My reduced creases and mini load button are flashing ?
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
My hotpoint washing machine WF560 mini load and reduced creases lights are flashing and also the on/off light is also flashing, please help. Thanks
Heating eliment or PCB, is this when doing a prewash? or a normal wash excluding pre wash?
if you can manualy pump out and manualy rinse and spin, my guess is heating eliment is broke £20-£30
Jan 27, 2011 | Washing Machines
Hotpoint WF541 problem
Technical Fault is Pressure switch jammed on empty: check switch & module... in laymans terms its either a blocked sump hose or faulty pressure switch/module
Mar 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
The mini load and reduced creases light flash when washing has finished, but its as though it hasn't been spun properly
I should check the filter if I were you.
Remove lower rear panel of washer, remove large black hose on bottom of drum, remove and clean filter inside hose.
Please rate my solution.
Thanks.
Nov 03, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Reduce crease and mini load lights flashing on hotpoint wf541g. had pump failier and have replace with new on but still not pumping water out.
I have encountered a similar problem. The following lights were flashing on and off:
  • On/Off.
  • Reduced creases.
  • Mini Load.
I also found that previously one of the 'lifters' inside the drum had broken off and someone had tried to put it back in place and continued to use the washing machine. After a short period of time the above mentioned flashing lights began.
I first suspected the pump, but this was fine. I then disconnected the hose which connects the hole from the drum to the pump and I found a child's sock blocking the hose. I removed the obstruction, put it back together and the machine worked perfectly. I also replaced the lifter (apparently these break quite often) and the machine has been working perfectly ever since that day.
I hope this helps. Good luck.
Mar 10, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washing machine will not finish cycle and the reduced creases and the mini load buttons continuesly flash. Do you know how to solve this problem? My problem is same as earlier person identified sep 08. I...
Could be pressure switch jammed on empty, check pump for draining properly..
Select drain only and see if the water comes at a good rate, there are other problems that could the sequence of lights flashing that you are experiencing.
Dec 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Wma54
will help type this into a search engine it the user manual !http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WMA50_WMA52_WMM53_WMA54_WMA56_WMA58_WMM59_small.pdf
Feb 15, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
