Question about Denon AVR-3806 Receiver
Multizone volume level is low
I have a Denon 3806 reciever and am running the rest of the house off zone 2. For some reason, my volume levels are considerably lower than they used to be when I first hooked it up. Did I loose power from my amp? Could it be something to do with the volume controls in the other rooms? I have gone through the setup and turned the volume limit off, but it still didnt help.
  • 119 Answers
Try switching the remote to operate zone 2 and turn the zone 2 volume level up higher
Posted on Aug 02, 2009
How can i connect my denon 5805ci with my new tv 4k & 3D sony 65"
Are you sure that model is HDMI v1.4 compliant? I know my Denon 8508 is not so I use optical outs to get 5.1 surround sound.
Sep 08, 2014 | Denon AVR-5805CI A/V Receiver Dolby...
Center channel problem
Sound circuit card has likely failed. Without the proper electrical tools (oscilloscope) it is hard to fix. Take it in and see what they say it will cost to repair. Take to at least two different shops.
Dec 03, 2013 | Denon AVR-3806 Receiver
Denon 785 reciever the subwoofer is producing no bass. Did tone check check all conections. Is it possible could be malfunction with reciver?
Is EVERYTHING in this scenario new (unknown functionality)?
You don't say what the result of the tone check was, nor do you identify the sub.
If your unnamed sub uses Line Level inputs just run one of the AVR's Tape Out's to it to prove the sub works. IT WILL BE LOUD since no volume control is in line with generic Line Outs. If it uses speaker level input, just run a speaker pair to it from the front channel. THEN you will know in which direction to proceed.
http://www.retrevo.com/support/Denon-AVR-785S-Receivers-manual/id/363dj796/t/2/
Jul 09, 2011 | Denon AVR-785 Receiver
My reciever is shutting down completley when i try to turn on the second zone. i tried rewiring it but it still does it could it be the reciever or do i just have the settings incorrect?
if the reciever shut down with zone 2 on, zone 2 volume at -3 and nothing connected to zone 2 it needs repair if not reconnect the speakers to zone 2 speaker connections and make sure you do not have more than 4 pair of speakers with impedence matching volume controls or a impedence matching speaker selector box
Jun 15, 2009 | Denon AVR-785 Receiver
Can't get the MultiZone to work on my Denon AVR 3805 Reciever
No as there is no volume control on the zone outputs
Aug 18, 2017 | Denon AVR-3805 Receiver
Multi-zone volume levels --not adjustable (too high!)
Press the reciever button on tyhe remote until it say Multi in the display. You can now adjust the multi zone volume level.
Jul 18, 2008 | Denon AVR-3802 Receiver
How to vary the Multi zone levels at the receiver
Try putting amp to zone 2 go to set up menu for "variable" volume adjust and turn down the volume with the remote control volume buttons or use the volume control on the amp,this should work,i had the same problem with a YAMAHA amp and this worked.
hope this helps.
CABLE GUY.
Jul 16, 2008 | Denon AVR-3802 Receiver
Multi Room / Multi zone problems
As you may see from my posted response to a posting that correctly ID'd the solution, the answer to your problem is found on p. 47 of the manual (regarding how to adjust the multi volume levels as stated on p. 26).
Jun 20, 2008 | Denon AVR-3802 Receiver
Avr 3806 power shuts off when volume turned up
Hello david 420
It looks like your receiver's high-speed protection circuit is being activated. It is definitively not a fuse. When a fuse pops, you have to physically replace it. When the protection circuit is activated, the speaker output is cut off and the power supply indicator flashes. There are a few reasons why this happens:
1.- Your speaker wire connections are loose. Whether they are banana plugs or bare wire ends, make sure the speaker terminals on the back of your receiver are tight using clockwise turning.
2.- Verify that your speakers have an impedance between 6 and 16 ohms. Your receiver was designed to work with that impedance range. Any impedance lower than 6 ohms will activate the protection circuitry.
3.- The receiver is used at high volume levels over a long period, which results in an
extreme temperature rise. Improving the ventilation conditions around the unit might help alleviate the problem.
If after complying with these suggestions, problem is still present, you might need to have the unit checked by a professional for possible circuit failure.
Hope this helps. Let me know.
cancerags
Dec 31, 2007 | Denon AVR-3806 Receiver
Denon AVR-3806 Receiver Logo
434 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
