Question about Kenmore 51lb. Clear Ice Maker
I have a kenmore under counter ice maker that will not cut ice on twice ice. Works ok on regular setting. Replaced cutting grid already. Any suggestions?
Model 10689482993
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Check to see if your getting voltage to the grid during twice ice sounds like a switch problem
Posted on Apr 07, 2014
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: we have a kenmore elite
Nickle guard is what you should use. Also you should clean around the compressor. Blow out the condenser. I have a service manual for you:
CLEAR ICE MAKER TECH MANUAL
Posted on Jan 26, 2011
TheMobilian
  • 8220 Answers
SOURCE: Free standing ice maker not functioning
Have you got a slow flash or fast flash?
A slow flash is a problem with the sensor.
A fast flash is dirty condenser failed condenser fan.
See page 16
Posted on Mar 15, 2010
Testimonial: "Thanks for your suggestion"
Ge monogram icemaker ZDIW50YB not cutting ice
Is the cutting grid getting warm if just warm make sure you don't have any loose wires supplying power to grid. Check grid cutting transformer to make sure it is working. make sure grid is clean. If you are getting power to cutting grid and it's not getting warm then cube let cutter grid is bad. If this needs to be replaced you might thank about a new machine the cost for this part is around 480.00 part number AP2068335
Aug 22, 2014 | GE Monogram ZDI15C Automatic Icemaker
Ive just put a new grid cutter in my whirlpool ice maker but it is not heatinh up to cut the ice sheets into cubes. Any ideas what to do next?
Yes the next step is to check the voltage on the secondary side of the grid transformer found in the photo on page 30 of the=> 15 and 18 inch Whirlpool Ice Maker Service Manual
GI15NFLXS Grid Transformer
I hope the manual is a big help in resolving the ice cutting problem and please ask should you have any questions. The secondary side of the transformer should be showing a least 8.5 volts ac. Let me know if you are able to find the problem, Thanks Sea Breeze
The 18 inch ice maker takes the same grid transformer as the 15 inch model.
Mar 15, 2013 | Whirlpool Refrigerators
Ge monogram zdic150 ice maker cutting grid does not get hot enough to make cubes
If the cutting grid is only getting warm this would indicate a loose wire, a dirty grid or a defective grid transformer. As much as these grids cost it would pay to search for the problem that is causing this. The transformer is near the control board=> WR62X10015 Transformer
Other source for a transformer=> WR62X10015 Transformer If you would like my help repairing the Ice Machine please let me know, Thanks Sea Breeze
Mar 08, 2013 | GE Monogram ZDI15C Automatic Icemaker
Whirlpool icemaker
If this an under the counter ice maker the machine is going to run water all the time with the exception of when the ice slides down to the cutting grid to be dropped.
Sep 05, 2012 | Refrigerators
Have kitchenaid undercounter ice maker, came with the house i bought a year ago. the problem is the water freezes in the resevoir. i have replaced the circulating pump, the thermistor, some sensor,...
on the right side of the ice bin and above the cutter grid are 2 sensor plugs, unplug the one towards the rear of the machine (usually has light brown w/red striped wires). if this does not fix the problem then replace the main control board and the transformer. Also the water doesn't go to the grid, it rolls across the evaporator, freezes a slab of ice that then slides down to the cutter grid. the cutter grid should be somewhat warm, it is what cuts the ice into the little squares. I've worked on these machines for around 7 years now and have only seen this problem once, this should fixya
Mar 02, 2011 | KitchenAid KUIS18NNT 18" Automatic Ice...
I have a viking undercounter ice maker Model VUIM 150 DRSS. The ice maker makes a heet of ies and then it looks like it "slides down" to a grid of wires which the weight of the ice causes it to split into...
The grid of wires (i.e. cutting grid) is supposed to be powered at the start of the "harvest cycle" I believe that unit has a 12 VAC transformer to power the grid. Either the grid has a broken wire, the transformer is bad or something is not letting power travel from the transformer to the grid (like a loose wire). If you have a multimeter you can test the grid for proper resistance which should be 5.0 to 5.9 ohms. Make sure you take the proper precautions to disconnect power from the unit before disconnecting the cutting grid to test it. I believe it is plugged into a recepticle on the side of the unit. If the grid checks out ok, you can test the recepticle for voltage...it should have power up to 35 minutes after the start of a harvest cycle. If you shut off the water supply and pull the reservoir plug, you can turn on the ice maker and have it "dry cycle" to test it's functions. It should be able to pull the evaporator plate (the cold plate) down to harvest temperature (11 degress F) in less than five minutes when there is no water flowing accross it. I hope this helps.
Jul 10, 2009 | Refrigerators
Under counter ice maker water pickup problem
Most likely your plastic curtain is not keeping the water in the sump area. ( I'm assuming it makes round cubes)? Look under the sump for any dripping if its a pretty steady drip replace your water curtain and the holder that's with it.
If you have a cutting grid type ice machine this is all together different and I need to tell you separately about that.
Jan 01, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
Ice jams in KUIS18NNJB Kitchenaid under counter ice maker
There are 2 sets of wires on the cutting grid that are perpendicular to each other. Electrical current passing through the wires creates heat that melts the ice. The first set cuts one direction, then the ice strips drop onto the second set that cuts the strips into cubes. Remove the cutter grid and check if the wires are broken. If they are, electrical current can't pass through the wires, so no heat. Restringing kits are available to fix this. If the wires aren't broken, you'll need a voltmeter to see if current is reaching the wires. If it isn't, then the transformer has likely failed.
Dec 13, 2008 | KitchenAid KUIS18NNT 18" Automatic Ice...
Kenmore 106.53552201
refrigerator works for a day and then quits working
Feb 04, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore 51lb. Clear Ice Maker Logo
93 people viewed this question
Top Kenmore Kitchen Appliances - Others Experts
Charles T Nevin
Charles T Nevin
Sal DeAngelo
Are you a Kenmore Kitchen Appliances - Other Expert? Answer questions, earn points and help others
