Question about ZJ YiWu Tattoo Stencil Maker Transfer Copier Thermal Machine
Monster point tattoo stencil machine
Stencil copy comes out blotchy not usable
How to ajust the points on a tattoo gun
be more specific, you mean contact points? that's all about armature height, spring tension, spring load, spring angle, spring slope... you want your armature bar about half a centimeter higher than the vice hole on your iron, you want your spring bent to around 20 degrees to 30 degrees depending on if your'e shading or lining. alignment springs (the one that is on the bottom of the armature bar) should usually be a 16 unless your'e using monster coils which good ol fashioned 10 wraps can do lining or shading if youre any good at tuning. dial back your contact screw so that it is not touching the contact spring when it's idle. Use 5-8v of power and press the pedal and dial it in until it touches. The machine will run, keep playing with the contact screw (screwing it inward) until the armature bar has a visible wobble optical illusion attributed to it. LIGHTLY allow the pole on the armature bar to hit your finger and if the machine speeds up instead of slowing down, you've hit the sweet spot. - Professional tattoo artist - Brian @ Foxy Tattoos, Raleigh, NC
Mar 21, 2012 | ART Cast Iron Coil Tattoo Machine Liner &...
Tip
Darkline Tattoo - Edsa Central Pavillion, Mandaluyong, Philippines
Got A Nighthawk ? Get A Tattoo !
Tattoo Supplies (Needles, Inks & Machines) | More Than 7000 Flash Designs | We Do Custom Designs
click here to visit website
on Mar 01, 2009 | 1991 Honda CB 250 Nighthawk
I dont know how to wire it
I hope it can help you: How to Wrap Coils for tattoo machines parts
http://www.ehow.com/how_7693710_build-tattoo-machine-coils.html
Oct 19, 2011 | ART Cast Iron Coil Tattoo Machine Liner &...
My copies are coming out "blotchy"(with light spots).
Sounds like the machine needs a deep cleaning, and exposure adjustment...call for service
Mar 20, 2009 | Copystar CS-1810 Copier
Broken tattoo gun
sounds like the armature bar is gone, replace the bar for a small fee, or better still replace the whole machine with a good quality one, they aint cheap but will last you a liftime.
Mar 12, 2009 | Butterfly Tattoos
I need a User Manual Guide for my Tattoo Kit/Machine.
if you dont know how to use it .........dont bother!!!!
Jan 28, 2009 | Primal Wear Arm Warmers Tattoo Medium...
Can you use thermal transfer paper
The paper will probably come out black after being heated by the fuser. 350 degrees.
Jun 07, 2008 | Brother IntelliFAX 885MC Plain Paper...
Hotpoint Aquarius WF100 Spin Hot
use a label maker they cost 15 to 20 and the labels last forever.
there are ways to stencil them on but they will come off unless you use plastic paint.
Apr 02, 2008 | Hotpoint Aquarius WF000 Front Load Washer
ZJ YiWu Tattoo Stencil Maker Transfer Copier Thermal Machine Logo
91 people viewed this question
Top ZJ YiWu Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a ZJ YiWu Craft and Hobby Expert? Answer questions, earn points and help others
