Question about Locks & Locksmithing
2007 yaris will not open lock with key only turns one way
When locked key will not turn to the left to open
  • john dunn
    john dunn Mar 30, 2014
    Hi john dunn, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
SOURCE: door locks Ford Focus SE 2007
open a lock door
Posted on Jul 10, 2008
SOURCE: vw polo gti boot lock
try locking the car then disconnect the boot lock. then unlock the car and reconnect the boot lock,it sounds as though its out of sinc with the rest
Posted on Oct 12, 2008
lastech
  • 408 Answers
SOURCE: ignition key won't turn lock ssembly
hi,seem your steering lock mechanism is defective,if you to try,remove your under dash,you can your steering lock, loose bolt in clamp,fine a small lock drill out,then you can turn your ignition switch,you can also remove the wiring in the back of steering lock,renew your lock mechanism,ty
Posted on Mar 23, 2009
  • 484 Answers
SOURCE: locked keys in 2007 Toyota Yaris; manual locks;
Three possibilities:
1. Call a service that can unlock your car (there are a BUNCH of these)
2. Buy a slim jim and unlock the car with that
3. Go to the dealer with the title to your car, or some proof of ownership, and they can cut you a new key.
Hope this was a little help,
matt
Posted on Sep 18, 2009
SOURCE: Cant open bonnet of Ford Focus x reg grill operated key lock wont turn
Stuck lock, bonnet won’t open ,,,
You do not need to drill holes in the grill or pay ford £200+
DIY..How?
Look into the grill at the top you will find the bottom of 6 plastic revscrews, 4 you get two via the grill slots use a chisel and cut them off, Then one either end of the grill. Place the chisel between two plastic layers, gently lift , check and cut, one each end.
With a wiggle that’s the top loose, There are two clips holding the bottom in place Put your fingers through the bottom slot in the grill, push down clip and greatly pull the grill, do both sides, It won’t come right out but your aim to loosen it., The lock is held in place in a sleeve with a plastic clips each side, you have push the barrel with a suitable item, this is to push it out of the sleeve and out of its housing, It may need a tap!!
Gently wiggle and pull the grill off
Lock
The lock is a ‘lock barrel along a shaft to a white plastic coupling’ this fits in to the ‘bonnet lock’
The security is at the coupling to bonnet lock in the form of a cross shaped plastic key
The key is fitted and held in place in the coupling, and when installed it’s fitted in to the lock, and once it’s in the lock part it will not come out, so therefore any jolt, pull, movement dislodges the plastic key from the coupling side and due to its design it will not slot back in so the lock barrel just rotates
To open you have to apply pressure on the shaft towards the left and into the coupling and turn the key in the lock barrel at the same time in a aim to get the coupling to catch the plastic key (take a few minutes) but it opens in the end if this is the fault, (alternatively remove the two bolts that hold the bonnet catch to the bonnet)
Once bonnet open remove the bonnet lock mechanism, then with draw the lock barrel, shaft, coupling, By looking in side you will understand regarding the cross key
Anyway you need to remove one of the catches from the side of the plastic key This way it will fit back in to coupling.
Reassemble
This is a brief description But the cost to me was 45 minutes, £2 for a pack of plastic rivets / screws, and I cached my bumper with the chisel £5 for a touch up stick Total £7. Well worth the time and effort
Posted on Nov 01, 2009
Seat lock wont open
Without pushing the ignition key in when turning it left from off position, lift the back of the seat while turning the key left. I have found the seat release spring under the seat gets weak, so you have to lift it manually. If you push the key in while turning it, it may bypass the seat release and lock the steering. Hope that helps.
May 05, 2014 | 2007 Derbi Atlantis Bullet 2t
Left front door lock doesn't work, neither with key or power
if the key turns inside the door lock and it still wont open its the rod inside the door panel that connets to your handles inner workings
Feb 03, 2013 | 2007 Cadillac CTS 3.6L
2007 yaris door wont lock when driver door is open
sounds like the ignition lock is worn out.
Mar 01, 2017 | 2007 Toyota Yaris 1.4
2007 Yaris Sedan key will not turn in either door. It works in the trunk door lock and ignition. Am I missing something simple? Have always used the remote entry but recently found it necessary to use...
The door locks may require lubrication; they are likely sticking as they haven't been physically turned with a key for a while. Spray a little WD-40 in there.
Aug 24, 2011 | 2007 Toyota Yaris
2007 Yaris: audio system is locked...
most likely needs the security code to unlock and activate the system.
May 17, 2010 | 2007 Toyota Yaris
My toyota 2007 yaris 4dr sedan keyless entry not working
they may need to recode your pad see dealer
Dec 30, 2009 | 2007 Toyota Yaris
Locked keys in 2007 Toyota Yaris; manual locks; how do ya unlock the door lock
matt
Sep 18, 2009 | 2007 Toyota Yaris
Automatic engine immobilizer wo'nt reset
The immobilizer does not "lock" the ignition, it does not energize the fuel injection relay. What you have is a "locked" steering column. Put the key in the ignition, and pull/turn the steering wheel HARD left or right, whilst turning the key to on or start. Do BOTH at the same time.The action of you pulling on the steering wheel will unlock the steering column.
Dec 21, 2008 | 2008 Toyota Yaris Sedan
Locks & Locksmithing Logo
37 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
