Question about TechShade - M967 - Auto Parts & Aftermarket Accessories e
NSN For a Valve Ball
I am looking for a valve ball. the NSN that I have is 4820010874529, but that is not a good NSN. Would someone please help me out. This item is Dealined in Afghanistan and I need it fixed.
  • 2,019 Answers
You need to tell us what the diameter of the lines are, and what will flow through the valve? It is gasoline, water, natural gas, etc?
Posted on Apr 12, 2014
Will not pick up paint
Hi Dan,
Yes there is a second ball valve; it is the outlet valve located inside the piston. When you remove the inlet housing to access the inlet valve and its parts, you can partly inspect the outlet ball valve which you can see in the end of the piston; check that it is free to move and nothing is stuck in it. Another thing that can stop the sprayer from priming is the priming circuit is blocked up, either the bypass valve or the return hose or both. This happens when you don't flush this out at the end of the day.
Sep 16, 2014 | GRACO INC 210 ES Airless Sprayer
Tip
Ball valve
when buying a new ball valve for toilet or water tank blow through the open end with the arm in closed and check for air leaks release the arm air should flow shut again should be silent this will indicate a good working valve
on Mar 14, 2010 | Plumbing
What is the ball valve for?
Good Afternoon Friend,
I understand you want to know what the ball valve is for, in your Frigidaire dishwasher, model# FDB1050RE. In your particular appliance, I don't show that there should be a ball valve. I show that there is a "check ball" in the sump, which controls and switches water flow between the spray arms. I ask that you please follow up with a comment on the post, at your convenience, to advise if you have further questions. Hope this is helpful.
-Best regards-
WP
Jun 01, 2014 | Frigidaire 24 in. FDB1050RE Built-in...
Ball valve leaking
Probably need to re-pack the stem with stem packing thread
May 11, 2014 | Plumbing
Flush ball sticking dometic toilet
Actually, it's the flush valve that's not closing. The ball operates the valve. In some cases the valve needs to be replaced; in others, the ball has absorbed water and is unable to close the valve completely.
Jan 14, 2013 | Dometic Sealand 500 Plus Series Toilets
How do i adjust the water level in the toilet tank?
Lift the top lid of the toilet tank. You will ball valve assembly. At the end of the arm of the ball valve there is a nut which if tightened lifts the ball valve. If loosened the ball valve goes down. You can adjust it to suit your requirement.
May 19, 2011 | Home
20 ton jack is new model ge2105a, does not work at all. especially jacking up. it has oil and as far as i can tell no air in the oil.?????
Unscrew the release valve completely and check that the ball is in place. Check that the release valve screws in all the way to seat the ball. Try inspect the ball seat at the bottom of the release valve to see if there is a good solid face for the ball to seat on. (The jack should respond a little, even if there is a slight leak on the release valve). There is another ball valve in the jack. It might be located in the body below the release valve or it might be inside the bottle. (If it is a new jack, surely it should still be under warranty and you can take it back to the dealer?)
Feb 04, 2011 | Garden
I just had a new thermostat put in my 2005 pilot because only cold air seemed to be blowing - lukewarm at best. They also fluched and put in new anti freeze. It seems better but not great. Now my center...
Had the same problem on a 2006 pilot LX. Hot from rear heater because it comes from a separate heater core. Front heat low because ball valve faulty that controls coolant flow to heater core. The lever on the valve would move freely but the connection to the shaft of the ball valve was stripped. Ball valve may be located on the firewall under the hood. Ball valve very poor design.
Dec 02, 2010 | 2005 Honda Pilot
Pump won't pick up cleaning fluid thru plastic suction tube.. Troy Built with 5 hp engine
The suction tube connects to a small brass piece that has a ball valve. When pump pushes water down hose, it creates suction on the ball valve. The ball valve has to be the right size. Too large, no suction, too small, no suction. The entire world of electronics is based on similar principle.
When the ball valve wears out, or gets clogged, the pump pressure is not able to lift fluid. Try cleaning valve, but my bet is you need a new part with the ball valve.
Oct 06, 2010 | Garden
TechShade - M967 - Auto Parts & Aftermarket Accessories e Logo
69 people viewed this question
Top WeatherTech Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a WeatherTech Vehicle Part and Accessory Expert? Answer questions, earn points and help others
