Question about GAEMS G190 - G190 Xbox 360r/ Playstationr3 Slim Vanguard
G190 cracked screen
My screen needs to be replaced
  • 2 more comments
  • Stefan
    Stefan Mar 30, 2014
    Sorry i am trying to find out if anyone knows where i can get a replacement screen or if it is possible to re\place the screen
  • Yasir Khan
    Yasir Khan Dec 11, 2016
    This my number contact with me our company will do it for you
  • Yasir Khan
    0507771348
  • Eric Goodman
    Eric Goodman Apr 07, 2017
    My screen need to be replaced
Screen needed is m185bge l22 made by Chimei innolux. Bought mine for £29 off eBay and isa plug and play replacement. Good luck
Posted on Jan 07, 2015
Take a picture of the back of the lcd for me. Like this one from the g155. The G155 uses an easy to find laptop screen. This one should too. g190 cracked screen - b86e767b-1a18-4536-b8a1-c7e1b734254e.jpg
Posted on Jun 03, 2014
  • Michael Jun 09, 2014
    m185bge-l22 is the lcd part # for the g190 series
GAEMS g190 vangaurd cracked screen
hello, although I want to go into detail explanation with you what how to genericly replace a devices screen it would not be the proper thing to do. Your request for a step-by-step guide to replace a screen on a particular device is somewhat not realistic, in particular this device is very uncommon. I have one of these devices mine is about 3 years old and it has the same problem however what you need to do is order another screen. carefully look around the unit for the screws in order to remove the casing around the screen, once you remove the casing there should be more screws holding the lcd in place, remove those screws and any other screws holding the lcd in place. lightly lift on the screen in order to try and lift it up putting only finger tension on it, once the screen is release look for a plug on the back of the screen that connects it to motherboard or maybe a motherboard on the LCD screen itself connected to wires which go to the motherboard of the unit, after disconnecting remove the screen and look for any identifying markers to identify the screen. after locating the model number or some identifying factor of the screen go ahead and search for it on ebay or somewhere else do a general Google search if you are able to find the lcd you can replace it just as easy as you took it out there is no step-by-step guide for your particular device, I suggest maybe making a video question showing the unit and maybe someone can respond to you giving you steps that way, however my solution I do believe will be the most simplest for you. some more good news is that LCD that's inside that you need is the same type that you will find in your laptops and televisions a lot of them are interchangeable it really depends on the company that made them and the type of connection that they use so you maybe will be able to go to a computer repair shop and get a screen or a goodwill and find a cheap l_c_d and take it apart as long this is the same size in dimensions there is chance that you may be able to find a replacement however not guaranteed.
Good luck and Thanks
Questions? Just ask!
Nov 25, 2015 | GAEMS G190 - G190 Xbox 360r/ Playstationr3...
Lcd tv screen crack
any crack in the screen will need replacing it weakens the screen and can shatter. also the picture don't look good. would change the screen.
Mar 26, 2013 | Coby TF-TV3217 32 in. LCD TV
Alpine CDA-7965 go ERE=G190 diagram wire
Most radios have universal wires for the most part.Yellow is 12volt constant power,red is switched power(accessory)black is ground.
the 2 gray wires are right front speaker(black stripe is always negitive)
the 2 white are left front
purple is right rear
green is left rear
orange/white is illumination
Dec 20, 2012 | Alpine ERE-G190 Car Equalizer
Do i need to replace lcd screen if i cracked glass screen
If it is working okay there is no need, but if graphics and information become distorted or do not display then yes will need replacing.
Feb 20, 2012 | Coffee Makers & Espresso Machines
The screen looks cracked and multi colored but the actual glass isnt broken or cracked
Your LCD/monitor is cracked from the inside. There are several things that can cause a screen to crack from the inside. The two most common are pressure on the screen or dropping the machine. Sorry, but it is irreparable. You need to buy a replacement.
Jun 15, 2011 | Computers & Internet
Screen is cracked
http://www.ownta.com/original-htc-g1-cell-phone-reparing-lcd-display-screen-replacement.html
This is what you need, just fix it by yourself, if you know how to repair.
May 27, 2010 | HTC G1
Cracked screen
http://cgi.ebay.com/ACER-ASPIRE-ONE-8-9-LCD-SCREEN-ZG5-A150-AOA150-AOA110_W0QQitemZ180422161297QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2a01ffb391
you do not need to replace the converter- As long as your screen is just cracked then the converter is fine. Converter may be bad if your screen is really dim or just blank.
Mar 22, 2010 | Acer Aspire 5100 Notebook
Broken screen on Blackberry Curve needs to be
you can use warranty or send it to the company and they will charge you if you hadnt taooken the warranty
Sep 12, 2009 | RIM BlackBerry Curve 8310 Smartphone
Cracked ipod touch screen
£53 from these guys www.ukipodrepairs.co.uk
Aug 21, 2008 | Apple iPod touch
GAEMS G190 - G190 Xbox 360r/ Playstationr3 Slim Vanguard Logo
1,565 people viewed this question
Top GAEMS Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Are you a GAEMS Video Game Console and Game Expert? Answer questions, earn points and help others
