Question about Garmin Nuvi 660 GPS Receiver
How do I delete an address on Garmin Nuvi 660?
  • 14 Answers
Select TOOLS, then MY DATA then DELETE FAVORITES then select the addresses you wish to delete.
Posted on Jun 18, 2009
Unfortunately the MY DATA option doesn't exist on the 660. You can delete a single address by doing the following:
1. Select Where to? / Favorites.
2. Select the address you want to delete
3. Select Edit...
4. Select Delete
To delete all addresses (favorites), do the following:
1. Turn the device off.
2. Turn it back on again, while pressing the top left corner of the screen.
3. Eventually it will ask you if you want to enter mainentance mode. Select Yes.
4. The bottom option should be something like "Delete all waypoints". Select this option.
This will delete all your favorites and some locale information, which it will ask you for again after it reboots.
Posted on Mar 16, 2010
  • 35 Answers
SOURCE: garmin nuvi won't turn on
Well , do you delete or add something in your NUVI before that occured.
Need more information.
Is that a new problem ?
What is the lassfrimware update ?
Posted on Jan 21, 2008
SOURCE: Garmin Nuvi 660 dead battery?
Normal 0 Garmin NUVI 660 instructions
It is pretty easy to open up your nuvi,(but not recommended by Garmin or me)...
looking at your nuvi from the back flip up the antenna. You will see two tiny torx screws on the antenna. Remove them and carefully seperate the antenna housing. Pay attention to how the antenna flex is seated because reassembling the antenna housing can be tricky. On the left bottom side the pin assembly that holds the antenna in is spring loaded. Pull the pin towards the center and you will be able to seperate the antenna housing from the unit. Underneath you will find two more tiny torx screws holding the main housing togather. Remove those two screws and you are almost home. Now you need the special plastic tool that you can get on ebay. The tool is used for opening ipods without mangling them. Gently pry the case apart with this tool. Start where ever it is easiest to get the tool in. Once opened you can figure the rest out for yourself. The battery is flat and rectangular and is seated behind the circuit bourd attached to the back cover.
Posted on Dec 26, 2008
SOURCE: Garmin Nuvi 660 lost Europe maps
Eventually managed to speak to a man at Garmin who confirmed that it was not loading any European maps because it didn't have enough spare memory to load them all. He said that he would email me instructions for freeing up sufficient memory, the email never arrived but I decided to delet all the voice languages that were no use to me and all the other language 'help' files and tried again - it worked.
At no point did I get a 'insufficiant memory' warning, which would have been very helpful, nor is there any guidance for how much memory will be required when embarking on the update. Take note Garmin...
Posted on Feb 28, 2009
the kowalski
  • 86 Answers
SOURCE: need to know how to reset home address....Picked wrong one.
To remove the Home Address, do the following:
  • Choose "Where to?"
  • Select "Favorites"
  • Find "Home" in the list
  • Press "Edit" -> "Remove" -> "Yes"
Your home position is now removed, and you can add a new one.
Posted on Jun 04, 2009
folks, the garmins have an on-board battery that needs to be powered up (at least occasionally) via the usb port - like from your computer. just using the dc car power cord does nothing for this battery. i've had this exact same problem on both my 760 and 780 nuvi units. fixed it using the usb charge. seems to run down differently for all the various nuvi models. my regular charge will hold for 7 hours on my old 660, my 760 and 780 work about 5 hours. my 'power up' failed on the 660 after 10 months with no internal battery charge, but the 7xx models only took about 5-6 months to 'fail.' hope this helps. jack b :-) in midland, tx usa
Posted on Dec 06, 2009
Hi, deleted some important functions from my nuvi 660. How can i get the software back again. Same software which is in the navigator when u buy it from any place. Pls urgent help needed
find the software needed on the below link:
http://www8.garmin.com/support/download_details.jsp?id=1921
If the above is not what you want, then you can perform a update. I assure you that updating will help ot reinstall the deleted software.
Follow instructions on how to update your nuvi 660 from the tips posted by me on the below link: http://www.fixya.com/support/r6547054-update_garmin_nuvi_gps
I hope this helps.
Good luck.
Nov 29, 2010 | Garmin Nuvi 660 GPS Receiver
How do I delete an address from recently found?
On a Nuvi, you can not delete just one entry in the recently found list. You have to delete the entire list.
- Jim
SHARCNET-USA
Jul 19, 2010 | Garmin Nuvi 660 GPS Receiver
I'm trying to reset the home address in my 2nd hand nuvi 660. can you help? thanks.
Go to "Where to?" then touch "Favotites" find "Home" the you can edit the address and phone #
Apr 03, 2010 | Garmin Nuvi 660 GPS Receiver
Need to know how to reset home address....Picked wrong one.
Jun 04, 2009 | Garmin Nuvi 660 GPS Receiver
Trouble with garmin 660 GPS
My Garmin 660 after going thru the initial start up of "loading map" it will just SHUTDOWN. I have tried to clear the data in the diagnostic menu as recomendated by Garmin support to no avail. At the start, the trouble is it will just stay in the loading map stage. Then later it begin to shutdown.
Jul 14, 2008 | Garmin Nuvi 660 GPS Receiver
Deleted MP3 files still play on my Nuvi 660.
Go to the GARMIN M3U file , open it and do what you want .Transfer, delete , copy and so so....
Dec 23, 2007 | Garmin Nuvi 660 GPS Receiver
Adresses
Well mine did the same thing. It was a simple fix, just go to the wrench -> map -> map info -> and make sure the box by your maps is checked.
Sep 03, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
6,904 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
