Question about HP Pavilion dv6000 dv6100 dv6200 dv6300 dv6400 Motherboard - 434722-001
Charging diagram for 431426-001
For to check to see if the motherboard is getting power
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 2,226 Answers
If your power supply is good then your board will have power if not then the board is bad. there is no charging diagram make sure that all power plugs are on board are in
Posted on Mar 30, 2014
  • Deborah McNeil Mar 30, 2014
    when i check the pwer supply the light comes on when it is out of the machine but when i put it back in no light and not charging
A circuit diagram for samsung np-s3520 laptop motherboard
First, check the output of the laptop's power supply with a multimeter. If it is producing the voltage indicated on the power supply's label, your power jack on the motherboard has possibly been physically broken inside the case some how. Another possibility is the battery itself has become defective.
You will need expert desoldering skills to be able to install a new jack, not to mention skills to entirely remove the motherboard from the laptop's case and reassemble it to its original state again. Motherboards are multi-layered and excessive heating of the board can damage "through holes" that must be cleared and cleaned out enough to insert the new part without damaging the board. Temperature controlled soldering equipment is recommended. If the board has become broken, the laptop is likely uneconomical to fix.
Here is a link to someone selling this part on Ebay @ $4.00 USD+ a few dollars shipping if you're located inside the U.S.
NEW SAMSUNG NP S3520 LAPTOP AC DC POWER JACK CHARGING PORT SOCKET PLUG
Ensure the pattern of the legs of the replacement is the same as the original. This should be obvious from comparing the pattern on the backside of the motherboard where the original jack is located.
Sep 24, 2014 | Computers & Internet
I need a schematic diagram for a HP4540s motherboard
Interesting user icon...........
I better get this right, huh? Bahahahahahaha!
Best I can do is a Block Diagram,
http://notebookschematic.com/?p=22530
Click on the diagram to enlarge.
Now what is the problem?
Need to know where to connect cables?
Need to know the Specifications to upgrade?
Problem with laptop, and you need to know what electronic components deal with that circuit?
DC - DC circuit (Charging / Power )
Motherboard chipset
Graphics chipset
Post back in a Comment.
Regards,
joecoolvette
Apr 11, 2013 | HP 15.6" ProBook 4540s B5P37UT Laptop PC...
Respected Sir, I want Intex notebook model no m73sr charging circuit diagram, Please help me.
The power supply (the inline module built into the power cable, which may be two pieces, is probably bad. That is the most common problem. Contact a dealer to get a replacement (the model number is on the power supply module) or get a universal one, set the amps the same and select the correct adapter. It will come with several so it will fit the power receptacle in your notebook.
Mar 17, 2013 | Computers & Internet
I have a gigabyte p4 pc, when i power it on the fan runs but it gives out a continuous beep. checked ram, processor on another motherboard, cleaned the motherboard, checked for loose cards and cables
The continous beep usually means a memory failure (RAM) or video memory if a plugin card is used.
Check to be sure the unit sees all of the memory, a weak power source( without AC adapter) could cause a partial failure of one memory card.
Another fault would be that the battery is very low on charge and won't accept any charge.
BAD Battery.
hope it helps
May 31, 2012 | Gigabyte GA-8LD533 Motherboard
I need schematic diagram for toshiba L6450 s4030 for power solution
Go to www.ebay.com Type: Make and model, refine search to mother board.
Apr 01, 2012 | Computers & Internet
Toshiba satellite l25-s121 is not getting any pwer from the battery or the power cord, no lights come on or anything. powercord is working fine and has been tested with a multimeter. battery was fully...
I have to say that if you get no power from the mains adapter and no power from the battery that is charged up, there is not a lot left that is user serviceable on the mother board.
Contact www.toshiba.com for technical advice and a possible repair.
Hope you get it fixed soon.
Feb 17, 2011 | Computers & Internet
Dear sir do you happen to have circuit diagram for acer aspire 5570 , the 19v dc power in connection pin broke in two. i need the schematic diagram for this power system board which lead to the...
Connect the adapter to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Sep 10, 2010 | Computers & Internet
Vostro 1000 wont charge also 2nd machine same model has a ic blown on mainboard where can i get a schematic diagram also is there a general known fault with the charging circuiton this model . Rgds
Schematics for Dells are generally unavailable.
The not charging is normally due to a failure on the charging circuit or damage to the power plug (If ac adapter will not run system or if you have to play with the power connection.)
Replacement motherboards start at about $75
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1000+motherboard&_sacat=0&_trksid=p3286.m270.l1313&_dmpt=Motherboards&_odkw=dell+1000+motherboard&_osacat=0
Oct 06, 2009 | Dell Vostro 1000 Notebook
HP Pavilion dv6000 dv6100 dv6200 dv6300 dv6400 Motherboard - 434722-001 Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
