Question about Frigidaire FGUS2642LF
Ice at the bottom of the freezer side
I believe the drain is plugged but I can not see from the top. How can I check the drain
    Prodigy:
    An expert who has answered 500 questions.
  • Frigidaire Expert
  • 650 Answers
The drain is usually located behind the freezer panel. The panel would have to be removed to gain access to the drain trough. Hot water works well to thaw the drain and a wire ran through it will help remove the debris build up.
Posted on Apr 13, 2014
dididsaythat
  • 291 Answers
SOURCE: Freezer not freezing
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, you can try turning freezer to Warmer freezer allowing MORE air to refrigertor side.
Posted on Sep 06, 2007
  • 213 Answers
SOURCE: ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Posted on Nov 29, 2007
SOURCE: Frigidaire Side-By-Side Top Not Cooling
sounds like its froze up. the coil is in the back of the freezer and blows into the freezer via a fan then cold air is carried to the fridge via another fan. more than likely condensation due to weather conditions has built up on your coil and has froze up or your fridge fan has stopped working. unplug fridge for a day to let thaw, if this doesnt work check you air distribution fan in top.
as for the lights not working in the freezer the switch is on the left hand side of freezer wall under ice holding tank sometimes water from thawing ice get on it and it wont come out all the way, take a blow dryer to it to thaw and dry it out.
Posted on Feb 17, 2008
  • 1314 Answers
SOURCE: Frigadaire freezer cold but fridge compartment is warm
i need the complete model number to narrow it down they still make the frs20zrg to this day the last two numbers like frs20zrgwo or frs20zrgw9 is what will tell me what kind of defrost system it has the serial plate is in the fridge side up by the light bulb or on the left hand side or right hand side of the fridge compartment up near the top sorry to be a bother but its necessary
Posted on Mar 30, 2008
  • 531 Answers
SOURCE: fridgidaire frs26zsh side by side ice buildup in bottom freezer
if you have icemaker install check there or you have a clogged in your drain cut ashort piece of naked wire wrap it on the heater coil and puch wire down in drain not a long piece please unplug refrigerator
Posted on Apr 02, 2009
Ice forming at bottom of freezer
I had a problem with Ice forming in the bottom of my freezer on my whirlpool side by side freezer-refrigerator. Turn out to be a plugged drain in the bottom of the freezer. That drain goes into a tray under the whole unit. During Defrost, condensate drops from the contents of the freezer on to the bottom of the freezer and goes through a drain tube to a pan underneath. Should that drain tube become plug and the water is left standing in the bottom of the freezer, it will turn back to ice after the defrost cycle is over. Once the drain tube is clean out, the problem goes away.
Oct 20, 2014 | Whirlpool Refrigerators
Where is the drain plug on the Amana upright freezer? How do I get to it to check for clog and clean out?
The best thing for you to do is unplug the machine and let the ice completely thaw. After that you gain access to the top of the drain you'll have to remove the back wall and the drain hole is under the evaperator. From behind the machine you should be able to see the bottom half of the drain. it sometimes has a rubber piece on it that resembles a duck bill. It that is indeed there remove it because that would be the source of the problem.
Apr 23, 2012 | Amana Freezers
Ice accumulates on the bottom of the frezzer
if frost free freezer then maybe drain tube plugged up with ice.defrost freezer and restart (unplug till ice melts)or drain hose is dirt plugged
Nov 23, 2011 | Samsung RS2630WW Side by Side Refrigerator
Top of refrigerator is warm and bottom freezes everything it is a side by side refrigerator and the top two shelves of the freezer(along with the icemaker) thaw and melt but the bottom freezes and the top...
poss answer is drain hole/vent blocked,as unit auto defrosts water/vapour collects at bottom and when unit swiches back on it freezes,poke out drain with thin wire with a small piece of cloth dipped in clorine bleach or blow out with air hose.do not use hot water to manually defrost/ clean drain holes every 6 months
Feb 07, 2010 | Refrigerators
Ice accumulating in bottom of freezer in side by side refridg with water and ice despensers
check that drain at bottom of freezer is not plugged up, check that fan inside freezer is running.
check defrost heating element/defrost timer.
most likely it is a defrost timer.
Oct 11, 2009 | Refrigerators
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Ice building up in bottom of freezer of side by side MSD27 Maytag
Your defrost drain tube is clogged up. Remove the ice and look for the top of a drain tube about 3/8-1/2" in diameter. Once the ice is gone, use a meat baster (turkey baster) full off hot water stuck in the top of the drain tube and blast hot water through to clean it out. Do this several times with about 4 cups of hot water so you don't over flow the drain pan and flood the floor
Dec 20, 2008 | Maytag MSD2756G Side by Side Refrigerator
I have a top-mount refrigerator that is leaking from the air vent
I had the same problem with a whirlpool refrigerator with freezer on top. TURN OFF & UN-PLUG IT. To access the freezer drain you must pull the refrig out from the wall and take off the bottom-back panel, it uses some (7) small nut headed screws. The drain is the white tube on the left going into the drain pan. You can push a long wire or plastic hose up the tube, however that will probably only hit something solid (ice) and blowing air may not clear it, until you let the freezer completely thaw out, which may take several days. The following may help experienced do-it-yourself nuts, it is not for the faint of heart! I took out all the freezer items and placed them in coolers to keep them frozen. Then removed the back panel in the freezer, two nut headed screws at the top center. The bottom of this panel was frozen to the bottom of the freezer compartment, so I used a hair-dryer to thaw it enough to loosen it. (Be careful: water and electricity do not mix well!) The left side of this panel has some electrical control wires attached, so the left side will not come out, just rotate the panel and lean it against the left side of the compartment. Now use the hair dryer (or pour hot water on it) to melt the ice along the bottom back of the compartment under the freezer coils. BE CAREFUL: The fins are sharp and will cut! Do not bend them. If they are all frozen up your heating element-defroster may be out. If there is only ice along the bottom, the hair-dryer or hot-water will help melt it to the point it can be removed. If the drain hole at the back-bottom-center-right is plugged with ice, poor hot water on it to speed up its melting. The hair drier will not do this very fast and you cannot chip it out without damaging the plug hole. Mine was solid ice about 2 inches into the tube and hot water finally thawed it. Then pour water through the hole to flush it out. Clean the bottom drain pan & re-assemble. Good luck.
Dec 16, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice acculumates in the bottom of freezer
Defrost drain tube is plugged. Drain is a round hole about the size of a quarter below the evaporator coils. (behind back wall of freezer.) Take a turkey baster with hot (not boiling) water and shoot it into the drain hole until water runs through it (into drain pan under refrig.)
Aug 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water seapage
check the freezer drain. is it frozen over? drain is back of freezer on bottom.
Aug 02, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire FGUS2642LF Logo
55 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
