Question about Fisher and Paykel Dishwashers
E5 We had no water supply for a short time and our dishwasher has E5 error. We now have water again but E5 is still flashing - how do we make it go away and start using again?
  • Fisher and P... Master
  • 3,247 Answers
Make sure the water inlet tap under sink is fully opened. The water pressure in mains could be lower than the setting on the dishwasher. Assuming it is DW60. See this manual.
http://manuals.appliancesonline.com.au/dw60cdx2/dw60cdx2_user_guide.pdf
Posted on Apr 11, 2014
Rotu
  • 175 Answers
SOURCE: Dishwasher will not start
Check the drain pan area under the dishwasher, if it full of water it will trip a float switch and run the drain pump until the water evaporates or is removed by a shop vac.
Posted on Oct 03, 2006
SOURCE: Indecit dishwasher not circulating water
Checked that the motor was not seized by inserting slotted screwdriver through hole at back of machine to engage in slotted end of motor to spin up water circulating motor. Motor was not seized, so that was not the problem. Then took bottom off machine and on inspection found that the start capacitor which is bolted to side of motor was bulging and discoloured wher the terminals are. Replaced Start capacitor ( Less than £10.00) and machine motor started up. Machine behaved irratically at first, flashing lights etc.but got it to reset by switching on and off a couple of times, ran machine through cycle, now working ok.
Posted on Mar 15, 2008
SOURCE: error code. Fisher and Paykel Dishwasher
well since you asked on the 5th July, and no reply, doesnt look like you may get one. I thought thats what this site was about??
Posted on Sep 22, 2008
SOURCE: dishwasher will not run. clean light flashes seven times
I tried the button sequence described by guest #1 but nothing happened.... is there anything more to it?
Posted on Jun 13, 2009
  • 177 Answers
SOURCE: Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Posted on Mar 02, 2010
Samsung error E5
I don't know about a E5 error; are you sure it's not a 5E error? That means a drain error or "water not draining" error. Check the drain pump and drain hose for an obstruction. If that's okay, and the dishwasher drains water, then you probably have a bad ECS sensor.
Mar 30, 2014 | Samsung DMR77LHS Tall Tub Dishwasher
Tip
Blinking Clean Light on Kenmore & Whirlpool Dishwashers
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
on Feb 28, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
Dishwasher is not working, FP DW60CSW1, three of five lights blinking
It is possible you have this error
First 3
programme
indicators
flashing
E5 Water tap not turned on.
Insufficient water supply pressure.
Water supply hose is crimped or
bent.
Drain hose is too low.
Ensure the water is connected
and turned on.
Check household water pressure.
Check hose and straighten if
needed.
Ensure that drain hose is
connected in accordance with the
'Installation instructions'.
For details refer user guide.
Apr 08, 2013 | Fisher and Paykel Dishwashers
Program stops after a couple of minutes beeping continuously and giving an E5 error message.
The alarm E5 indicates it's failing to fill in the allotted time.
As you can restart and it then completes I'd suggest checking the pressure system to see if theres a restriction in it.
Alternatively, a couple of runs with a dishwasher cleaner should break down the detrius that would cause this.
The pressure switch should be on the bottom right near the front of the appliance.
Take the thin tube off of it and blow as hard as you can back into the sump.
Also check the water supply is ok, pressure and flow is good.
Hope this is of some help
Aug 04, 2010 | Belling 24 in. IDW603 Built-in Dishwasher
I have a kenmore elite dishwasher 577-9 17262402. The clean light is flashing. How do I stop it from flashing to start the dishwasher?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 21, 2010 | Kenmore 24 in. 15252 / 15254 / 15259...
Kenmore dishwasher will not start
May 28, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
May 27, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
E5 error - need to know where drain hoses are
tried to take off the drain hose, but could not get it off the back, only by the disposal. I turned if off and on about 6 times and ran the delime cycle with lots of limeaway. It got the E5 error on the delime cycle, but it worked the next time I tried to run it.
The manual does say to turn it off and on as it drains out the water. Takes a while as it has to heat up the water each time.
May 12, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Kenmore elite keeps flashing red on smart wash button. It won't do anything else.
Feb 18, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
403 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
