Question about Vacuums
Simac evt 100 steam cleaner
Water heating, pressure building, but no steam from nozzle.
  • 54 Answers
Try taking the steam head apart and cleaning. If difficult to remove, fill a basin with white vinegar & a small amount of water and let it soak to remove the built up deposits in the system. Remember to only use distilled water when steaming to avoid build up.
Posted on Mar 31, 2014
SOURCE: steam will not eject
Same issue with my model. Heated up but would not produce... I called it SED (Scunci Erectile Disfunction) My doctor prescribed him some lube, and it worked! Now days Im happy to say we share a heathy steamy relationship!
Say goodbye to SED forever with the help from lube! All you have to do is open up the unit, locate the circular brass colored button, apply a squirt of lube (wd-40), create a decent amount of pressure and play with the little button until you notice smooth in-out motions. Put the unit back together and BAM you two will be back to a hot and steamy relationship, just like you had when you first met! ;)
Posted on Sep 10, 2008
  • 31 Answers
SOURCE: steam cleaner does not get it to steam pressure
scaled up temp sensor, faulty thermostat
Posted on Jan 07, 2010
SOURCE: scunci steam cleaner not spraying steam
Unscrew the screw on the handle and remove handle. Remove rubber where top screws on. Remove two screws and the top and now unscrew the black pipe where the steam comes out. Now remove the button and see the small metal protrusion on the pot where the button was. Hit it with a hammer a few times softly to remove the scale buildup until the metal starts moving in and out again. I also sprayed it with a little silicone spray. Now put everything back together again. My steamer now works beautifully again!
Posted on Jan 11, 2010
Vac Belts
  • 701 Answers
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Posted on Mar 02, 2010
Testimonial: "just what I was looking for thank you"
  • 20 Answers
SOURCE: My Bissell Pro Heat 2X steam cleaner is not releasing the water
Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
Posted on Apr 30, 2010
Does this cleaner heat up the water for steam? It is called a steam cleaner, but I do not see anything about how to regulate the temperature of the water to make the steam and so no one gets burned.
Steam is steam is steam - it has a temperature of 212 degrees F and if you go any lower it is no longer steam - condenses back to water. Capiche? If you pressurize the steam you can then raise its temperature to a super heated condition. How do you think a pressure cooker works??????
Aug 26, 2017 | Vacuums
The steam comes out of the water reservoir cap instead of the steam Jet Nozzle.
I can only guess since I have never worked on one of these units, but I think you lost a gasket on the cap. Pressure must build in the reservoir before being forced out the nozzle.
Jul 13, 2015 | Tristar SB Steam Buggy Vacuum
My polti steam cleaner wont work when i click trigger
Check the wand and line for calcium build up especially in the nozzle. Hard water will deposit a lot of calcium in the system, which needs to be cleaned regularly to keep it running freely.
Aug 25, 2014 | Polti Vaporetto 2400 Canister Steam Vacuum
Repair Polti VT Evolution steam cleaner doesn't work
Steam nozzle/lines are probably clogged. The minerals in the water will eventually clog up the system, you need to use only Distilled water whenever possible to eliminate as many minerals from the water as you can. If the screws are spinning and not coming out, you will have to pry up slightly on the cover the put pressure on the inner parts so they will come apart. Easiest way is to push something like an old credit card betwen the seams and pry up carefully. go slow and easy so you won't break anything.
Aug 20, 2014 | Vacuums
Can the nozzle get blocked and affect the pressure of the steam
Yes particularly if you use hard water (high in mineral content)
Aug 09, 2014 | Euro-Pro Steam Penguin Hard Surface Steam...
Unit not working to heat water--cant hear compressor starting up like normal
Did you make sure that it was closed all the way? Sometimes if the water canister is not on all the way it can cause this. And depending on how old the steemer is maybe that part went out. But I would check all the lines to make sure nothing is clogged or pinched
Jun 07, 2012 | Vapor Professionals TR6 Canister Steam...
Sanapathic
do you not have instruction book opration guide?? to make steam you req water then a method of heating it thus produce of steam results and pressure which expels via a nozzle ? just like the electri kettle
Oct 19, 2008 | Oreck Sanapathic DMS2000 Handheld Steam...
IWOULD TO KNOW IF STEAM CLEANER ARE HEATED WATER
yes, they heat water to over boiling point by putting it under pressure so you only get steam. it cleans with very little water.
Jul 27, 2008 | Vacuums
Vacuums Logo
79 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
