Question about KitchenAid KEMS309BSS Combination Microwave Oven 30"""
Kitchenaid KEMS309BSS Combination Microwave Oven light in Microwave does not work.
The light in the microwave portion of my combination oven does not work. I have searched through the manual to find out how to replace it but I can not find anything. Can you please tell me how to replace the light?
MicrowaveSvc
  • 9047 Answers
SOURCE: internal venting of KitchenAid Microwave oven hood combination
That info is in your installation instructions, which can be found here.
Posted on Jan 03, 2009
SOURCE: Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Posted on Mar 26, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave lamp burn't out
You can find owner's manuals (which would cover any user-replaceable lights if present), installation instructions, and parts list, which have helpful exploded view diagrams here.
You can order parts here.
Posted on Jun 30, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Display panel (right side) on
The first thing I would do is a hard reset (simply unplugging it for a couple of minutes) if that has not been done already.
Then one would need to retrieve the technical sheet (mini-manual) found behind the control panel assembly.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here. Just enter your model number from the tag on your unit.
If a reset won't fix it, I would bet there is a loose connection where one of the boards connects to another, or some contamination from grease or steam, etc., at one of those connectors.
A lot of time one can unplug then reconnect the connector, and that will clean it. Or one can unplug the connector and clean the contacts with a soft pencil eraser.
Posted on Sep 26, 2010
  • 2069 Answers
SOURCE: Problem with the KitchenAid 30
well i will give you a link to suggestions that have already been made by other experts on Fixya. click here
otherwise,
A. Unplug oven or disconnect power.
B. Open the back panels and make sure the P6 and P2 connectors are fully
inserted on the appliance manager and on the lower oven user interface board.
- If they are not plugged in, plug in connectors and go to step F.
- If they are plugged in, go to step C.
C. Visually inspect all wires between P6 on the appliance manager and P2 on the
lower user interface.
- Make sure wires are not cut or pinched.
- If the wires appear to be intact, perform a continuity check between
P6-1 of the appliance manager and P2-1 of the user interface board.
Posted on Mar 09, 2011
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Runs 20 sec stops reads F1E5
Error Code/Message - Oven - F1 Error Code - F1 E5
Control displaying F1 E5:
There may be a problem with the Oven Control, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Oct 23, 2015 | KitchenAid KEMS309BSS Combination...
WHEN I SUBMITTED MY PLEA FOR HELP TO GET A MICROWAVE USER/OPERATOR MANUAL, I WAS ASKED: WHAT MAKE IS IT?
that model is from the uk,you need to search over there for it,i just searched for an hour and come up with this, Accumetrics Inc Announces United Kingdom Distribution Agreement With...
22l is how much it holds,not the model number,Elitech commercial grade steam oven/combi grill - in VGC - not used a great deal, but a very handy addition to any kitchen at busy times!
Voltage - 220-240 V input 1650 watt when on steam mode, 1250 oven/grill mode.
Dimensions 220x315x312 mm
Manual available online to download - (Ref Elitech EA053747)
Capacity 22L Instruction Manual Copy ELITECH Steam Oven Combination Grill Model Ref...
May 11, 2015 | Microwave Ovens
Sorry but this is actually a combination microwave/oven and not a mobile phone. I need the user manual in English.
Google search manufacturer make, model and manual. If one is available, you can download it from the search results.
Apr 16, 2015 | In Microwave Ovens
I have Kitchenaid Combination wall Oven and Microwave Model #KEMS308SSS and my microwave runs fine but dose not heat any thing and starts cooling for few mins
I have the same problem with a KEMS378 KitchenAid that is only 11 months old. Gettign warranty repair Monday...So can let you know...
Jun 20, 2010 | Microwave Ovens
KitchenAid KEMS309BSS Combination Microwave Oven 30""" Logo
59 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
