Pitsos dif 4305
How can i put out the water pump in order to replace it?Because at the end of any program,remains water on the buttom of MY washing machine.Or maybe there is another way to fix the problem?Thanks...
  • 183 Answers
SOURCE: Flashing Lights on Ariston A1636 & Won't progress to rinse either
Suggest checking for a faulty heater. Regards Engineer
Posted on Jul 29, 2007
  • 1294 Answers
SOURCE: Does not Spin out the water at the end of a load
If it spins the balance is okay. Check out your filter now. And then the pump (after the spigot prob below) Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
  • 1314 Answers
SOURCE: Gibson front load washing machine will not spin
are you sure the pump is plugged up and was the impeller damaged
Posted on Mar 29, 2008
SOURCE: washing machine
whilpool awo/d 4305 light onclean pump can i do this myself
Posted on Nov 23, 2008
SOURCE: Hoover CA230 1300 Special Edition Washing Machine
I had the same problem. My husband checked the carbon brushes attached to the motor and ran the machine on spin. The brushes were sparking so he assumed they were worn and replaced them and hey presto machine works fine now. The brushes cost 23.99 and were just bought from a local shop but can be bought online cheaper. Hope this helps solve your problem. Essex
Posted on Apr 08, 2009
Whybdoes water remain in machine at end of wash?
If the drain pump malfunctions...or is clogged then it will not empty within the time cycle and the unit will time out. the pump in at the bottom of the machine
May 21, 2014 | Maytag Neptune Washer
Water leaking underneath pitsos dishwasher when in use
It is so common that the drain leaks in many ways and is the most problematic fault in a dish washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
to replace door seal : click on door seal
Jan 12, 2013 | Dishwashers
The water remains in the drawer after a washing cycle
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Thank You for using fixya
Aug 12, 2011 | Hotpoint Washing Machines
The Water is not emptying even tho I have unplumbed hose and put it at flOor level. It is 10 years old. Is it worth repairing?
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. Take a try and DO NOT ORDER PARTS UNLESS IT IS CONFIRMED.
Aug 08, 2011 | Hoover Washing Machines
Hi I have a problem with my laundry machine.Its flooded and the water stays in the laundry machine and the water wouldn`t go away.We washed our clothes with three programs in a roll.And maybe thats the...
Aug 08, 2011 | Washing Machines
I have IFB Elena washing machine. My problem is that water is coming out of soap inlet dish. Also after the cycle is complete drum is filled with water.
Water in the soap tray can be due to fault program,excess water level or inlet leak.Water collecting as the drain fails to work is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Jul 29, 2011 | Washing Machines
Water remaining in washer after completed
any error codes maybe f21,take the bottom panel off, you'll see the pump on the right hand side,use a pair of plyers to unscrew the middle part of pump,if you have a shop vac turn the middle part counter clock wise slowly when water starts coming out vac it up,also put a towel under the pump to catch water,when it's drained unscrew the middle part all the way and take it out and clean out the pump,feel around inside to make sure nothing is stuck in the impeller of the pump, try blowing through the other end of drain line to see if there is a block in it,put it back together and run it,put it on spin drain and make sure water is pumping out the drain line,if not the pump could of been damaged and you need to replace it
Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Mar 29, 2008 | Washing Machines
Gibson front load washer will not spin
well lol thats what i was going to tell you to do if you didnt hear the crunching sound with the power off but good for you
Mar 28, 2008 | Washing Machines
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
