Question about Apple iPhone 5
Iphone 5 won't restore! Kill me knowwwww
Okay, so I got an iPhone 5 for free a couple months ago with a totally destroyed screen. Like an @#$hole, I tried restoring it without the screen working anddddd it got about 99% in iTunes and then got the error messages. SO - I got a new screen/glass on the web so I could see what was going on and now it's stuck on the, "Plug in to iTunes" screen. I have tried everythinggggg I can think of to get this stupid thing to restore. I thought it may have been jail broken, so I got tinyumbrella - no joy. Also tried evasion, redsnow, itools, ireb, etc.,etc. There are no blobs to recover from Cydia and I've tried all the 6.* Firmware customs restores. I cannot get it into DFU for the life of me, redsnow kicks it out of recovery and it goes back everyevery time whilst plugged it. I've also modified the windows hosts file, turned off all firewall/antivirus stuff, changed my router to allow the traffic and loosen the firewall, etc. I KNOW there is a way to do this. I have a buddy that says I'm not doing it, (DFU), and the right now but I've done the whole "Up-Volume" thing and still nothing. Acts like there is nothing to boot? Any help would be awesome. I know there is a way to do this. No water damage FYI, checked for it. Help me PLEASEEEE and THANKSSSSSS
  • kozkoz Mar 30, 2014
    kill me *now...
    Also, it was on Verizon's network previously. Have the old sim card. Just FYI.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 32 Answers
Hi . usually when you see plug to i tunes logo nothing else could be done sorry .
you could try this method sometime its works . open the front of the phone like you changing the LCD & remove to screws from tree of the battery and separate the connection of the battery & put it back after 10 seconds . it should work good luck
Posted on Mar 31, 2014
  • 1 more comment
  • Maega Mar 31, 2014
    If for some reason the iPhone is keeping some bad data in RAM, this method could actually be worth a shot as disconnecting the battery will in turn clear RAM incase something won't clear on power off.
  • kozkoz Apr 02, 2014
    I tried this after reading your post, no luck.
    It just keeps flashing the Apple logo, "Logo...Black...Logo...Black...Logo".
    Night Owl:
  • 38 Answers
DFU doesnt happens with volume button.You keep connected the phone to computer then hold the Power and home button. Once you see the screen go off and come back again then wait till it goes off again and exactly after 3 seconds leave the power button and keep holding the home button.Your phone will be in DFU mode now.But honestly speaking the kind of troubleshooting you have done it seems there seems to be problem with hardware and most probably it is baseband (radio chip)
Posted on Mar 30, 2014
Testimonial: "As I stated below, DFU, whether it software-forced or physically, is not opening. I get now power slider or lock screen. I've never seen the iOS actually running. Do you mind explaining more specifically what you mean why you'd would think the baseband and what kind of hardware/software correlation it has? Thanks for taking the time to respond. ------------------------------------------------ I just posted this for someone else's response. : (So onlooker's, forgive the redundancy) Hey, thank you for the post/info. I have done the procedure you are speaking about. I (sometimesss) seems like it will work, but immediately after you release the power/sleep, you hear the Window's device unplugged/replug sound and it comes back on w/the iTunes screen. I should have been more specific about the Vol.-Up dealio as well: I've tried that unplugged, to see if it would boot regardless of boot-files, w/no joy. The poster after you said it may be a corrupt/damaned baseband? I also have redsnow already, along with just about every-other free JB freeware, and it will not allow for pwned DFU because the Recovery Fix doesn't not stay. It immediately resumes iTunes after about 10 seconds. I've also tried the "Custom-ipsw's" like "Recover In DFU.ipsw" as well as just the stock. I saw an article on here that said you may need to remove the .bbfw's which I've done an tried with every version. I feel like I am missing something, there has GOT to be a way around it. I mean JC - I work in tech. support and deal w/problems 1000x more difficult but there is simply something I cannot address in this instance. I mean, in reality it's just a small HD - it should be formattable, no!? Any-hoo.. Thanks again!"
  • kozkoz Mar 31, 2014
    @sunilkchopra, please read the testimonial on your comment if you'd like to read the respone to your post.
  • 92 Answers
Just to clarify, you need to have your phone connected to iTunes to enter DFU mode. And rather then the Volume buttons you'll need to hold power for 3 seconds (until the Apple logo shows), then Power + Home for 10 seconds (a little after the screen goes black) and finally Home (releasing power until iTunes says a device is in recovery mode)
Then go ahead and try to restore.
