Question about Pyle PLD10BT 10.1" Touchscreen DVD Player with Bluetooth
How to install a Pyle PLD10BT in a 2006 Pontiac Grand Prix
Connecting wire harness
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Having trouble installing my Pyle PLDBT30U
your part number is Metra 70-5520
It is a standard Ford plug, but is used on your car as well.
Only 1 plug is necessary
See link - http://cgi.ebay.com/FORD-2003-2007-HARNESS-METRA-70-5520_W0QQitemZ170248469364QQcmdZViewItemQQptZCar_Electronics_Installation?_trksid=p3286.m20.l1116
i dont think this model has a premium sound upgrade.... could it be a changer cable?
Posted on Dec 28, 2008
audio20
  • 22 Answers
SOURCE: replacement wiring harness for pyle pld5mu
1-888-318-PYLE Ask for tech support they will sell you one.
Posted on Jul 22, 2009
  • 34743 Answers
SOURCE: pyle pld44mub wiring diagram just bought this player without a wiring harness I need a photo
Request it from Pyle.
Posted on Nov 04, 2016
I have a 2005 pontiac grand prix. I just bought an after market radio. I don't know the what the wires do in the stock wiring harness. i can't figure out which color wire did what function
Well you can start by checking the wires behind the speakers. There are almost certainly 8 of those. Then there is a power wire which ought to be red and a heavier gauge, plus a ground, which should be black.
Or you can just refer to this wiring diagram :>)
2005 Pontiac Grand Prix Car Radio Install Instructions ModifiedLife com
Nov 23, 2016 | 2005 Pontiac Grand Prix
I need a wiring harness diagram for 2006 Pontiac Grand Prix base model stereo system
http://www.modifiedlife.com/2006-pontiac-grand-prix-factory-stereo-install-diagram/
May 25, 2015 | 2006 Pontiac Grand Prix
In cold weather, clock on radio resets and radio cuts on and off
It sounds like your not getting a good connection to your battery. I would try replacing the wiring harness first, (remove radio to gain access.)
Apr 04, 2013 | 2006 Pontiac Grand Prix
How to replace the heater hose fitting for 2006 pontiac grand prix
Drain approximately two-thirds of the brake fluid from the master cylinder reservoir. Lift the rear of the Pontiac Grand Prix off the ground with a car jack. You can read more at http://www.ehow.com/how_4520075_replace-rear-disc-brakes-pontiac.html------------------------------------------------------------------------------------
Launch Creader VI
Feb 20, 2013 | 2006 Pontiac Grand Prix
2006 pontiac grand prix is skipping while driving
It's the CPS (crankshaft position sensor) beginning to fail. The sensor is located behind the harmonic balancer on the lower RH side of the engine. If you look down the accessory belt from the alternator you"ll see a wiring harness leading behind the crankshaft pulley. An easy way to diagnose a faulty sensor is to warm up the engine and carefully tap on the sensor bracket while the engine is idling. A bad sensor will cut out and the engine will stall.
Feb 01, 2013 | 2006 Pontiac Grand Prix
2006 pontiac grand prix base model a/c blower not blowing are at times. When you turn on the a/c you can hear the compressor click on but no fan blowing.
You have a fan blower in the car under the dash,sounds like a loose connection check the blower wires for proper continuity tighten all loose connections
Jun 16, 2011 | 2006 Pontiac Grand Prix
Hello i have a 2006 pontiac grand prix and the temp guage just flatlined
check the temp sending unit to make sure the wire is connected. if so then replace the sending unit. hope this helps
Feb 01, 2011 | 2006 Pontiac Grand Prix
Where is the fuel filter on a 2006 pontiac grand prix gt
Pontiac stopped installing the fuel filter on the rail in 2006. The 2004-2005 models had a fuel filter on the driver's side under the rear passenger seat area clipped to the frame. 2006 beyond the fuel filter is part of the fuel pump unit inside the tank.
May 21, 2010 | 2006 Pontiac Grand Prix
How do i remove ignition switch on steering cloumn of 2000 pontiac gran prix
unless u are familiar with air bag assemblies I suggest u take it to a qualified mechanic..if u accidently touch something wrong u can deploy the bag and cause serious harm to yourself..u have to remove the air bag in the steering column
Sep 16, 2009 | 2000 Pontiac Grand Prix
Pyle PLD10BT 10.1" Touchscreen DVD Player with Bluetooth Logo
44 people viewed this question
Top Pyle Toys Experts
ray gallant
Are you a Pyle Toy Expert? Answer questions, earn points and help others
