Question about Briggs & Stratton Garden
Westwood 1300s red hot exhaust
The exhaust from manifold glows red hot , almost looks as if flames are coming from it . Burning far too hot . Help!
  • Briggs & Str... Master
  • 2,478 Answers
Get carb. adjusted, way to rich.
Posted on Mar 30, 2014
Glowing red exhaust pipe coming off of manifold in 2000 Lexus ES 300
That is caused by an over fueling condition, you need some testing done.
Dec 08, 2016 | Lexus Cars & Trucks
2005 ford focus manifold get red hot and motor shaking
A glowing red manifold usually means a lean mixture, which causes a hotter burn, hence exhaust manifold glows red......you havent stated inlet or outlet so i went for the obvious...
Nov 29, 2016 | 2005 Ford Focus
Husq 125b starts great! & runs 5 min, exhaust glows cherry red hot and engine is now at 50% or less power. Exhaust is not clogged; fuel ratio is correct....???? :(
ignition timing is incorrect or valve timing (if 4 stroke) is off
ignition timing is too far retarded and if 4 stroke , the exhaust valve is staying open too long ( tappet clearance )
the indications are that there is compression flame escaping into the exhaust when it should be out
Nov 12, 2016 | Cars & Trucks
Catalytic converter
The exhaust downpipe is glowing red with heat?
To be honest, that may be fuel-air /and or cylinder head problem. A downpipe gets very hot, yes, but they don't glow red.
A faulty oxygen sensor can cause the catalytic converter to overheat - with disastrous results.
If you're not sure what you're doing don't mess around with things. get somebody who knows what they are doing to look at your car and give you an opinion
Feb 17, 2016 | 2006 Nissan Sentra 2.5
What would cause the elbow and manifold to get red hot in minutes on my 2004 Ski-doo elite under normal driving conditions? Could it have blockage in the muffler?
Blocked muffler will cause extreme reduction in power. When you say red hot, do you mean it glows red or it is very hot and you will burn your hand on it? The latter is normal, you cannot touch an exhaust system within a minute of running. Cherry red sounds abnormal. Engines putting out maximum power can have glowing manifolds but not average power. Make sure the timing is correct and do not use gasoline with an octane rating that is too high. Higher octane fuel burns slower. If it is still burning when the exhaust valve opens, it will continue to burn in the manifold. Use the gasoline recommended in the owners manual.
Feb 14, 2015 | Winter Sports
Exhaust glows red hot
That means you are sending raw fuel into the exhaust, likely due to severe misfire. That will destroy the Catalyst in short order too.
Sep 14, 2013 | Nissan Cars & Trucks
Exhaust manifold and pipe glowing red hot hyundai accent 97
Exhaust Glowing Red Hot
Start over--you do not have the timing
belt on correctly
Dec 06, 2012 | 1997 Hyundai Accent
2007 Honda 919 exhaust pipes red hot
Hi, Sandy and the usual suspects are:
1. Retarded ignition timing.
2. Retarded cam timing.
3. Bent or burnt exhaust valve.
4. Massive air leak.
5. Intake manifold cracked or damaged.
6. Intake manifold seals have failed.
7. Wrong heat range spark plug.
8. Fuel delivery system running too lean.
9. Faulty Map, O2, MAF, TPS, sensors.
10. Faulty advance mechanism.
11. Faulty VOES switch.
12. Aftermarket exhaust headers tubing too thin.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Exhaust glowing red
http://www.motorcycleforum.com/59-motorcycle-repair/97882-immediately-red-hot-exhaust-pipe-header.html
Honda CB900F Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB900F Owner Manual
Sep 14, 2012 | 2007 Honda 919 Base
Garden Logo
111 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
