Question about Cobra 2500w Power Inverter
Power invertor weill beep a few times then shut
Power invertor willl beep a few times then shut off.Try to turn it back on and still beeps and says LUP on screen where watts and volts are.It is a cobra CPI-2575 invertor.
  • 365 Answers
Insufficient ground...check your connections and try again...do NOT continue to use the unit if the problem persists.
Good Luck
Posted on Jun 15, 2009
What does lup mean on inverter?
as I see no make (BRAND) I can only say search for it on Google and see if there is a manual . or contact the manufacturer
Aug 31, 2015 | Electronics - Others
Why does my 900w microwave trigger the LUP code & alarm?
you need at least a 1900 watt inverter with a fully charged battery to run a 900 watt microwave,it uses 900 watts to make microwaves and it uses 700 or so to run everything else.
Mar 11, 2015 | Inverter Electronics - Others
My GE stainless steel 1100 watt microwave starts beeping out of the blue and the display panel shuts off and when I open the door it resets itself and then starts to beep when I close the door again.
Try removing the power cord for about a minute, push all the touch pad 'buttons' and then plug it back in. If this doesn't work it sounds like you may have a bad door interlock switch or a bad PCM .. Good luck !
Feb 11, 2015 | GE XL1800 1100 Watts Microwave Oven
My skytronic power invertor is making a constant beeping noise
do you have a load plug in at the time if so try it with nothing plugged in if all is fine the load may be to big for the invertor
Apr 04, 2010 | Electronics - Others
My friends computer just stopped working while she was using it. The screen froze and than she shut it down. When she tried to turn it back on all that happened was that the caps lock, the scroll, and the...
There are a number of things that can cause this to happen. Try taking the battery out of the notebook, disconnect the AC adaptor (if in use) press the power button a few times. Re-install the battery, reconnect the AC (if needed), press and hold the power button for about 2 seconds. This is a hard reboot and should correct you issue. When the notebook powers up, make sure you remove any cd's in the cd-rom drive.
Good Luck,
C2Solutions
Jan 05, 2010 | HP Compaq Presario V2000 Notebook
Whister 1200 Inverter
if the inverter is wired to a lighter socket then you do not have enough power as lighter sockets are generally limited to 100-150 watts. If you are using the supplied battery clamps, then is the vehicle running to supply enough power to run your TV?
Sep 25, 2009 | Whistler PI-1200W 1200-Watt Power Inverter...
Power drive 2000 INVERTER what does Lup stand for?
check the wires you either have a bad connection or a bad wire the power in verter has 4 wires 2 neg 2 pos if 1 of the 4 is loose or bad it will give lup code .
Aug 23, 2009 | Electronics - Others
Cobra 2500w Power Inverter Logo
1,696 people viewed this question
Top Cobra Electronics - Others Experts
Gil Shultz
Bill Boyd
hewillseeyou
hewillseeyou
Are you a Cobra Electronics - Other Expert? Answer questions, earn points and help others
