Question about Toys R Us Tabeo
No command message
When i try to turn it on it just shows me the android robot and the message "no comands".
How do i unlock my nexus 7 when its on the screen with android robot laying on its back?
Android robot laying down with a red triangle having an ...
https://androidforums.com > Forums > Featured Forums > Android Lounge
Mar 24, 2013 - 14 posts - ‎7 authors
Whenever i try to turn my android tablet on it displays android robot laying ... an exclaimation mark in a red triangle and dont let me proceed to its desktop . ... and holding it until it turns off and then turn it back on can revive it, ... no command error ' Android Forums
19 Jun 2014
HELP-Tried Recovery Reboot, Red Triangle w ...
15 Jan 2012
More results from androidforums.com
SOLVED: android guy on his back - Nabi Jr - iFixit
https://www.ifixit.com/Answers/View/349279/android+guy+on+his+back Oct 31, 2016 - my android guy on the screen is laying on his back with the stomache door ... Android recovery mode" and a few seconds later an Android robot ...
How to Fix The Dead Android and Red Triangle Error Symbol - YouTube
? 1:44
https://www.youtube.com/watch?v=58EPvbwPbe0
Oct 5, 2016 - Uploaded by Gauging Gadgets
Meaning of Green Android laying down and a red triangle with an exclamation point inside it: •If there is ... All ...
How to Fix The Dead Android and Red Triangle Error Symbol Android Recovery...
Jul 07, 2017 | Tablets & eReaders
Can u reset ipad if android robot laying down with triagle above it
iPads don't run Android, they run iOS!
you have some lesser version of a tablet, but here is the Android information you are looking for.
How to Factory Reset Your Android Phone or Tablet When It Wont Boot
Jan 17, 2016 | Tablets & eReaders
How Do I Reset an Idolian Studio 10 Tablet that is looping on the Android logo?
The robot dude meant it was loading up the system settings to the next screen so you can wipe off corrupted data that prevents the tablet from completing startup.usually an incomplete update.So
as follows ... Hold power button to switch off tablet....then hold power button and volume up together for at least ten seconds.let the robot appear and do nothing until the menu option comes up to ask you to factory restore.you will lose all your apps and data.if the robot comes on and gets stuck make sure the tablet is fully charged and repeat the two button hold as this may take several attempts.sometimes Chinese technology is unpredictable.
Jan 26, 2015 | Idolian 10.1" Android 4.1 Jelly Bean OS...
Get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Jan 21, 2015 | Tablets & eReaders
I've had several issues but the one now is that all my tablet will do is show a pic of an android laying down with a red triangle on it bearing an exclamation mark. At the bottom of the screen it says NO...
Oct 29, 2014 | Tablets & eReaders
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
Oct 27, 2014 | Tablets & eReaders
How to fix nextbook with no command message
Go online with make and model and search or go to manufacturer web site or find a local service centre and ask there.
Sep 21, 2014 | Nextbook Tablets & eReaders
Zeepad does not open
can't get netflex to show picture.
Dec 29, 2013 | ZEEPAD VIA8650 Android 2.3 Tablet
Where and how i get the android 2.2 os software for download in my fujezone TP700 touchpad tablet?
my android is only showing me an android robot i need the operating system
Feb 12, 2013 | Tablets & eReaders
Tablets wont boot up just shows arnova on screen and shuts down
I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
To access Recovery mode on the ARNOVA 10bG3
To access to the recovery mode:
1. Hold down the volume button + and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
To access Recovery mode on the ARNOVA 9G3
1. Hold down the Home button and press the ON/OFF button.
2. Once the ARNOVA boot logo is displayed, release the Home button.
To access Recovery mode on the ARNOVA 8cG3/8bG3
1. Hold down the volume button - and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button -.
Sep 16, 2012 | Tablets & eReaders
Toys R Us Tabeo Logo
61 people viewed this question
Top Toys R Us Tablets & eReaders Experts
Bill Boyd
andrewcahoon
micky dee
Are you a Toys R Us Tablet and eReader Expert? Answer questions, earn points and help others
