Question about Cisco Computers & Internet
Cisco Acces Point series 1020 Air-AP-1020-A-KG
How to reset and the Cisco Acces Point series 1020 Air-AP-1020-A-KG and configured it as a repeater in a domestic WiFi network.
  • Cisco Master
  • 3,320 Answers
This is an enterprise AP and needs to run with a Cisco router.
Posted on Apr 03, 2014
Can get router to work
The Cisco Aironet 1200 access point provides secure wireless connection to your network. Cisco's wireless access design meet the needs of a small to medium size business.
This unit provides secure network access for laptops or Wi-Fi capable portable devices, which you upgrade at any time as your business grows.
A beneficial feature of the Cisco Aironet 1200 is its ability for the administrator to reset the access point remotely.
This resetting process works through your internet browser.
Log on to the System Configuration page by entering your Cisco Airnet 1200 IP address in your browsers web address text box.
Enter your user and password information from the pop up menu.
Click on the "Setup" button from the summary status page.
Select the "Cisco Services" setup option and click on "Manage System Configuration."
Click on "Reset All System Factory Defaults" to reset the router.
The Cisco Aironet 1200 will be restored to factory defaults.
http://www.cisco.com/en/US/products/hw/wireless/ps430/index.htmlCisco Aironet 1200 Series
Configaration Cisco Aironet 1200 Serieshttp://www.cisco.com/en/US/docs/wireless/access_point/1200/vxworks/configuration/guide/bkscgc10.html - wp1016665
May 07, 2014 | Linksys Cisco Aironet 1200 Wireless Access...
Reset Access point Cisco 1020
If your current controller can't see the AP, then the 1020 can only be reset through the Controller it was originally configured with. It doesn't have a console port, so you have to connect it to the old controller and run "clear lwapp private-config"
Mar 25, 2014 | Symbol Spectrum24 4131 Access Point...
When I enable the vlan option in an EAP9550 I lose wireless access
Bruce,
Is the goal to use a different VLAN for each access point (AP)? If so then you will need to configure each NetGear port to use the same VLAN as the AP that is connected to it. You will then need either a switched virtual interface (SVI) for each VLAN on the NetGear or a trunk port (802.1q) from the NetGear to the Cisco. I'm not sure the NetGear will support SVIs but it will support trunks. An SVI basically creates a gateway for each VLAN's subnet. For example, let's say AP1 uses VLAN 10 and the subnet is 10.0.10.0/24 while AP2 uses VLAN 20 with a 10.0.20.0/24 subnet. The NetGear will need 2 SVIs, one for each VLAN/subnet. The first SVI for VLAN 10 can be configured with IP address 10.0.10.1/24 while the second SVI can be configured with 10.0.20.1/24 for VLAN 20. These IP addresses will be the gateway for each VLAN. Finally, the NetGear would need to act as a router and route each VLAN's subnet to the Cisco device. Once again I don't believe the FS726TP supports this.
The other solution would be to create a VLAN trunk port between the NetGear and the Cisco device but I believe the Cisco RV042 does not support trunking. If it does the trunk would be configured to carry all of the VLANs to the Cisco device which would then have SVIs created on it.
If neither of the above is possible you would need to use the same VLAN for each AP and each of the interfaces on the NetGear and Cisco devices which negates the need for the VLANs.
I hope this helps.
Mar 13, 2014 | EnGenius Computers & Internet
How to resolve wifi access mode not supported
an AP is used to extend you wireless range and will connect to your router to provide network and internet access. An AP by itself cannot connect to the ISP since it does not use a WAN port
a router is an AP that will allow you to connect to your ISP for internet connection. A router can be configured to work as an AP but a AP cannot function as a router.
Feb 19, 2014 | Linksys Business Series WAP4400N...
My Cisco aironet 1141N-ke9 showing red blinking continuously and stuck in that .Now only access via console.Can any one solve it
Sounds like the network connection to the AP is shot. Try a different cable, different port on the switch, or repower the device.
Aug 05, 2012 | Aironet Air-ap1141n-a-k9 Cisco 1140 Series...
Good day, I want to connect three/four Cisco linksys wireless router wirelessly together in a home network such that: 1. Systems working with each AP can comunicate with those with other AP 2. all of...
Ok, what you really want to do is have one router as an access point and the others all set as repeaters.
You'll want to find some WAP54G for the access point/repeaters
The procedure, I cannot explain better than this article does:
http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&login=1&app=search&vw=1&articleid=4200
it has diagrams and the works on setting those routers into repeater mode.
Post a comment here if you have any issues with that configuration!
NOTE: your configuration should use 2-3 WAP54G with a WRT54G as your main router at the modem.
Feb 22, 2011 | Computers & Internet
Can't connect to my Cisco Aironet 350 wireless Access Point
Did you setup and configure your Cisco aironet 350 directly from your laptop? I would verify the IP configuration on your laptop and make sure that your Default Gateway and subnet mask and DNS are set correctly. Give it a static address on the same subnet and see if it can see the router. Hope that helps!
Cheers!
J the Guru
Sep 09, 2017 | Cisco Aironet 350 Series Wireless...
Configure cisco aironet wifi
if ur using IOS autonomous AP, then u'll need to configure the bvi interface to get an ip address and then enable the interface. once it has an ip, u'll need to configure the ssid, vlan, etc - choices include doing so with the CLI or web page GUI. U'll need to enable the built-in web server then u can access it via the web interface to setup the ssid, any vlans, radius, etc. good luck.
Jan 17, 2008 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Computers & Internet Logo
259 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
