Question about Irons
I have found a leaflet about crochleting but cannot find how to order it. please help
This is a older leaflet but you show it available for 7.95
Steam iron model 14884. Need replacement filter. Can I get locally or only order online
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Please provide manufacturer name of your steam iron. Also which city are you located in.
Jul 31, 2014 | Irons
How do I fill my iron with water ... Rowenta DA-49,6
see the video attached and proceed according. God bless you
Feb 06, 2013 | Irons
Bosch sensixx b3 instruction manual
I have a Bosch sensixx b3 iron I have Lost the manual and need to de scale it
Jan 28, 2012 | Irons
I have an older (1997) Rowenta DE 11 Powerglide iron. In the process of cleaning it, I mixed up the order of the wires. The colors are brown with the power cord, dark blue with the power cord, blue by...
If you can take a sharp picture of the circuit board and send it jodamechanical@aol.com I might be able to help you.
P.S. Make sure all wires and circuit board are clear.
Feb 10, 2011 | Rowenta Powerglide DE011 Iron with Auto...
Instruction leaflet for Morphy Richards Iron 40659
It is always better to use distilled water, but this is not essential. However when using normal water, if the water has high salt content, white residue may be left on the bottom plate.
Jul 31, 2009 | Irons
Sunbeam 4267-000 not turning on just blinking red
"FF" or a blinking light will display meaning “Fault Found”. The “fault” is in the amount of power available to the blanket, mattress pad or throw.
There are several causes to this problem:
1. Bedding product is plugged into an extension cord, surge protector, power strip, or not plugged into a direct wall outlet.
2. Bedding product wasn't plugged in properly.
To FIX this problem, do the following to reset your bedding product:
1. Unplug the power cord from the electrical connection.
2. Unplug the cord from the actual bedding product itself.
3. Re-plug the cord into the bedding product. Make sure the connection is secure and complete.
4. Re-insert power cord back into a wall outlet.
If the 4 steps above are not followed in order, the bedding product will not properly reset.
Dec 08, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
Iron no longer charges
no batteries ! works by just heating the base element which then retains the heat simply by virtue of it's materials and mass.
the sparking sounds like a short in the circuitry or element. If so, no replacement parts or service is available that I have found yet. I own one too, and have been looking for a while ! mine still works but I need some cosmetic parts. If you are interested in selling to me for parts, please contact me @ votz03@sbcglobal.net Thanks!
Jun 06, 2008 | Maytag MLI7500A Iron
Irons Logo
46 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
