Question about Indesit IS70C Electric Dryer
How to reset dryer
I need to reset the heater element
  • 1,162 Answers
One way is to turn breaker off, remove power for a few seconds. Then turn it back on
Posted on Mar 30, 2014
Electric dryer won't heat
Thermal overload cutout tripped or is defective and needs replaced. Look for a red reset button near the heater element on the thermal overload. If no reset button, replace the thermal overload cutout. The timer itself could be defective, which will prevent power going to the heater element.
Sep 14, 2015 | Roper Dryers
Kenmore 240 volt compact electric dryer not heating model # 110.89182990
U need to check the heating element ,u know how are CALl for service
Mar 13, 2015 | Kenmore Dryers
Reset dryer
there are thermal one time use fuses and your heater element may also be faulty.
here are more info of fuse locations etc.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-3--RFBHVDc1MEVDIA==/GE-Dryer-doesn-t-heat
Jun 14, 2013 | GE Profile Harmony DPGT750EC Electric...
Samsung DV218AEW/XAA not heating
If the technician that came out told you he simply reset your heating element, he was not telling you the truth. Heating elements themselves cannot be reset. The element is either good, or burnt out and would need to be replaced. More common on modern dryers is that the thermal fuse on the side of the heater duct will blow out and needs to be replaced. This is usually caused due to poor air flow because of a lint blockage in the outlet duct. I would recommend calling a good, reputiable service company to repair the issue and to check the outlet duct as well. To get to the heater duct assembly, the top cover, control panel and front panel (including the door) must be removed.
Mar 25, 2013 | Samsung DV218AEW Electric Dryer
Zanussi white knight dryer - the dryer is not heating up. i have pressed the red reset button the back but no heat? the drum still rotates.
It is possible the heater element is faulty or a thermostat problem.
You need to test the element and stat's with a meter to check for continuity.
Dec 22, 2010 | Zanussi TD4100W Electric Dryer
Dryer won't heat up but tumbles. What could be
you could have a bad heating element, a tripped circuit breaker, a blown fuse in the dryer or a bad timer. you can check the element and fuses/ thermostats with an ohm meter for continuity.
Sep 17, 2009 | Dryers
Heating element
Hi Nichole, welcome to FixYa.com
The heater kit you need is a part number 395711.
You can get them here:
http://fisherpaykelparts.net/index.php?categoryid=112&productid=32
If you have been able to get to the reset, you are 90% of the way to the heater elements, they are located inside the aluminum "box" that the reset-able t-stat is mounted on.You take two screws out and the whole heater box can be pulled forward. Then you remove the two wires that are on the backside for the elements and it will come all the way out so you can remove the top half of the element box and switch out the elements. The kit comes with new thermostats as well, be sure to replace all the parts that come with the kit.
You can do it, it's not that hard,
Dec 29, 2008 | Fisher and Paykel DEGX1 Electric Dryer
ASKO T700
I had the same problem. Turns out the reset button on the back of the dryer needs to be pushed; when you push the reset button you should hear a click. If you do not hear a click the problem was probably not the reset button. The button shuts down the dryer heating elements if they are getting too hot and also keeps the drum from turning unless the start button is held down.
If you push the reset button and the dryer starts to work again, I strongly recommend that you stop the dryer and investigate why the heater elements overheated. In my case there was lint/hair build up on the heater elements themselves. Extensive dryer disassembly is required to properly clean the heating elements but it is worth the prevention of a house fire. While you're at it, clean the rest of the machine and the duct work.
Hope this helps
Jun 20, 2008 | Asko T700 Electric Commercial Dryer
Not heating
It is probably a thermal fuse. Take off the back of the dryer and you will see it on the lint outlet tube. It is white and is 1/2 inches wide and 2 inches long. It has two leads coming out hooked to wires. To check it just pull one of the leads off, turn on the dryer and touch the wire you took off to the other one and the burner should come on. It costs $12 at a parts store.
Jan 31, 2008 | Roper RES7646KQ Electric Dryer
Indesit IS70C Electric Dryer Logo
Top Indesit Dryers Experts
Tim Whalen
paul
paul
Are you an Indesit Dryer Expert? Answer questions, earn points and help others
