Question about Garmin nuvi 780 GPS
Touch screen is defective. seems to have dimple under the face and when you push is indents, but not responsive
  • Garmin Master
  • 2,130 Answers
If there is physical damage to the touchscreen, then it can become unresponsive and will need to be replaced. The touchscreen is bonded to the glass (they are one piece), so both the touchscreen & glass will need to be replaced, even though the glass may not be cracked. Please see this link for more information and how to have the touchscreen replaced for you.
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Posted on Mar 31, 2014
How to put in sim card
Assuming you mean the 2013 version but I'll try both,
so for the 2013 version
  1. Turn your tablet off and place it on a flat surface with the screen facing up.
  2. Tilt the right side slightly up to find the SIM card tray near the bottom right and the small hole in the tray door.
  3. Insert a paperclip into the hole in the tray door, and push firmly but gently, the tray should pop out.
  4. snp_8a30b60eaed5a3a37f46a8c715167552992e_3271601_en_v0Remove the tray and place the micro SIM card inside it, the angle corner fits with the angled indent
  5. Push the tray it gently back into the tablet.
  6. snp_8a30b60eaed5a3a37f46a8c715167552992e_3271604_en_v0
Activate SIM card
  1. Open the Settings app snp_2918920_en_v1 and turn off Wi-Fi after completing the set-up instructions. Once Wi-Fi is off, you'll see a notification at the top of your screen.
  2. Swipe down the notification shade and touch the notification.
  3. Follow the activation instructions provided by your carrier.
For the Nexus 7 (2012) 3G use the same process noting that the tray slot and pinhole is on the left side of the device when its facing up.
*Note* : Only the Nexus 7 (2013) LTE & Nexus 7 (2012) 3G can accept a SIM card. Wi-Fi versions of the tablet can't.
Dec 10, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
Why do I get a series of dimples on the printout?
check the format of your documents, you have to clear the possible formats which could cause the colorless dimples
Nov 15, 2012 | Brother HL-4040CN Laser Printer
Need to know how to set the timing belt on A 91 plymouth laser. Or A diagram on where the marks need to line up
First off I would strongly recommend you purchase a haynes or equivalent service manual. There are 2 indentations on the cam gears. There is an arrow on the oil pump (lower right) sprocket. There is a small dimple indentation on the crank pulley sprocket. The crank pulley dowel pin faces up. Actually, vfaq.com lol
Jun 27, 2010 | 1991 Plymouth Laser
I changed out the old timing gear for a new one. How do I set the timing gear?
have the cam gear and the crank gear dimples facing one another. The crank gear has the dimple facing straight up and the cam gear dimple straight down. The dimples are marked in the flat side facing outward in one tooth in each gear
Apr 09, 2010 | 1985 Chevrolet Chevy
I bought a 1999 Dodge Ram pickup and can't figure out how to set the clock?
Most dodge's have the two little dimples in the face.If it does you can use a tooth pick to push them.One is Hrs and other is Min.If you don't have the dimples then I have no Idea.
Jan 27, 2010 | 2001 Dodge Ram 1500 Truck 2WD
Touch screen and push buttons are not responseive.
Make sure the switch on the side that locks the buttons is not switched on. To be safe, switch it on (so that the red shows) then off.
Oct 11, 2009 | Dell Axim X51v Pocket PC
Lens will not retract
It seems like some manufacturer defect in S series of samsung. I am facing the same. EIther u can get it serviced free at samsung care or just give a helping hand to the lens when its retract , push it inside with fine touch and it will come & go smooth.
Jun 05, 2009 | Samsung Digimax S730 Digital Camera
Need to get winder out from watch so as to remove watch face
Open the back of your watch. pull the stem ( winder) out and look for a small metal piece inside that moves as you do this. There should be a little dimple on the moving piece. The piece may be on then side next to the stem, or on the movement under the movement backing plate. Tale a tweezer or something like it and push in the dimple. DO NOT PUSH HARD!!! You want to try to pull the stem out while pushing down on the dimple( it's called the detent) as lightly as you can. If you push too hard you will mess up the whole stem assemly If you still have a problem please let me know..Good Luck!!
Jul 08, 2008 | Watches
Lcd buttons not responsive
Flexible Cable between LCD and Camera circuit seems damaged. Change this cable and hope problem will be solved.
Jun 01, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
My motorola e6 touch screen is not working
Hi Guys,
This is in response to the query you have posted in one forum.
I'm not sure if you guys have already got the solution for it.
I also faced the same problem and I could fix it.
It looks like the problem happens when the touchscreen connections to the PCB becomes loose.
You may follow the below procedure to rectify the problem
- Open the back cover and remove the battery.
- Cut a thick paper in the shape of the bettery slot and place it under the battery.
- Close the cover after placing the battery. (You may feel it a bit difficult to close the cover.. but try ...)
This actually push the PCB to the touchscreen connections. Now check if you are facing any more issues..
Mine is working fine after I did this.
Thanks
Savin
May 05, 2008 | Motorola Mobility ROKR E6 Smartphone
Garmin nuvi 780 GPS Logo
73 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
