Question about Drills
Jcb hammer drill cutting out
My jcbd-hd1010f keeps cutting out when in use any ideas why
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 142 Answers
Bad power cord? Brushes getting low?
Posted on Apr 22, 2014
  • 2712 Answers
SOURCE: hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Posted on Aug 27, 2008
SOURCE: which type of oil goes in the chuck of the jcb
use 3 in 1 oil, its light and wont hold a lot of dirt or gunk. easy to clean chuck and reapply
Posted on Jun 13, 2009
smjdragonfly
  • 79 Answers
SOURCE: Hammer drill will not hammer.
Need a new clutch/tranny. You can find it online - look up tool parts on Google. Tool Parts Direct is a good source. Please rate me
Posted on Jun 18, 2009
  • 5 Answers
SOURCE: Require manual for JCB RHD 950 Rotary Hammer Drill
try choiceful.com.au
Posted on Oct 10, 2009
emissionwiz
  • 79865 Answers
SOURCE: Dewalt dw511 hammer drill won't hammer, only
The hammer inside the drill head are most likely damaged ans/or broken, it is likely the best thing to do is just replace the tool.
Posted on Feb 16, 2012
JCBD - HD3 Hammer Drill. The lock button is stuck on, cannot switch off, have to take plug out of socket
hi john.
sounds like the switch will need to be looked at, so it will need to be opened up to see why this has got stuck.
Nov 05, 2017 | Cars & Trucks
Jcb sds chuck repair
Allways In a bench vise not allways a demolition hammer has a chuck but most times a locking sleeve for sds but allways you can remove it .
Apr 30, 2014 | Hammering
The switch in my JCB cordless drill is starting to die. The rest of the drill is perfectly fine, motor etc. I have tried calling th JCB support number, however they were no help. Any ideas where I can...
Before you look for a replacement of switch try first to checked the connections of switch if it is OK,then try to cleaned the contact with it.,If you are know how to used a tester try to checked the continuity of the switch, by placing the test probe of the tester to the 2 wire of the switch then from the tester select sound continuity,(one test probe to one wire) it should hear a sound from the tester,it means the the switch is good. Hope this simple solution could help to solve your problem. Don' t forget to rate me up sir/madam.Thanks.
Jun 12, 2011 | Drills
My JCB 18V cordless drill is not working when you press the trigger. The battery is fully charged any ideas please.
It's probably the switch; mine judders and works kind of. Slight burning smell coming from it, dismantled it to discover that the switch has started to burn out, so far no luck finding a replacement.........
JCB are totally useless, no help from their support phone number!
Sep 15, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
I have a dewalt 18v cordless hammer drill but for some reason while drilling the drill does not spin as fast as it used to batteries are fine just the drill any ideas
depends on where you drilling- wood - no hammer option needed- fast, metal- no hammer option needed- also fast, but it is concrete- sorry- hammer option needed so it will always drill slower, and drain your batteries way faster (have a spare one ready).Speaking about drilling - don't drill for too long with no breaks to cool them down, always keep an eye on gun's and battery's temperature- even if it is new Lithium NANO, do not let them overheat.
BTW- what model is yours? Is It SDS hammer drill sort of DC212KL?
May 19, 2010 | Dewalt 18 Volt Compact Drill Kit
Which type of oil goes in the chuck of the jcb
Jun 10, 2009 | Drills
Drills Logo
90 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
