Question about Craftsman 1700 PSI, 1.3 GPM Electric Pressure Washer w/ Steam Cleaner
Steamer wont work
The machine turns on just fine,but when i put it on steam the no matter how long i wait or how many times i press it, the steamer wont work
My compact steamer does not let the steam out when I press the black release button help?
I examined mine. There is literally NO hole in the steam wand for the steam to exit. It's a wonder the thing didn't blow up. Take it back and be glad you still have your face.
Jan 01, 2015 | Top Vacuums
Can not turn on the steam mop
I was able to turn on the steam mop, but no matter how hard I pumped the handle... no steam. Someone here said to put vinegar into the water bottle. I realized that they were saying particles from the water could have formed and clogged the steam tube. First, make sure your steamer is OFF!! Turn the steamer upside down as though you were putting a new pad on, Use a slender object to clean out the tubing where the steam comes from. Again, I will say... make sure your machine is off before you attempt this.. Otherwise, when you clean out the tubing the object will become a bullet flying thru the air and can hurt you, Hope this works
Dec 01, 2014 | Bissell 39W7 Lift-Off Hand Steamer and...
I have an Ariete coffee machine the steamer takes along time to heat up not much steam coming out
if the steamer is not been in use for a ling time is possible tha the valve got stuck. You can try to open and close the steam handle repeating that very often while steam get out. if it does not work try to make a cicle of water mixed with salt, just start the coffe maker, warm up and start WITHOUT COFFEE, you repeat that several time to obtain clean water from the fiter, warm up for steam function and start to open-close the steam handle on the right of the coffee maker body. If that doese not helps you must change or repair the rubinet-valve of steamer, apply to assistence.
Sep 08, 2013 | Ariete Cafe Retro Espresso Machine
Hello The lights on the front of the machine wont stop flashing so I can't press the cup symbols to make coffee. The hot water is coming out though through the steamer spout. Thanks!
Circuit Priming
When the machine operates for the first time and when
all the water has been dispensed, the machine circuit
needs priming. In this case, the 4 buttons of the control
panel will flash at the same time.
• Press the ON/OFF button . The 4 buttons will
flash.
• Place a container under the cappuccinatore.
• Open the "hot water/steam" knob by turning
it anticlockwise.
• Press the hot water button.
• Wait for water dispensing to stop.
• Close the "hot water/steam" knob by turning it
clockwise. Remove the container.
When the first priming ends, the warming up
starts. Before brewing coffee, water and steam,
please wait for lights 15 and 16 to be permanently on.
The machine is now ready to brew coffee and dispense
steam. Please see related sections for operating details.
Note: if priming is not completed, the 4 buttons
will keep on fl ashing. The machine cannot be
used.
Jan 14, 2011 | Saeco Nina Bar Espresso Machine
I have a Krups coffee/espresso maker, with a milk steamer. It makes great coffee and espresso; however, the steamer is not working. It is not clogged; I cleaned the handle with a fine needle, and water...
There must be a blockage in that steam pipe, I think you need to dismantle the machine and remove all of the steamer parts off the boiler and look for the cause of the problem. Oftentimes it will be old hard milk that has been drawn up the pipe and gone hard from the heat. Once cleaned out prevention by blowing a large amount of extra steam through it after each use is the solution.
Apr 22, 2017 | Krups Gusto 880-42 Espresso Machine
The steamer dosen't work at all. When the knob is
First you should remove the end tip of the steam hose and try to clean the steam holes with a pin. The steam should come frealy withou the end tip. If not then you shoul desasemble the steam tap , clean it and put it back together. The problem is only caused by dry milk or milk with chocolate. Even if you manage to have some steam then the problem can be solve by using the steamer warming just water in a glass and leave it all nigh long inside the boiling water in glass this will meld the dirt and will gos away.
Feb 09, 2010 | Rancilio S24 Espresso Machine
I have an electrolux Enviro multi steamer which I was using this morning. I turned the steamer off for approximately 1 1/2 to do some shopping, and when I turned it on again, the steamer light turned on...
Problem fixed itself. Turned off for couple of hours so unit can cool down completely and when I turned it back on it started working again.
Dec 14, 2008 | Vacuums
Steamer
Take off the edge on the steam pipe, clean it and mount it again.
/Mirran
Aug 31, 2008 | Breville ESP8XL Espresso Machine
Craftsman 1700 PSI, 1.3 GPM Electric Pressure Washer w/ Steam Cleaner Logo
52 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
