The volume completely does not work and the button on the tv don't work either
  • 3,320 Answers
Take it to a repair shop.
Posted on Mar 31, 2014
My remote won't change from AUX to Tv and all of the buttons don't work on AUX except for the volume and mute, how do I get it back on tv? Thank you
Try to push the TV button that is lit red at top middle of remote for 5 seconds in stead of hitting input. In other words by holding the tv button down it might trigger it to respond better. Thanks Mike
Apr 07, 2013 | Televison & Video
My RCA 46la45rq tv remote AND side buttons stopped working
The panel control circuit inside should be checked. Contact any experienced service technician.
Nov 27, 2012 | RCA 46 46LA45RQ LCD TV
Remote sensor on tv not responding I,have to turn on tv manually. change input manually,tv reception is ok. Volume cannot be controlled,it will lock in at full volume or drift back & forth,mostley...
Have you checked your remote to see if its working? If you have a digital camera or camera phone, point the remote at the lense and see if it shows up on camera screen. If it is working then the IR sensor on the tv could be bad.
Jul 17, 2012 | Sylvania LC420SS8 LCD TV
the problem is the s/w on the tv if you have some solder experience this is easy to fix just repalce the s/w
Feb 12, 2012 | Sylvania LC420SS8 LCD TV
My batteries died so I recharged them but now the remote will just flash on the tv button. It will turn the volume up or down sometimes. It will change the channel every once in a while but its not...
Hi drembert35,
Try dis-assemble the remote control, and clean it from inside, using Akia Spray or something, but be carefull to not use cleaning fluid which would erase the button connection with the board, so just use spray, and if you don't have one, use the water, and dry it fine before connectng the battaries to it.
and see if the buttons work fine, after doing this, and if not, do this,and don't get surprised,
use a cigarette package paper, the silver paper, and cut a circle from it, in the size of button, and put the conductor side of the paper on the board, on the buttons which don't work with you, and fix it good, then assemble the remote again.
that's if not the 1st soultion of cleaning didn't work.
and Let me know.
Jun 11, 2011 | Philips RC4331/01 Remote Control
My tv is an old rca tv, i have a dish network remote, one of the kids locked out the tv and i dont know how to get it back on, it wont tell me a anything all i can do is change the tv with the remote,...
If I read your post correctly it sounds like, the remote no longer works the volume or power for the TV set. If this is correct follow the steps below for a Power Scan. If this is not the issue or the steps don't work feel free to contact me and we will sort this out!
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Try several functions Mute Volume and Power to make sure the remote works properly then press "SAT".
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | RCA 32F531T 32" TV
Volume automatically goes to maximum on TCL TV
The volume (+) button on the TV is stuck or soiled if the volume automatically increases when the TV is turned on. To find out:
  1. Turn off the TV.
  2. Press and hold the volume (-) button on the TV then turn it on.
  3. If the volume doesn't automatically increase, you have a stuck button.
  4. If it does increase, you have a faulty key control board.
  5. In either case, you have to replace the key control board.
To find it out further:
Warning: Beware of electric shock.Please do not proceed if you do not have the skill to do the following.
  1. Unplug the TV.
  2. Let it stand for 15 minutes to allow voltages to drain completely to avoid the risk of electric shock.
  3. Remove the screws securing the TV's back cover and pull it off.
  4. Disconnect the cable that runs from the main board to the control key board.
  5. Turn the TV on using the remote.
  6. In this manner you can use the remote control to run the TV while waiting for the control key replacement board.
To do a hard reset of the TV, unplug it and let it sit for 2 hours or long enough to completely drain the internal voltages.
Nov 20, 2009 | Televison & Video
Television
You need to check what micro switch are bad and replace him because for that the remote don´´t work
Aug 25, 2008 | Televison & Video
"snow" screen, full volume, remotes don"t work
good day
due to the long time the buttons were not used, they tend to get stuck and this causes channels eighter to stay in one station or continou scanning. it could be resolved by spraying WD40 on the buttons and press it many times then dry it before operating the unit.
chris
Mar 25, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
