Question about Zanussi ZWF1420W Front Load Washer
Zanussi turobodry wdt 1085 door clasp wont open
Door clasp will not open
2 Suggested Answers
apart4u
  • 213 Answers
SOURCE: how to fit a door seal on zanussi washer dryer WDT 1085
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Posted on Jan 19, 2010
Zanussi turbodry wdt 1075 washing machine fills & drains but does not perform wash cycles or spin cycles drum does not rotate
Quite probably the motor brushes. Disconnect from mains. Tilt machine backwards as far as possible. On motor, disconnect wires to brushes. With a multimeter, check continuity between brush and any segment if the commutator. If open circuit, replacing the brushes should do the trick. Also visually examine the commutator for damage
Aug 17, 2014 | Zanussi Washing Machines
Door will not shut
Take a screwdriver and stick it in the clasp on the door and pull them open while pulling on door latch. Take screwdriver and push the clasp open.
Dec 29, 2012 | 1997 Oldsmobile Cutlass Supreme
Door wont open on washing machine zwf16581w at the end of the cycle
The door is designed to stay shut at the end of a cycle usually for about 4 minutes, even if you switch the machine off at the mains. Other than that you probably need a repair.
Dec 17, 2011 | Zanussi Washing Machines
Driver side door wont open from the inside
on most vehicles , on the inside of the door panel the door handle is connected by a long rod that is connected to the main exterior lock and held in place by either a clasp or some other kind of locking mechanism, sounds like it may be seperated inside the door panel.
Feb 24, 2011 | 1992 Oldsmobile Cutlass Ciera
Door will not close the clasp will not open
With the door open and the door unlocked, put a screw driver in the latch on the door. Pull it up and depress the door open handle at the same time. the door latch will return to the open position. Release the door handle button and close the door.
If that is unclear, imagine the llatch to look like a hook that grabs the round metal post mounted on the car door post. the hook is down as if it thinks it is closed so it blocks itself. By getting that 'latch hook to go back up it will allow you to close the door thus resting itself to operate normally again.
Hope that helps.
Jan 16, 2010 | 1994 Acura Integra
Memorex mvdp 1085 dvd player, says door open.
our memorex 1085 doesnt play it just buzzes and has a blue screen
Jan 09, 2010 | Memorex Televison & Video
The interior handle won't open the door anymore, what is the best repair?
The interior handle is attached to the lever that opens the door by a long rod. That rod is a secured by a little plastic clasp that sometimes breaks over time.
You must remove the inner door panel and you may have to fish inside the door to get the rod (sometimes it falls over when the clasp breaks) and replace the clasp. The clasp isn't very expensive at all, and the job of replacing it isn't that difficult.
I hope this helps.
Aug 19, 2009 | MTX T-Form 92-99 Suburban Red incl. 10"...
How to fit a door seal on zanussi washer dryer WDT 1085
Feb 10, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Door wont open
Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Dec 23, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi ZWF1420W Front Load Washer Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
