Question about Other IO-920HR - iGlasses iO-920HR High Resolution 3D Headset
Broken left hdmi socket and minijack. Can I get a spare parts?
I HAVE i-Glasses 920HR And there is not working. I opened them and the plugg for mini hdmi are broken. Can I order spare parts for my i-Glasses? This is just small plate that pluggs in the glasses.
  • 210 Answers
I dont think you can buy a spare mini port ,i would try ebay for a spares or repair of the same model and use the charging port to fix your own
Posted on Mar 30, 2014
Having problems connecting using RCA cables (TV to Sound Bar) - No sound on Sound Bar
I assume by using your phone (cable rca to mini jack) the sounbar functions normal. Next time give more info like tv and soundbar make and model no and what connections are available on both components and if its input or output connections.
On the tv make sure the rca cable (tv to soundbar) is plug into the stereo output of the tv and not in a av input. Some tv's have a mini jack out and not rca. Some have a earphone socket which could also be used.
Some tv's only have a digital or optical output port. Iin basic sound work and can be connected with the following combinations .
Minijack to minijack
Minijack to rca
rca to rca
digital to digital
optical to optical
Oct 26, 2015 | RCA Televison & Video
Replacing minijack
I use a multimeter to check the connections to the ear pieces. I set it to the diode function. The meter's test probes also have a very low dc voltage and this causes a 'click' sound in the working earpiece. Some earphones have 3 wires, others have 4 wires. In the 3-wire setup, one wire is the common wire. It goes to the ground connection of the mini plug. The 'click' sound on the left ear piece should go to the tip of the connector. The 'click' sound that you get on the right ear piece should be soldered to the 'ring' of the mini plug. The 4-wire type of earphone/ headphones cable usually have two wires that are the same colour. These are the ground or common connections for both right and left. I hope that this helps. A multimeter or vom is a necessity. Len.
Apr 11, 2014 | Klipsch Image S4a black For Android In-Ear...
Minijack color scheme wiring
copper wires get tied together and go to the ground lug, red and white go to the other two pins. will work either way or swap red and white for proper left and right ears.
Jan 15, 2014 | Altec Lansing Audio Players & Recorders
Hi: Have a pair of Oakley Nanowire 1.0 Brown that have a nosepad broken off in the middle. It appears to me to really need a whole niew middle part in place. Is this something you can do?
Good brands give a warranty and in case of a damage you bring the glasses to the optician you have bought them from. He will contact the producer, order the spare parts and repair the glasses for you.If the warranty is still valid you get this for free. If there is no warranty anymore you can ask for an estimat of cost for the spare part and repair, so that you can decide whether or not its worth the money.( maybe if the glasses are already quite old)
May 12, 2011 | Oakley POLARIZED OAKLEY NANOWIRE 2.0...
My sansung pn50a460s4dxza says it is 3d ready. how can i use this feature on my tv.
Your tv is a 2008 model, legacy 3d tv and requires a lot more than a current 3d HDTV does to view 3d. Today with a current 3d HDTV, Normally you only need a 3d source like a 3d Bluray movie and 3d glasses from Samsung and a HDMI cable connection from bluray player to HDTV. See below for your TV. You need a PC and IR emitter and Samsung 3d glasses plus user selected options on the tv.
Samsung 3-D Ready HDTV How do Samsung 3-D Ready HDTVs work?
Samsung 3-D Ready HDTVs are enabled by Digital Light Processing (DLP(R)) or Plasma Display Panel (PDP) engines that are capable of very fast refresh rates (120Hz). The inherent speed of these display technologies enables high quality stereoscopic 3-D by alternatively displaying left and right eye images. The display is synchronised with 3-D shutter glasses to provide the observer with a vivid perception of depth.
How do I connect my PC to a Samsung 3-D Ready HDTV?
The DVI output from the PC's graphics card must be connected to the TV's 3-D compatible HDMI port using a DVI-to-HDMI cable (or a HDMI cable plus a DVI to HDMI adaptor).
Alternatively, some newer graphics cards have a HDMI port instead of a DVI port. In this case, simply use a HDMI cable to connect the PC directly to the TV.
On all models, the 3-D compatible HDMI port is identified by the letters "DVI". (eg, "HDMI 3/DVI IN" or "HDMI 1/DVI IN")
What other equipment do I need to enjoy 3-D on my 3-D Ready HDTV?
  • Windows PC with DVI output
  • Compatible 3-D Shutter glasses and IR emitter with VESA compatible sync connector
How do I connect the IR emitter to the 3-D TV to support wireless 3-D shutter glasses?
The IR emitter should be connected to the "3D SYNC OUT" socket. The emitter should be placed on top of the TV with the LEDs facing towards the room. How do I turn the TV into 3-D mode?
Ensure that the TV source is set to "HDMI 3/DVI" (or "HDMI 1/DVI" for 720p models).
Plasma HDTVs Press the Tools button and select 3D Effect. Update from Off to Mode1.
May 04, 2011 | Samsung PN50C430 50Inch 720p Plasma HDTV...
Mini hdmi socket in tomtom is not working
It is not a mini HDMI its is a mini USB for connection to a computer or charging devices
Oct 18, 2009 | Tomtom One XL GPS Receiver
Can I hook my pc to my sound system
Your cable must be a minijack to 2RCA. Minijack connected at line out on computer and 2RCA at AV1 in or other available port in on HHTS(Home theatre) (white and red socket). That is sound only. Video will be yellow (or vga/DVI/HDMI depending on graphic card)from your graphic card to AV1 in. same port as sound. Now select AV1 on HTS. If no picture on tv make sure you computer graphic card is set for dual display .
Aug 29, 2009 | Panasonic Home Theater System System
Can't get sound when used as computer monitor
comp sound Tv
Your cable must be a minijack to 2RCA. Minijack connected at line out on computer and 2RCA at AV1 in or other available port in on TV (white and red socket). That is sound only. Video will be yellow (or vga/DVI/HDMI depending on graphic card)from your graphic card to AV1 in. same port as sound. Now select AV1 on tv. If no picture on tv make sure you computer graphic card is set for dual display .
Feb 02, 2009 | TruTech PM1919BXA1 19 in. LCD TV
Samsung V30, power socket broken
You can find most any Samsung parts at this url
http://www.server-parts.com/samsung/v30.htm
Mar 16, 2008 | Computers & Internet
Aquos lc-26ga5u to mac mini
Adjust resolution on your mac mini to something the TV supports. Usually 1080 vertical resolution or below
Nov 07, 2007 | Sharp Aquos LC-32D40U Television
Other IO-920HR - iGlasses iO-920HR High Resolution 3D Headset Logo
48 people viewed this question
Top Other Radio Communications Experts
eradiostore
eradiostore
Are you an Other Radio Communication Expert? Answer questions, earn points and help others
