E000805 on IRC while related fan is rotating
Is it possible it may come from the connection to a PC?
  • 28 Answers
Not possible replace machine pcb
Posted on Mar 31, 2014
Canon ir3300 error code 000805-0002
canon ir2200 E000805-002
E805
The clock signal is absent for 5 sec or more after the fan drive signal has
been generated. The detail codes of the fans in question are as follows:
0001 developing fan (FM1)
0002 fixing fan (FM2)
0003 curl reducing fan (FM4)
0004 curl reducing fan (FM5)
0005 electrical unit fan (FM3)
Main cause The fan wiring is faulty (short circuit, open circuit). The fan is faulty. The
DC controller PCB is faulty.
Action
1. Foreign matter
Is there foreign matter that prevents the rotation of the fan?
YES: Remove the foreign matter.
2. Wiring, Connector
Are the wiring and connector of the fan normal?
Developing fan (FM1): DC controller PCB (J302B)
Fixing fan (FM2): DC controller PCB (J308B)
Curl reducing fan (FM4): DC controller PCB (J311B)
Curl reducing fan (FM5): DC controller PCB (J311B)
Electrical unit fan (FM3): main controller PCB (J1028)
NO: Correct the wiring and the connection.
3. Fan, DC controller PCB
Try replacing the fan. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Nov 09, 2016 | Canon Ir 3300 Black & White Copier
How can i solve E000805-0000 error on Canon IR 2318 copier
Fan failure
Check the fan connector.
Replace the fan.
Nov 02, 2016 | Canon Office Equipment & Supplies
Copier ir3100cn when switched on display error code e000805-0003 what is this problem ?
I believe this is a problem with the main cooling fan in this machine, check this is rotating properly, and if not, it will need to be taken out and tested, and then replaced it is, indeed, fautly.
May 27, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
E000805-0002
Fixing fan rotation error which cools the fixing assmbly, the fan may be clogged or need replacing
Oct 09, 2013 | Canon imageRUNNER 3300 All-In-One Laser...
My canon ir 3225 is giving me e000805-0003,where is the problem?
A E000805-003 is a error code for a fan that is not working correctly
Dec 19, 2012 | Canon imageRUNNER 3225 Black and White...
Canon ir 3300 error code E000805-002
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR3300&code=E003-0000
Oct 22, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
First there was E000007-0000 then when I service it the error changes to E000805-0000. so how can I solve it.
the e805 is service code for trouble with fan. if you say that you did service before this error, check if everything is properly connected.
emma.servis@gmail.com - for service manual!
Hope that helps!
Apr 28, 2011 | Office Equipment & Supplies
Paper jaam and e000805-0000 error
check the cooling fan motor may be one of the fan is not rotating
Nov 24, 2010 | Canon imageRUNNER 400S Copier
"denial of service": email, firefox, etc. cannot find server..
What told this was a "denial of service"?
Some hackers use DoS (above) it's considered the worst thing you can download, they can go from keylogging your PC, from taking over your pc anytime they like, and using your bandwidth which is called DDOS.
This is a very compllicated thing to get ride of,
One way you can test to see if your a victum of this is to check the port, here is how:
To open the MS Dos screen go to:
Start>Run>type "cmd" and press enter (without quotes)
All of the IRC Zombie/Bots open and maintain static connections to remote IRC chat servers whenever the host PC is connected to the Internet. Although it is possible for an IRC chat server to be configured to run on a port other than "6667", every instance I have seen has used the IRC default port of "6667".
Consequently, an active connection to an IRC server can be detected with the following command:
netstat -an | find ":6667"
Open an MS-DOS Prompt window and type the command line above, then press the "Enter" key. If a line resembling the one shown below is NOT displayed, your computer does not have an open connection to an IRC server running on the standard IRC port. If, however, you see something like this:
TCP 192.168.1.101:1026 70.13.215.89:6667 ESTABLISHED
. . . then the only question remaining is how quickly you can disconnect your PC from the Internet!
A second and equally useful test can also be performed. Since IRC servers generally require the presence of an "Ident" server on the client machine, IRC clients almost always include a local "Ident server" to keep the remote IRC server happy. Every one of the Zombie/Bots I have examined does this. Therefore, the detection of an Ident server running in your machine would be another good cause for alarm. To quickly check for an Ident server, type the following command at an MS-DOS Prompt:
netstat -an | find ":113 "
As before, a blank line indicates that there is no Ident server running on the default Ident port of "113". (Note the "space" after the 113 and before the closing double-quote.) If, however, you see something like this:
TCP 0.0.0.0:113 0.0.0.0:0 LISTENING
. . . then it's probably time to pull the plug on your cable-modem!
Note that a Windows IRC client program running in the PC will generate false-positive reports since these are tests for IRC client programs. So be sure to completely exit from any known IRC client programs BEFORE performing the tests above.
Oct 18, 2007 | Dell Inspiron 2200 Notebook
29 people viewed this question
jasbo
jasbo
