Question about Nextbook Next3 tablet
How to hard reset
When i turn on my tablet it boots up then gives an error on the home screen making me not able to access anything.
My son forgot his password on sophix 740g tablet need to reset or unlock I try to it shuts off turn back on same thing. please help trying to give to a boy who doesn't have one Thank u GOD Bless
You will need to in fact press the following buttons together in order for you to be able to hard reset your device without having to worry about gaining access.
1 Press and hold the home button
2 Press and hold the volume up key
3 Press and hold the power button
From here your device will take you to the boot menu where you can hard reset your device
Jan 07, 2016 | Tablets & eReaders
Frozen reset
If the iPad has frozen on a screen press and hold both the lock and home buttons for about 30 seconds. This will hard reset the iPad and it should then boot normally.
Oct 24, 2013 | Apple iPad 32 GB WiFi Tablet PC
I put a password on my android tablet and now i dont remember the password
Make sure you backup your files by connecting it to a PC (if you have access to one) via USB cable,you will have to do a hard reset, otherwise there is no other way to get past the lockscreen (unless you have a recovery option with your email address)
Below is the process to tell you how you can hard reset your Samsung tablet (should work with any tablet):
  • Ensure that the Samsung tablet is powered off.
  • Press the Power and the Volume Up button together till the device displays the start-up logo.
  • Once the logo is displayed, release the buttons and wait till the device enters the Android system recovery mode.
  • On the displayed screen, use Volume Down button to go to the wipe data/factory reset option (Volume Up and Volume Down buttons are used to highlight the displayed options on the Android system recovery screen).
  • Once the option is highlighted, press the Power button to select the option. (Pressing the Powerbutton in Android system recovery mode selects the highlighted option.)
  • On the next screen, press the Volume Down button multiple times till the Yes -- delete all user data option is highlighted.
  • Press the Power button to hard reset the Samsung tablet device while clearing the dalvik cache along with the process.
  • Once your device is hard reset and rebooted successfully, you will see that the unlock pattern obstruction is also gone, and you can now set a new unlock pattern on your Samsung tablet.
Oct 21, 2013 | Tablets & eReaders
Tablet wont boot into anything but screen with horizontal lines..just got it today and charged battery and now i get nothing?
Holding the power button down for 10-15 seconds is considered a hard reset on most tablets. If it still won't load you can try doing a factory restore.
  • Make sure the tablet is powered off
  • Briefly tap the power button once, then hold the power button and volume down until you get the boot menu
  • There should be an option to factory reset or something to that affect
Dec 08, 2012 | Tablets & eReaders
Tablets wont boot up just shows arnova on screen and shuts down
I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
To access Recovery mode on the ARNOVA 10bG3
To access to the recovery mode:
1. Hold down the volume button + and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
To access Recovery mode on the ARNOVA 9G3
1. Hold down the Home button and press the ON/OFF button.
2. Once the ARNOVA boot logo is displayed, release the Home button.
To access Recovery mode on the ARNOVA 8cG3/8bG3
1. Hold down the volume button - and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button -.
Sep 16, 2012 | Tablets & eReaders
Disgo is frozen on home screen and home icon keep flashing i cant do anything
Search google to do a hard reset, I had the problem and after doing a hard reset it helped me and my tablet is working fine now. I don't really remember which keys it was but there are three keys to keep pressed and after that it will reset your tablet and if everything is ok it should work perfectly after that.
It would be nice if the manufacturer would also put that in the manual, because when I received my tablet I had to calibrate the screen and that didn't really help me. Also the tablet was working really slow and took a lot of time for everything, plus the fact that the keyboard kept pressing all sorts of other keys then that I wanted to press.
I hope this will help you and that your tablet will work fine for you.
Let me know if you had any success.
Sep 08, 2012 | Disgo Tablets & eReaders
Nextbook Next3 tablet Logo
35 people viewed this question
Top Nextbook Tablets & eReaders Experts
D. E. Hev
Tom
Dustin
Dustin
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
