Question about LG 32LC7D Television
Lg 32lc7d hdmi no signal
When I plug anything into either of the 2 hdmi inputs on my tv all I get is no signal
    New Friend:
  • 56 Answers
Try another HDMI source (borrow a friend's BluRay for example} to confirm it is the TV at fault. If it still doesn't work, the TV needs a main board replacement because all the HDMI circuitry is on the main board. this usually happens after a power surge or lightning storm, and a near hit is all it takes, Sometimes, if you have a Satellite Receiver it too might be damaged on its HDMI output. So 1st try another source..IF you replace it yourself be sure to find the right board by using the TV's service # example 32LC7D-XX.XXXXXXX.. The letters where I have Xs are very important and must be matched,
Posted on Mar 30, 2014
  • 1 more comment
  • Joshua Press
    Joshua Press Mar 31, 2014
    Tried it with my set to9 box, ps3 and xbox 360 all say no signal but if i turn my tv off then back on in the top right corner it says connecting then no signal. also tried 3 diffrent hdmi cables same with all no signal
  • Joshua Press
    32LC7D-AB.AAUYLJD is that the number I need to find the main board?
  • larry lease Mar 31, 2014
    Yes, that appears to be a correct number, so now you'll have to find the part number for the main board by using that service number. I can't help you with that as my refernce material does not contain your service number
  • 60 Answers
SOURCE: pc to tv
Try changing the resolution on you computer. That TV may not handle the current resolution setting. You may also have to do something on your computer to turn on the rgb output.
Posted on Feb 22, 2008
  • 979 Answers
SOURCE: Unable to display HDMI Input
Okay so you have the HDMI cables from both the DVD and the Cable box plugged into the reveiver?
Posted on Feb 28, 2008
  • 50 Answers
SOURCE: "No signal" sign on TV screen using HDMI selector
it sounds like a refresh issue, double check you selector and make sure it fits the refresh of the tv. i had this once with a sharp where the tv was 120hz and the selector was 60 and it created a no signal and when it did come in it was jumpy. if you have a 120 tv then selector should be the same.
Posted on Apr 27, 2010
SOURCE: Sony Bravia does not recognize my Dell Inspiron 1525
I have the 1525 and you have to do extra steps each time you want the HDMI to be recognized by the Bravia - too bad it is not automatic as it is with some. Anyway what you have to do is have the HDMI cable connected from laptop to TV then go to your desktop - right click on an open area (away from icons), a menu will appear, let the cursor hover over Graphics Options - you'll then see Output To...then you'll see Intel Dual Display Clone...hover over that and you'll then see Notebook + Digital Television...left click on that and you should see your desktop on the TV in a few seconds. If it does not work the first time...get your movie or whatever you want to show up and ready and go thru these steps again...stupidly complicated aye? when it should automatically detect and show...are other TVs like this?
Posted on Dec 07, 2010
SOURCE: LG 37LC2D HDMI no signal (picture or sound) + crackling on audio
i have the same problem. i think they just get old, i solved the audio problem by taking the cove off the back and disconnecting the speakers, i now just use PC speakers, works grand. i haven't solved the HDMI problem yet..
Posted on Jan 17, 2011
I had it working about 10 minutes ago and moved the remote and now no signal.. how do I fix this?
-Be sure your TV is on the correct source or input as your CABLE or SAT BOX.
-Press the TV button on TV remote control to turn your TV ON.
-Press the INPUT button on your TV remote control.
-Cycle through all the inputs on your TV.
-Do this until you are on the INPUT your CABLE or SAT BOX is plugged into.
-You should then see the CABLE or SAT programming show on your TV.
HINT: Your TV will most likely list the TV INPUTS as: HDMI 1, HDMI 2, HDMI 3, VGA, Component 1, Component 2, and so on.
Feb 05, 2018 | Televison & Video
My digital tv is saying no singal whats the problem and how do I fix it? we have a huge antenna on our roof
1 – Is the NO SIGNAL issue happening on just one TV?
CORRECT INPUT or SOURCE
If it is just one TV that is showing the NO SIGNAL…
If you still see NO SIGNAL on your TV screen, see the next step below…
2 – If you have your TV on the correct INPUT or SOURCE and you still see NO SIGNAL…
CABLE OR SAT BOX NEEDS RESET
-Remove or unplug the power cable from the Cable TV or SAT set top box.
-Keep it unplugged for 2 to 3 minutes.
-Plug the power cable back into your Cable or SAT set top box.
-Give it some time for the Cable or SAT box to power up, get the signal, and initialize.
3 – If you have reset the Cable or SAT box and still have the NO SIGNAL…
UNPLUG THE CABLE GOING FROM THE TV TO YOUR CABLE OR SAT BOX
-Remove the HDMI cable or other cables from your Cable TV or SAT set top box.
-Keep the cable unplugged for 2 to 3 minutes.
-Plug the HDMI cable or other cables back in.
-Give it some time for the Cable or SAT box to get the signal and initialize.
HINT: Make sure all the cables that are connected to your Cable or SAT box and your TV are tight, undamaged, and secured.
4 – If all of your TVs are affected with the NO SIGNAL screen…
BE SURE THE COAX CABLES OR ETHERNET CABLES ARE SECURE or CABLE OR SAT IS DOWN TEMPORARILY
-Be sure to check the ones where the CABLE or SAT come into your home.
-Be sure ALL Ethernet and Coax cables are secure.
-Call your CABLE or SAT provider to see if there is an outage.
-Realign your Dish if you have SATELLITE.
May 10, 2017 | Televison & Video
My lg plasma Tv hdmi ports will not work?
Have you tried different HDMI cables?
Have you tried switching the ends around?
