Question about Bosch Dryers
My Bosch Nexxt 500 does not dry the clothes. The dryer heats up and their is good ventilation. It runs about 35 minutes then shuts off with the clothes still wet.
I ahve cleaned the sensor with vinegar and cleaned all of the duct work inside and out.
  • 50 Answers
The lint screen may have a film on it from fadric softner wash it in hot water rubbing it lightly.
Posted on May 04, 2014
4 Suggested Answers
SOURCE: Bosch Nexxt 500 gas dryer takes a long time to dry
Did you ever figure this out? I have a new Bosch and can't get the clothes to dry.
Posted on Oct 07, 2010
SOURCE: Bosch Nexxt 500 Dryer -- Permanent press cycle not
Same problem here
  • 3074 Answers
SOURCE: GE Profile Dryer Auto Cycle
below the lint trap is a sensor, clean it off gently as not to damage it, this will fix the problem
Posted on Mar 13, 2011
Bosch Nexxt 500-series electric dryer problems - Dryer never finishes complete cycle of drying clothes. When attempting to restart, the display will show 20 (mins) even though I've pushed something di
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Mar 12, 2014 | Bosch Nexxt 500 Dryer
My Bosch Nexxt 500 dryer keeps tripping the hi-limit cut out.
Try checking your exhaust vent pipe for excessive bends and kinks, make sure there is good strong airflow coming out the exhaust where it exits the building.
Dec 12, 2013 | Bosch Nexxt 500 Dryer
My Bosch Nexxt 500 dryer is TOO HOT.
You need to take care of this right away. Too many houses catch fire from lack of maintenance on dryers. Pull it away from the wall and unplug it. Check the inside of the duct work and clean it out. Then check the inside of the drier connection too. Run it without the duct connected and see if you have good air flow.
Jun 16, 2013 | Bosch Nexxt 500 Dryer
Dryer drying to hot
Check the fan is running, and the filter is clean
Dec 28, 2012 | Bosch Nexxt 500 Dryer
What could be a cause of water leaks from Bosch Nexxt 500 gas dryer?
Since there is no water lines connected to a Bosch Nexxt WTMC 6500 gas dryer, the water leak has to be from excess water from the clothes you are trying to dry. Which is probably more the problem.
Does your washer leave an excessive amount of water in the clothes after the spin cycle?
Jun 04, 2011 | Bosch Nexxt WTMC 6500 Gas Dryer
On my Bosch Nexxt 500 Series Electric Dryer keeps shutting off and gives the E-01 error we have check the exhaust air duct on back of the dryer and we have vacuumed the inside bearing shield what else...
Motor won't work
Lint screen hi-limit (thermal cutout) tripped.
Clean lint screen and clean lint and other debris from front shield, then replace hi-limit. Also check exhaust duct length & # of elbows.
Wire harness failed.
Run resistance or continuity checks to track down broken wire or connector. Replace failed wire harness.
Display shows "E:01" during drying.
Lint filter, air duct or air damper is blocked.
Air leaking past felt drum seal.
Air duct is too long, too small or has too many bends. Inadequate ventilation around dryer (i.e. in a closet).
Clean out filter, air duct and air damper.
Replace felt drum seal. If seal doesn't fit snugly onto drum, wet felt and dry it by running a timed dry cycle for 20 minutes (felt will shrink and fit drum snugly).
Shorten, enlarge, reroute and reduce # of bends in air duct. Move dryer to an area
Jan 09, 2011 | Bosch Nexxt 500 Dryer
Does not dry thoroughly
Clean out the entire exhaust venting system. If a build up of lint is inside of it the moister sensor shuts down the heating process causing the time to take to dry clothes seem forever
Jun 13, 2010 | Bosch Nexxt 500 Dryer
if you use fabric softener sheet,there is two small metal chrome stip take a wet rag clean them off,they are locate on the in side of dry drum close to dry grill on inside,those sheet can leave a film on those stip are your sensor for the auto cycle on the dryer
Apr 24, 2010 | Bosch Nexxt 500 Dryer
Dryers Logo
107 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
