Question about Butts Sunline Retractable Reel Clothes Dryer R400
Retractable clothesline knob b will not move to lock the lines
Knob B will not move to lock the lines
  • Rhonda Sabatka
    Rhonda Sabatka Apr 02, 2014
    Please help with this problem for my clotheline
  • 30 Answers
Hello
i have just purchased one of these. at the bottom of mine there is a round piece where you can put the line around to lock. i double mine up around this point
Posted on Apr 21, 2014
Is there a special tool for removing commercial locksets?
The spanner tool that Schlage includes with many of their new locks will work on the old ones. Search Google images for "schlage spanner wrench" and you'll see different styles, but they all can be made to work. You remove the inside knob (or lever handle, but let's say it's a knob) by sticking the pin end (or a straightened out large paperclip) into the hole in the knob towards the edge of the door and press in the springy retainer. While pressing in the retainer, pull the knob away from the door. If the pin is all the way in, the knob won't move away more than about 3/32", so after it starts moving, remove the pin and the knob should come off the rest of the way. If the inside knob has a keyhole, then you need to turn the key about 90 degrees, or as far as it will go, before the retainer will move. If you don't have a key, then pick it, or drill the pins so it will turn. If you don't care what happens to the old lock because you are going to replace it, you can cut off the inner knob with a hacksaw. Cut as close to the rose as possible. Once you have the knob off, use the spanner to remove the inside rose trim, and then pull the lock out of the door from the outside.
Oct 13, 2017 | Schlage Locks & Locksmithing
How do i remove a commerical lockset?
For Schlage, Corbin-Russwin, Falcon brands, you remove the inside knob by sticking a long metal pin or a straightened out large paperclip into the hole in the knob towards the edge of the door and press in the springy retainer. In some brands, you have to back off the rose to get to the retainer. While pressing in the retainer, pull the knob away from the door. If the pin is all the way in, the knob won't move away more than about 3/32", so after it starts moving, remove the pin and the knob should come off the rest of the way. If the inside knob has a keyhole, then you need to turn the key about 90 degrees or as far as it will go, before the retainer will move. If you don't have a key, then pick it, or drill the pins so it will turn. If you don't care what happens to the old lock because you are going to replace it, you can cut off the inner knob with a hacksaw. Cut as close to the rose as possible. Once you have the knob off, use a spanner tool to remove the inside rose trim without scratching it, and then pull the lock out of the door from the outside. If you don't care about the lock, you can use a pipe wrench or pliers to remove the rose. On non-commercial locks, you remove a decorative cover over the inside rose trim, and then have to remove a couple of screws to get the inside trim off the door, then you can remove the lock from the outside of the door.
Oct 13, 2017 | Locks & Locksmithing
Tighten line in Daytek retractable clothesline
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Dec 04, 2016 | Televison & Video
How do I replace a broken line on a retractable clothesline?
You will have to extend it fully, then take the housing apart to get to the anchor points for the line. Once there you can see how it mounts. Then replace the line with same length replacement line.
Sep 20, 2014 | Cameras
The knob on my kenmore elite won't move the timer.
The knob itself turns the switch on . The skirt move the timer position. Try turning the skirt. You probably have a broken knob. On these the knob is held in place with a plastic rod inserted into it all the way. This spreads the tip and retains the knob. To get the knob off to yank out the skirt for a look see you need to pull that rod out a tad to release the knob. 88be11a.jpgThat shaft has a rounded end on it that spreads out and locks the knob on. Clever ain't it? These timers are cheaply made, if you cannot find fault with the knob or the skirt then you is gonna need a timer.
Jun 05, 2010 | Kenmore Washing Machines
Cold Am . I turned the left knob 45 degree . All i get is HEAT,knob moves
Hi rafis1234,
if you are handy, you can remove the small dash panel where the a/c control knobs are and then you'll access the lever mechanism and most of the time you'll find a rusty lever or someting has jammed the lever.
Cheers
Oct 28, 2008 | 2004 Nissan Sentra
Mirror lock
Possibly the shaft has jammed. Follow this link for a source of good information: http://www.mapug-astronomy.net/AstroDesigns/MAPUG/ArhvList.htm
From their files:
The locking knob has a gear on the inside end of its shaft. It engages teeth on the outside edge of a large metal disk connected to the mechanism that locks the position of the mirror on the central baffle tube. Rotating the locking knob one direction rotates the large disk to tighten the collet on the central baffle. Reversing direction loosens it.
The teeth do not extend all the way around the large disk. So sometimes the locking knob gear jams to a stop before the lock is fully engaged. Soon after the GPS scopes first started shipping Buck Harley discovered that in such cases you can remove the locking knob with its shaft and gear, then reach in and rotate the large disk with your finger. Replacing the locking knob will now allow sufficient rotation to fully engage the lock. If you happen to move the large disk in the wrong direction, then just repeat the process and move the disk in the other direction.
You don't need to tighten the lock down hard. Just a little snug is enough. You should not attempt to use the coarse focus knob while the mirror is locked. Damage to the focusing mechanism could result.
This design is intended to precisely hold the mirror position. So, yes, it is meant to allow effective use of a separate guide scope by eliminating mirror flop when in the locked position.
May 26, 2008 | Meade LX200GPS Telescope
Retractable function selector knob stuck
facia panel most probably need removed, not to bad a job, but oven need to come out... go to bosch, web site...search parts finder with your model , and you will see an exploded diagram, this may help yet you get an idea on how it comes apart.. failing that call an engineer...
Jul 02, 2007 | Bosch HBN 560570B / 560550B Electric...
problem is caused by the sprung mechanism within the control knob sticking remove the knob completly, try to squeeze together in your hand to release and then spray with a wd40 type product, if this fails you will need to replace the knob, the knob only pulls off. Engineer
Jul 02, 2007 | Bosch HES436U Electric Kitchen Range
Butts Sunline Retractable Reel Clothes Dryer R400 Logo
203 people viewed this question
Top Butts Dryers Experts
Are you a Butts Dryer Expert? Answer questions, earn points and help others