If that doesn't work you can try use Redsn0w to enter PwnedDFU mode, sometimes after a device is jailbroken to restore to either a modded IPSW or even stock firmware you need to enter this special DFU mode
Otherwise technically you shouldn't need to even enter DFU, recovery should be sufficient (hold home button as you connect the iPhone to iTunes)
Oh and FYI: The Volume-Up key is usually used to disable Mobile Substrate during bootup if it's installed on a jailbroken device
Good Luck!
Testimonial: "Hey, thank you for the post/info. I have done the procedure you are speaking about. I (sometimesss) seems like it will work, but immediately after you release the power/sleep, you hear the Window's device unplugged/replug sound and it comes back on w/the iTunes screen. I should have been more specific about the Vol.-Up dealio as well: I've tried that unplugged, to see if it would boot regardless of boot-files, w/no joy. The poster after you said it may be a corrupt/damaned baseband? I also have redsnow already, along with just about every-other free JB freeware, and it will not allow for pwned DFU because the Recovery Fix doesn't not stay. It immediately resumes iTunes after about 10 seconds. I've also tried the "Custom-ipsw's" like "Recover In DFU.ipsw" as well as just the stock. I saw an article on here that said you may need to remove the .bbfw's which I've done an tried with every version. I feel like I am missing something, there has GOT to be a way around it. I mean JC - I work in tech. support and deal w/problems 1000x more difficult but there is simply something I cannot address in this instance. I mean, in reality it's just a small HD - it should be formattable, no!? Any-hoo.. Thanks again!"
  • 3 more comments
    Aple should really loosen their restrictions on Apple products. Its true that the iPhone just have a small flash storage like an SSD but certain boot files are stored in ROM and cannot be overwritten or edited. They can, however, be damaged. Apple did this to circumvent Jailbreaking (didn't work). Now this may sound stupid but out of personal experience you may have more success on Mac. OS X has all Apple mobile drivers built in and no conflicting drivers, and since a DFU iPhone actually triggers and uses different drivers it may be worth a shot if you have access to any Mac with the latest version of iTunes.
    I actually tried on a Mac about a month ago, before I got into the jailbreaking stuff just straight restoring and it seemed to get further and actually gave me an "Error Report" of the log. I will ask someone at work if I can
    Funny thing with this whole endeavor is I've bricked my router as well lol. I use a Linksys E1000 that is not longer scripting because of all the changes I've made/reverted. Apparently, after talking to Linksys Tech SUpport, the only way around it is to reset it, which sucks because I have some many things set in it. Portforwarding, IP reso, etc etc. But, even tho you can no longer log into it, it's still managing to keep the settings I've put in place. ipconfig is still the gateway I assigned and same DHCP pool. Just weird really, and somewhat irritating.
    And I have redsnow also, can't remember if i said that or not. I literally have every freeware JB there is out there, no joke.
    New Friend:
    Problem Solver:
  • 6 Answers
If the methods above don't work well for you. You'd better try some software which would help you get the problem fixed. This guide may give you some hints: iPhone Stuck in Recovery Mode How to Fix
Posted on Apr 23, 2014
  • kozkoz Apr 24, 2014
    @Shirley Xiang: I've tried Dr. Fone already. Because i got the phone for free from someone who had it left in their apartment ie the previous owner is unknow, I am not able to recover anything from it. my @me.com recovers my data from previous iPod's and whatnot, but there is nothing regarding the iPhone. The recovery fix in Dr. Fone does not work, simply puts it back in recovery mode. Thanks for the help attempt tho - I'm sure it will help someone else. I've been told by someone who knows more about iOS than myself that the "baseband" is no good.. Not sure if it is or not but as the phone is still a paper-weight, it verywell could be.
5 Suggested Answers
livesup
  • 7 Answers
SOURCE: error 16xx
I would suggest reseotring it once more and trying to use quickpwn again. If it fails you may alternatively want to use Winpwn, it basically does the same thing.
Winpwn: http://www.winpwn.com/index.php/Main_Page
Posted on Feb 18, 2009
  • 42 Answers
SOURCE: help on frozen iphone 3.1.3...want to restore
just switch off your phone and press home button and connect to cable and restore it from there it would get solved
Posted on May 25, 2010
kid_ant
  • 881 Answers
SOURCE: I jailbroke my iphone 3g on blackrain and cydia, a
Yes! Take a look at this eBay listing:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=320576101949&ssPageName=STRK:MESELX:IT#ht_2280wt_1139
that guide can help you out!
