Question about Cell Phones
Rca tablet problems
I was charging my tablet, never had a password, but when i unplugged it this time, from the charger it ask for a password. tried a few of my personal password and the internet password cause it is connected to internet, tried pressing reset but still comes back to screen asking password.
  • 30 Answers
Don't know if this will help but I had a lepan tablet that messed up weird like that. I let the battery totally die, recharged it, and it worked fine. if that doesn't work, try to do a factory reset, google the type of tablet + factory reset and it will give you a series of buttons to push (FYI this will delete any files you have on it)
Posted on Apr 10, 2014
I have a RCa 10 inch tablet and it just went dead on me when I press the power button all it,s showing is a battery I keep it plugged in alll the time what is wrong and do I keep my tablet plugged in
Are you using the charger? Some tablets specifically mention a similar problem occurs when trying to charge via USB. The charger has a higher output voltage.
May 24, 2017 | Tablets & eReaders
Tablet not charging while plugged in
Turned off the tablet, unplugged the charger and kept the tablet off for about 30 minute to one hour, plugged in back the charger, then turn on the tablet. After that I you might see the tablet started charging. Good Luck.
Jul 10, 2015 | ASUS MeMO Pad HD 7
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
NOTHING BUT A BATTERY AND RCA TABLET COMES ON WITH CHARGER BUT SHOWS NOTHING BUT A BATTERY ON SCREEN RCA 7 INCH TABLET
With the charger hooked up and plugged in the tablet will only show the battery on the screen briefly to let you know it's charging. It won't actually boot up until it has a sufficient charge. Just let it set that way for a couple of hours then try to power up.
Feb 26, 2015 | RCA CA 7" Tablet with 4GB eory 28458515
I have an Rca tablet that wont turn on, i have used three chargers to try and get it working but still wont turn on.
Try connect to PC. If PC find it - its ok, then you need reinstall windows or android, if not find, something wrong with microschemes
Feb 25, 2015 | RCA CA 7" Tablet with 4GB eory 28458515
My tablet want come on what's wrong with it
I've had the same problem with my RCA 10 inch tablet. I have charged it, tried the hard reset, used different chargers and even different outlets, and held the power button on for 60+ seconds with NO RESULTS! My recommendation is to contact RCA, which is what I am doing, and request an immediate replacement if yours is still under the 1 year manufacturers warranty. If you look these tablets up, you will see (as I have found) that this is apparently a common problem with the tablets. Wish I had known that prior to purchasing!
Jan 01, 2015 | Tablets & eReaders
I turn my tablet on then it switches it self off
Sounds like it does not have enough battery power to stay on. If you have not tried to charge it, you should try that first. If you have, it sounds like it is not getting charged or not holding a charge. Could be bad AC power source, bad charger, bad charger connection or bad battery. Take steps to confirm that each of these are good. If all of these are good, sometimes the tablet can become so discharged that it will not allow itself to charge. When they are in that state, sometimes you can trick them into charging again by repeatedly disconnecting and reconnecting the charger as follows: With charger plugged in to AC power source, connect the charger to the tablet. Pay attention to the screen or LED or whatever indicator your tablet has to let you know it is charging. You may see it momentarily indicate charging, or maybe not at all. Then unplug the charger from the tablet then immediately plug it back in and pay attention for the charge indication again. You may have to do this a bunch of times (like 20) until you see the indication that it is charging. When you do get the indication, stop unplugging and re-plugging and let the tablet charge for 24 hours (to a full charge). This trick doesn't always work. Sometimes the battery or charging circuit or an internal connection is bad and no amount of unplugging/re-plugging will fix a hardware problem.
Nov 17, 2014 | Tablets & eReaders
My daughter's RCA tablet will not turn on. what can i do?
Two possibilities:
1.- Be sure the battery is charged. There has to be some indication that the tablet is being charged.
If you can turn on the table when plugged in to the charger, and it dies soon after unplugging it, the tablet's battery may need replacement.
2.- The other possibility is that the tablet is dead...
Jul 30, 2014 | Tablets & eReaders
My RCA tablet died and it wont turn back on
If you have the correct charger, let the tablet charge for a full 24hrs, actually i think 10hrs will be ok and try turning it on, also you can google how to do a reset for your exact model tablet. I have another brand tablet and that worked.
Mar 28, 2014 | RCA Tablets & eReaders
Rca tablets
My tablet isn't charger isn't charging my tablet
Jan 03, 2014 | Audio Players & Recorders
Cell Phones Logo
132 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
