Question about White Sewing Sewing Machines
Broken spring white 1666
Tension spring broken
  • 33 Answers
I would take it to a machine repair man
Posted on Mar 30, 2014
Tension wire springs
more than likely the springs are broken . try releasing the opener and lifting by hand if you can not call a repair service
Sep 04, 2017 | Sewing Machines
What can I do to wind my bobbin tighter
Make certain you are passing the thread through the tension for the bobbin winder when setting up to wind the bobbin. Check that tension assembly for anything that could be stuck in it, preventing the assembly from putting tension on your thread, such as another thread. Wiggle the disc on the assembly to make sure it isn't stuck. If none of that works, disassemble that assembly from the top of the machine (NOT the tension you use when threading to sew!) and see if the spring inside is broken. If it is, replace the spring if you can get it, or the whole assembly if you cannot.
Apr 28, 2012 | Brother LS-2125 Mechanical Sewing Machine
Cannot get the tension right and the thread keeps braking
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 05, 2011 | Singer Inspiration 4206
I have a Kenmore 385.16126200. The tension is too loose. I have already turned the dial all the way to 9. Is there something else I could do?
I would check to make sure the spring is working in the dial, check to see if the dial is actually closing around, if not could be a bad spring in it. Also check to make sure the thread is totally in the dial. Hope this helps.
May 16, 2011 | Kenmore Sewing Machines
Machine was working fine. After lunch I returned to sewing to find the top thread that goes through the needle will continuously go around the bobbin. It will only sew only 1 to 3 inches before the...
Check the tension on the top thread - this sounds like the top tension device is not engaged or has broken.
Lower the pressure foot and pull the top thread from just before the needle, it should offer resistance to your pulling. If not, check the tension device, rethread and ensure the thread is pulled between the tension discs.
If no joy, then perhaps a trip to the shop is in order, the tension spring/device may have broken.
May 03, 2011 | Euro-Pro Sewing Machines
Tension dial not correcting tension problems
Look to see if the 'check spring" is still there, and not broken.
If the tesion nob can be truned without any feeling of tension, then maybe the screw that attaches the 'tension housing' to the stem has loosen or broken.
May 10, 2009 | Sewing Machines
Needle doesnt hook bobbin thread while sewing
Our machine had the same problem, there was a piece of broken thread stuck in the upper tension spring keeping the tension spring open. removing the broken thread in the upper tension solved the problem for us
Feb 20, 2007 | Simplicity SE3 Computerized Sewing Machine
Open Questions:
Sewing Machines Logo
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