Posted on Aug 16, 2010
celltech_adv
  • 443 Answers
SOURCE: my iphone does not turn
If the ios 5 is in beta. That means that it's in Test mode. If it keeps messing up and dying. It's not ready yet.
Beta = Test
So the best you can do is offer feedback to Apple over it, then restore your phone back the the latest ios 4 for the time being, and wait for ios 5 to get out of Beta mode
Posted on Sep 21, 2011
How to recover my lost contacts from my iphone 4s?
If you already have an iCloud account, you should be fine.
Just restore you iphone with icloud and you will have all your contacts again.
if not, check if you got contacts on your SIM card. To do that, go to settings, Mail and contacts and choose import SIM contacts.
If you have a google email adresse set up in your phone, you can recover them from gmail.
hope i helped you
Nov 21, 2014 | Apple iPhone 4S
Laptop LCD/Display Problem, Green and Pink Tints???
Their are a couple things that could be causing this, My first thought is that the screen its self is damage. A LCD screen is composed of millions of tiny pixels so when some fails others will still work.
That other thought is that the GPU or video device on the laptop could be failing and creating video problems. Have you tried closing the laptop and opening it agian, this would help rule out a bad cable connection.
Dec 24, 2013 | Computers & Internet
I droped my iphone 3G and the screen went totally white colour,restarted it but still same,how can it be replaced without geting a New LCD
Hello dear
You can work to restor iphone and it should be good
And remained a white screen will be a problem valuable cells in the screen
May 14, 2011 | Apple iPhone 3G
Hi my name is jessica and about 3-4 days ago i tryed to reset my iphone and i did and then it shut off and froze when it trys to turn on
try leaving it on the charger and leaving it for atleast 4-5 hours on the apple screen..
Sometimes that is good enough to let it come out of the frozen state...
Otherwise what you have to do is put it into restore or DFU mode and use itunes software to restore the firmware on the iphone...
You will have to search google to figure out how to use itunes to restore and how to put your phone into restore mode..
Nov 06, 2010 | Apple iPhone Smartphone
My iphone screen is cracked and my touch slide button wont work but i can still can except call but i cant slide it to unlock it is there anyway to fix it
my phone is a IPhone 3gs and i cracked the screen a couple of months ago and a couple of days ago my screen started to act really slow and it wouldnt work on some parts and now today my screen wont work nor respond at all. PLEASE HELP ME I REALLY NEED MY PHONE ...!!!!!
Jun 16, 2010 | Apple iPhone Smartphone
My iphone cracked about a few months ago and a few days ago i spilt water into the crack. It started with my ringtone not working and then my phone completely shut off. I tried restoring it on itunes but...
No, it's not the end but you will most likely need to take it in to a Authorized Repair Center so they can repair the broken, cracked screen and any internal damage since obviously water or moisture getting inside is an issue.
Jun 09, 2010 | Apple iPhone Smartphone
G3 iPHONE - Battery Life
I've got my G3 a couple of months ago and in the setting I adjusted my screen brightness to the minimum level that I feel comfortable with. That did help improving the battery life. Also two more things helped as well. If you keep your bluetooth on at all times that will use your battery. The last thing that I realized was the wifi mode. Since I have free internet access came with the Iphone plan I turned my wi-fi off and it help me with the battery life too. I get avarage of 3 days from my phone without charging it now.
Aug 23, 2008 | Apple iPhone Smartphone
Wifi Not working anymore on 1.1.4 iphone after ziphone unlock.
OKAY WELL APPLE INC HAS STOPPED OTHER CARRIERS TO USE THERE WIFI YOU CAN GET ARRESTED FOR UNLOCKING THE IPHONE THATS THE NEW LAW SORRY THAT I COULD GIVE SUPORT ON YOUR PROBLEM.
FOR ANY MORE INFORMATION PLEASE VISIT US AT APPLE.COM/IPHONE
  1. CHECK FOR IPHONE UPDATES
  2. RESTART PHONE
  3. GO TO SETTINGS AND THEN GENERAL RESET IPHONE
  4. FINALY REACTIVATE THE IPHONE
THANK YOU APPLE GENIUS BAR
May 19, 2008 | Apple iPhone Smartphone
My iphone is lockup
use ziphone 3.0 last version for now. ı did. it does everything you need. all you need to do is click do it all.. it's free, you can donate if you want..
Mar 31, 2008 | Apple iPhone Smartphone
Apple iPhone 5 Logo
144 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