Are you sure you changed your TV inputs to the correct one?
Not all LG TV's will sense an HDMI connection and offer to switch to the new input.
I know it sounds ridiculous but I had an HDMI Cable break just sitting there. Also they now have HDMI Cable that are Unidirectional, you can plug them in backwards.
Dec 23, 2016 | LG Televison & Video
I have just acquired a new lg tv as a free gift from sky. My problem is u can't tune it in either auto or manually. I don't have a aerial just hdmi skybox
You will not be able to tune in TV stations unless you first have a TV antenna installed. Once connected to a working antenna the set should find stations easily enough ?
But you do not need to tune anything in to use it with your skybox -simply connect the skybox to the TV using an HDMI cable (available anywhere that TV's are sold) noting the number of the HDMI socket that you plug in into on the TV. Then, using the TV's remote, set the TV to input signal from that input (HDMI 1 for example) and you should be fine?
Apr 14, 2016 | LG Televison & Video
Have brought second hand Hitachi tv which just comes up that it has no signal. To retune i need a 4 digit code,is there any way i can by pass the code or put in something that the Tv will accept.
Hi Annette.
I'm not sure what level you're needing a code for. If you're looking for unversal remote codes to try to pair a remote to the TV, a listing can be found here
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
I'm not finding anything else about Hitachi TVs and a 4 digit code.
Is this 'no signal' coming in off of a cable, or off of broadcast TV? You may also want to check if there are multiple inputs and you're on a not-plugged-in input. For instance, the TV may have 3 HDMI inputs and a set of component video inputs. If, say, your cable box is connected to HDMI 2 and your DVR is plugged into HDMI 3, then if the system defaults to HDMI 1 when it turns on, perhaps it's showing some error code. You should have some sort of input select function. Try cycling through your inputs to make sure that the set is OK playing from other canned input like a DVD player. If so, then move that input through the imput ports to make sure they work.
If the TV has a direct cable coaxial hook-up, most, if not all cable companies anymore only broadcast in encrypted digital, meaning you'll need a cable box or something like a TiVo with a special cable card to see anything.
More specifics would need the make / model / year of the set.
Hoping this helps!
D
Nov 30, 2015 | Hitachi Televison & Video
LG 60pk950 - HDMI inputs 'No Signal'
Try manipulating the TV mode selection to HDMI 1, 2, 3 or 4, whichever the number of HDMI ports are available.
Nov 02, 2015 | LG 60PK950 High Definition Plasma TV
On my e-motion tv when I switch it on and go onto did it says no signal....help please
Why does my TV say no signal? If your HDTV or Standard TV displays a "No Signal" error message, it may be due to one of the following issues:
  1. Determine how many TV's are affected.
    • If it is one TV, continue to step two.
    • If multiple or all TV's are affected, continue to step five.
  2. Ensure that your HDTV is on the same source/input as your MTS Ultimate TV service.
    1. Press the TV button on your MTS Ultimate TV remote control.
    2. Press the TV/Video button.
    3. Wait 10 seconds.
    4. Repeat steps b and c continually to cycle through all the available source/inputs on your TV until the correct source/input is selected. (ie. HDMI 1, HDMI 2, Component 1, Component 2, etc.) On standard TV's (non HDTV), you may have only 2 choices, TV or Video.
  3. If the source is correct from step two:
    1. Unplug the HDMI cable from your MTS Ultimate TV Set-top Box.
    2. Wait 30 seconds.
    3. Plug the HDMI cable back in.
    4. Wait for the signal to initialize.
    5. Make sure all cables connected on the set-top box and your TV are secure.
  4. If the problem persists:
    1. Unplug the power cable from the back of the MTS set-top box.
    2. Wait 60 seconds.
    3. Plug the MTS set-top box back in.
  5. If you are still experiencing a problem:
    1. Make sure ALL Ethernet and/or Coax cables are securely in place.
    2. Unplug the power from the MTS box labeled 2Wire or Pace as well as the affected set-top boxes.
    3. Wait 60 seconds.
    4. Plug the power back into the MTS box labeled 2Wire or Pace.
    5. Wait for the broadband light to turn a solid green colour.
    6. Plug the power back into the affected set-top boxes.
    7. Wait for the signal to initialize.
Good Luck
Feb 24, 2015 | Televison & Video
Roku stick dosent do anything. ...? Plugged into hdmi slot on tv and also plugged in power cord to roku and nothing pops up on my tv...? Iv tryed to reset but dose nothing. ... help???
Did you change the TV input setting on your TV to the correct HDMI input? Most Televisions will take a few seconds to scan the input before displaying any image. Most newer televisions have multiple HDMI inputs, and you might need to select each one, wait several seconds to see if there's a signal, and then move on to the next input, until you find which HDMI input has the Roku start screen signal.
Dec 09, 2014 | Televison & Video
When I switch from one HDMI input to another I get a no signal & spinning LG box. after several minutes it gets a signal
Try a different HDMI cable, then try the other HDMI inputs on the TV, then try to connect another HDMI device to the TV. If all are still bad main board needs replaced
Oct 19, 2014 | LG 55LK530 55 inch 1080p LCD HDTV, with...
Why is tv saying no signal?
Connect a known working DVD player by using a new HDMI cable to HDMI INPUT 1 and check for signal.
If you have a DISH or CABLE system box, connect that also with a new HDMI cable to HDMI input 2 or 3 and recheck for signal. Your T V remote will have an input selector to change between the different inputs on your
T V.
Sep 08, 2014 | Proview HX303 30 in. HD-Ready LCD...
LG 32LC7D Television Logo
191 people viewed this question
Computer Repairing
Computer Repairing
