Question about Pc America Computers & Internet
Cash register express
Turned wireless adapter off and client is asking to re-register. Turned back on and client connects to server. Would like to keep wireless off.
    Sergeant:
  • Pc America Expert
  • 310 Answers
Hi Lloyd,
need more info about your setup to help you. is this a stand alone station or connected to a server? your question wasn't clear about this.
sysadmin@ccybernet.com
Feel free to email me with more details if need be.
Posted on May 21, 2014
SOURCE: Screen hangs after cash transaction or credit card transaction
Is the problem you're having with a computer running Windows Server?
Posted on Apr 13, 2009
  • 32 Answers
SOURCE: Restaurant Pro Express - my client workstation
the default user is 'sa', the default password is 'pcAmer1ca' for the database.
Posted on Jan 28, 2010
  • 310 Answers
SOURCE: Syncing client with server - Restaurant Pro Express
Your getting a connection successful because your looking at the localhost. The server would be the network name of your server. And the password is case sensitive and is pcAmer1ca. (Note the number 1, not an i)
Posted on Jan 29, 2010
  • 310 Answers
SOURCE: can i convert cash register express data to excel
If you are looking for data in a specific format other than the standard reports, it is not easy. I have developed special reports and spreadsheets for several companies from CRE, but it is not an easy process. If you would like my assistance, contact me. sysadmin@ccybernet.com
Posted on Feb 03, 2010
  • 32 Answers
SOURCE: How do i connect a client directly to my server?I
First make sure all stations are on the same version, then uninstall the enterprise server/client services from the appropriate machines. Next, direct connect the client to the server. pcAmerica no longer supports the "enterprise" sync (which is lame) but have switched over to sql replication in the newer versions (which costs $$$). so the only way to do sync w/o redundancy is with direct connect. id also check out faq.pcamerica.com for some help
Posted on Nov 03, 2010
Station asking to register
Are you running this station wirelessly? Last I checked, pcAmerica does not recommend using wireless workstations. Correct your wireless problem. This is not related to RPE. Or run a temporary line to workstation. Verify you are connected to your network and re-register RPE.
Mar 30, 2014 | Pc America Restaurant Pro Express
Is anyone having issues with Cash Register Express, database on the server, Firewall has to be off for the other registers to access. I don't like the fact that the firewall on the main server has to be...
PCAmerica does usually recommend turning off all firewalls, windows and others. However, they also have a procedure for running the sql server on a static port that will allow the firewall to be turned on using exceptions for this static port. I have never tried this option, but I can send it to you or try and help you.
B Mattern
Please return and give me a favorable rating if this helps or is of value to you.
Dec 18, 2010 | Pc America Restaurant Pro Express
Hello, Trying to install this NetGear RangeMax NEXT WN311B into a Pentium III computer with a AMD chip, should be fairly simple just put SSID and Passphrase, - IT WILL NOT CONNECT! Please help
From a computer that uses an Ethernet cable to connect to the router,
access the web-server "inside" the router, and enable "logging" of events,
i.e., attempts to connect, and IP-addresses handed-out by the router to wired/wireless clients.
Then, on the computer with the RangeMax, try again to connect.
Go back to the computer connected to the web-server, and "refresh" the view of the newly-updated "log" file. What new messages are displayed?
Nov 17, 2010 | NetGear RangeMax NEXT WN311B...
Jan 29, 2010 | Pc America Restaurant Pro Express
Dec 17, 2008 | Pc America Restaurant Pro Express
Wireless Doesn't Work - No light.
If someone else setup the router for you they may have turned off the wireless. If you can connect via ethernet use the web based configuration utility to turn it back on.
The intial setup is as follows in the manual:
To provide an initial wireless connection to your network and the Internet:
1 Connect the SBG900 to the cable TV system as described in Section A.
2 On each wireless client computer, install the wireless adapter hardware and
driver software according to the manufacturer's instructions.
3 On each wireless client computer, set up a wireless adapter profile to
“connect” the client to the SBG900. The procedure depends on your
wireless adapter and computer operating system.
In your initial profile, use the SBG900 default wireless Network Name
(ESSID) motorola (case-sensitive).
Your computers are connected but not secure.
The default SBG900 settings provide no wireless security. After
your wireless LAN is operational, be sure to enable security as
described in “Setting Up the Wireless LAN” in the SBG900
User Guide
Oct 30, 2008 | Arris SURFboard SBG900 Wireless Router...
How to set up a security setting on my WBR-1310 D-Link router
Dear Sir/Madam
My compu name = manta
Installed windows server 2003
This administrator is the user name
Password = manta@123
In this manta system I created one limited user
User name = server
Password = server@123
In manta server in administrator user, I installed one software in D:\ shree this is shared folder
Means that path is \\ manta\d$\shree\setup.exe
I want access which I given in the path in client system.
But when user runs this software its asking server user name & password
I can’t type or give server user name & password again and again to client .
My mail id is manta4727@gmail.com plz send the answer. Thanking u
Jan 21, 2008 | Broadcom BCM5705 Network Adapter
No access to port 25 for wireless clients
What happens if you connect one of the wireless machines with an ethernet cable? Any chance you have a Firewall of AV program blocking port 25 on these machines? Have you tried Safe Mode With Networking? I'm sure you realize that is most often caused by the ISP blocking Port 25, but I assume they would have told you so if this was the case.
Jun 05, 2007 | D-Link AirPlus DI-614+ Wireless Router
Computers & Internet Logo
76 people viewed this question
Top Pc America Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
sunil dixit
pravintechno
Level 1 Expert
Are you a Pc America Computer and Internet Expert? Answer questions, earn points and help others
