Question about Rheem 4 Ton Air Handler - RHLLHM4821JA
My air handler fan does not come on, the outside unit turns on fine. Is their a way to reset the fan?
Had a power outage last night and the unit turns on outside and the coils in the air handler freeze so its just the inside fan that does not kick on...Is their a way to trouble shoot this?
  • Rheem Master
  • 1,253 Answers
Check for fan operation by turning the fan control at the thermostat to "on". If the fan blows, it works. If not, check a circuit breaker or fuse.
If the fan blows when forcing it on with the thermostat but not in automatic, check the fan control circuit in the air handler. Danger: high voltage, beware! There should be a system wiring diagram inside the air handler somewhere.
Posted on Mar 30, 2014
I have an older trane twe030c140b0air handler and it was workingq fine then today froze. Fan in unit will not run. Sparks from conteoller. Is that the correct name? Unit is 208 thanks
Turn power off to air handler. Jump red and green inside the machine. Turn power on. If fan runs then the problem is likely outside of the machine, that being tstat or tstat wire.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 17, 2017 | Heating & Cooling
My outside A/C unit is not coming on
might be it is relay problem in pcb. Pls check the cord then relay by a technician,
Oct 14, 2013 | Goodman Heating & Cooling
I have a Ruud heat pump/air conditioner. The out side fan and unit works fine and cools fine but now the inside fan that blows the cool air in will not turn on. We can turn the fan with our hand so I don't...
You didn't mention if you checked for 115 volts at the power supply to the air handler. The unit outside has its own power supply. A lot of times the switch that is on the wall doesn't like to work after its been turned off and back on for service, also check the blower door safety switch. If the blower door hasn't been put back in place properly and snugly it will kill power to the whole air handler. Hope this helps. Good luck
Jul 31, 2013 | Ruud UBHC Air Conditioner
Goodman compressor not running after power outage
no reset replace capacitors. check terminals on compressor to see if a wire burned off
Jul 31, 2012 | Goodman Heating & Cooling
Unit exactly one year old. Was interruped by lightning strike last night. Afterwards air handler blowing, but not cooling? Turned unit of at temostat, waited a few minutes, turned back on and unit (both...
Marion, if there was a lightning strike and then a power surge when the power came back ON, I don't doubt what the servicemen had to say. The age of the unit plays no role in it, when something like this happens. Power surges can be killers to electrical appliances. That's why it always wise to turn the unit off during a power outage. Just ask anyone who was in Irene's path a couple of weeks ago. Power went out for days & weeks for some, when it came back ON, electrical appliances were damaged or ruined or started house fires.
Hope this helped you and thanks for choosing FixYa.
Sep 19, 2011 | Amana Heating & Cooling
Our air conditioner stopped cooling last night. The fan runs. My husband pushed the reset button on the outside unit but didn't know if he is supposed to keep it pushed in or just push it in quickly or...
If it is a split unit this is a unit with a furnace and air handler inside with the condensing unit outside. If your inside fan is running ck your outside fan and seeif it is running. If it is it is probably the wires to the capacitor or the capacitor its self. Some capacitors have 3 wires this is a dual capacitor with a 5uf for the outside fan and a 35up for the compressor. on some there are two seperate capacitors one 5 one 35 uf. also it could be the wirng to the capacitor they will be melted and chared. all of this is located in the outside unit where the elect wires go into the unit you can removethe shell but first disconect the power there should be a disconnect switch near the unit. if not trip the breaker. be carefull with the elect.
Aug 08, 2010 | Ruud UBHC Air Conditioner
Outside unit will not come on
Check the starter capacitor, and di you remember to add oil?
Aug 27, 2009 | Goodman CLQ36AR49 Air Conditioner
Air conditioner compressor runs for about 1-2 min, then cuts off
well when u have outages the voltage drops obviously, the one that suffers are the capacitors the capacitor for the compressor might need to change, change it with the same capacity as the old one example if labels say 55 microfarady ( mf ) ( 55 mf ) get one of the same I am not saying it is a 55 mf capacitor vary depending on motor and brand. So check the label
Jul 23, 2009 | Danby Portable Air Conditioner
RUDD A/C not running, only fan
ok it unit is a central I'm suspecting a voltage transformer is defective you see these units need 24v to turn on certain components but if your air handler turns on, your getting 24v to the fan relay, the problem would be elsewhere. if your handy with a volt meter open the thermostat(if applicable) put the meter on ac volts and measure to see if there's 24v between the R and Y terminals
if so your cooling contactor is defective. (If you get 24 v and unit outside dosen't turn on) if there isn't some fuse on the air handler control board blew out.
you can e-mail me @ hvac.tech7872pr@gmail.com if you need more info
Jun 16, 2008 | Ruud Heating & Cooling
Rheem 4 Ton Air Handler - RHLLHM4821JA Logo
298 people viewed this question
Top Rheem Heating & Cooling Experts
jeff5may32
billconfused
Lawrence Oravetz
Are you a Rheem Heating and Cooling Expert? Answer questions, earn points and help others
