The condenser is leaked
My Room Air conditioner model KC-15P have a problem of the condenser which is leaked
  • 1,249 Answers
Time for a new air conditioner.
Posted on Mar 30, 2014
  • 105 Answers
SOURCE: Water leaking from portable air conditioner
First, make sure the unit is level. If so, you have a blockage or kink in the drain tube. Careful inspection should reveal any blockage, & you may be able to poke it thru with a piece of coathanger wire. Don't use excessive force, any block should be easily freed.
Posted on Jul 15, 2007
  • 105 Answers
SOURCE: Fujitsu wall mounted air conditioner leaks into the room
Make sure the unit is level, this is very important. Check for blocked drain tube, which runs from the bottom of the drain pan under the cold coil to the outside. Clear tube with a piece of coathanger wire, be gentle.
SOURCE: Fujitsu wall mounted air conditioner.
Is it a split system? I had the same problem with my split system and and it was because the condenser line was mounted wrong. The line was mounted so the water had to go uphill and it was causing the condensation to leak through the front of the unit.
Posted on Aug 14, 2007
  • 166 Answers
SOURCE: sharp air conditioner portable leak in bottom
You mean it's leaking around the AC's unit base? If so, here's a handy diagnostic article that specifically addresses this problem of yours, explaining the probable causes and solutions, a solution that may very well have to do with the condensation pump's malfunction or just debris blockage, among other things: http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Creates_Water_Puddle.htm This article should set you on your way! Good luck! Brad
Posted on Jun 13, 2009
  • 82 Answers
SOURCE: coleman tsr rv air conditioner leaks into rv when running
It probably has a clogged condensate drain. Take off the cover on top the RV and check hoses or tubes leaving unit for debris or lint. Often this water is used to help cool the condenser so look for leaves pine needles etc in the pan. There may be a cover you can remove on the evaporator section that will allow you to clean the collection pan and hose or trough. Is it possible the RV is far enough out of level that the condensate can't "run uphill"? Always power off while working on this unit unless you are electric savvy. Good luck!
Posted on Jun 28, 2009
Hi, I have an air conditioner Frigidaire which is leaking in the front. The unit is in a window, in a 4th Floor and I don't have access to the back, how can I unclog the unit??. I am desperate!!!!
if it's just condensation leaking out the front of the unit it could be that the unit is not level in the window. If it's tilted too far into the room it will leak condensation into the room. Try to tilt it back just a hair so that the condensation leaks out the back of the unit.
Sep 02, 2013 | Frigidaire Heating & Cooling
I have the LG LP1200DXR and it is leaking near the wheel and i cant figure out why, when we drain it no water comes out what could the problem be?
All air conditioners collect condensate. It has to drain somewhere. Try connecting tubing to the drain hole or port. In order for air conditioners to remove heat from a space, they also remove humidity, which is water vapor in the air. Like placing a cold beverage in a warm room, it will form condensate (water) around it. The water that you were trying to drain out already leaked out. This is a normal thing for condensation to form when cooling. The condensate needs to be emptied regularly or piped with flexible tubing to a window or plumbing.This is the same as water dripping from your car while the A/C is on.
Aug 30, 2013 | LG LP1200DXR Portable Air Conditioner
Brand new kenmore air conditioner 18500 btu, there is no place for the water to drain, no drain plug? water is getting high... model 70181
The new Room A/C's do not have drains as it uses the condisation from the pan to help cool the coils this makes the unit more effecient.
Sep 01, 2011 | Kenmore Room Air Conditioner
The AKAI Asplet air conditioner does not cool my room
Your condenser may be dirty and the evaporator coils should be cleaned there may be inadequate air flow around the condenser. if there is a leak, your unit may be out of refrigerant you might have a leak in your duct system.Contact an aircon technician to clean and refill the freon and it will be cold as new.Thanks
Jan 25, 2011 | Sanyo Heating & Cooling
Amcor AmcorAire UCHW-H12AF2 Split System Air Conditioner leaks water in side the room. after the drain hose was change and clamped.
I had the same problem. The insulation on the coper line was loose and the pipe was exposed. The water was condensation , not water from the drain.
Aug 25, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Black & decker room air conditioner condensation problems
I own this a/c and netnut71 is absolutely correct. You will not see most modern window a/c units drip condensation. They recycle through for cooling purposes. We even have one window a/c we nicknamed "Mr. Slurpy" because he's the loudest. :)
Aug 02, 2010 | Heating & Cooling
No more condense water outside, leaking heavy inside the room from the bottom of the handler
Take a shop vac and **** the pipe out from the outside. You have a blockage in the condensate pipe.
Nov 08, 2009 | LG LS-K2430HL Heat Cool Mini Split Air...
LEAKING ON THE INSIDE OF THE HOUSE
There is an outlet to allow condensed water to flow outside the house from the AC unit runs. Please check whether there is any dust block in the tube and once you clean it water will flow out and not into the house. Sometime the garden lizard or flycatcher could get into the drain pipe and got stuck and block the outflow of condensed water.
Please ensure that the window air conditioner is installed in such a manner the out side portion of the unit is slanted or tilted to the back so that the water will run out and not into the room. By providing some pad to the front portion of the unit the above could be achieved and condensed water will not flow into the room.
Jul 08, 2009 | GE AJCQ08ACB Air Conditioner
Air conditioner is leaking on the floor
Hi! siswebster7
Is this a window or wall unit. If so the unit is not tilted so the condensation can run away from the room, or the condensation drain is pluged.
InMrFixIt
Jul 28, 2008 | DeLonghi Heating & Cooling
Jun 03, 2007 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
