Question about Lenovo 3000 N200 0769 Intel Celeron 530 1.73GHz / 512MB DDR2 / 80GB HDD / DVD Player/ CD Burner / N... PC Desktop
Nvidia graphic software not installing
Trying to install the nvidia graphic software
My gf9400 gt 1gb shows blue screen, until booting it works but while loading win 7 it crash dump blue screen appears every time???? but after plug out graphic card and plug in onboard vga works fine what...
Hello bsod often means you have a driver problem, or a graphic card problem.
The graphic card could have a defect, this can cause the blue screen.
Try also to check the device manager, for any other drivers missing.
Try first to download and install the newest driver from nvidia:
http://www.nvidia.com/object/win8-win7-winvista-64bit-314.07-whql-driver.html
This is the 64 bit driver.
The 32 bit is here:
http://www.nvidia.com/object/win8-win7-winvista-32bit-314.07-whql-driver.html
If i am wrong by my selection, choose another here:
http://www.nvidia.com/Download/index.aspx?lang=en-us
Or use Automatically find drivers for my NVIDIA products, by installing a small bit of software.
If the driver update does not help, the graphic card must be renewed.
My advice is to uninstall ALL the old nvidia software, before you install the new.
Are the onboard graphic nvidia ???
This can sometimes create a conflict, when the graphic card brand are the same.
Try to disable the onboard graphic, in the device manager.
Good luck
Mar 05, 2013 | InnoVISION Multimedia Technologies Inno3D...
See guys i have sony vaio vpccw16fa laptop,all so my graphics driver is geforce gt 230m, my problem is when i install nfs "the run" my system giving message need to update the graphics to play it, nee
Hello here is the SONY homepage:
http://www.sony-asia.com/support/download/359171/product/vpccw16fa
The newest nvidia driver, can be downloaded here:
http://www.nvidia.com/object/notebook-win8-win7-winvista-64bit-314.07-whql-driver.html
My advice is to uninstall ALL nvidia software, before you install the new.
Hope this will help you
Mar 05, 2013 | Computers & Internet
I re-installed the operationg system (Microsaoft Windows 7) for Asus N5S3. It asked me to install the intel card and the Nvidia card; after intalled them the Nvidia is read as a driver in the Device...
Certain video cards are only compatible with certain processors on motherboards. AMD CPUs work with Nvidia and Intel CPUs work with certain graphics cards also. Are you sure it's even compatible?
Dec 29, 2011 | ASUS Computers & Internet
I have an ASUS P8 M 67 - M - EVO with an Intel Core i7 2600 K with an integrated graphics card Intel HD Graphics: Base frequency 850 MHz Maximun dynamic frequency 1350 MHz Features: Dual Display...
hi! nothing to worry!
it's a simple problem solved quickly! follow these steps!
sir! u first need to install graphics driver(nvidia graphics driver)
1. try to find the driver cd/dvd that u got along with ur motherboard( asus p8 m67 dvd) !
2. install nvidia drivers in ur pc!
3.then it ask u to restart and install ur magic bullet!
still wont found driver and error appears! visit www.driversdown.com then search for nvidia drivers.
still unable to found driver download driver genius pro software and install it it scans and show the required graphics software! select that tab and hit download !
that's it! ur problem solved!
Rate or Comment me if u like my solution!
Jul 23, 2011 | Computers & Internet
Windows 7 64 bit wont boot up unless I disable the nvidia. I tried updating the driver but this did not help.
How did you update driver? Did you use Nvidia? I can't find it at all through Asus. Do you get video through the Intel chipset with the Nvidia diabled? Anyway Nvidia has a download but I don't know what comes with it, and if you tried to download from Nvidia, you have to unistall the old software before installing new software for it to work right.Look in programs and features and see if you have any duplicate software. Do you by chance have an installation CD for your graphics? If so, I would do one of two things, if you have a CD, uninstall all Asus software, you will have the video graphics but, you may also have "Smart Doctor" and "OSD gamer". Again, if you have a CD uninstall all Asus software including graphics driver, gamer and Smart Doctor restart system, and re-install from CD. If you are going to try download from Nvidia, try uninstalling video graphics only, then download driver from Nvidia. If you have questions let me know.
Dave
Apr 25, 2011 | ASUS ET2400INT-B121E 23.6' Intel Core i5...
Unable to install drivers for my nvidia graphic card
Each driver has its own INF file are provided next to the driver download. You must replace the INF file with Modifed downloaded from nVidia. But before installing the driver did you install the NVIDIA drivers any other form? I had the same problem and I installed the driver provided by Dell original first, then updated to the current driver. Try not to install the new driver and the first thing will be done
Try a manual installation of the driver via device manager, the content of the driver is usually unpacked to c:\nvidia. Run the inf file in this folder. This trick always works for me when i come accross any system driver which doesn't works properly.
Jun 03, 2010 | Compaq Computers & Internet
Nvidia Geforce FX5200 128mb DDR AGP 8x
Hi, since you mentioned you installed an MSI card & it worked well. I can assume you changed the bios & to boot to the AGP rather than the Integrated 3D video. This is good. Notice the message you got from Nvivia. It could not locate any compatible drivers. This can indacates 1 of 4 reasons.
1. The 5200 was not completely incerted into the AGP slot.
2. The AGP slot is dirty & needs cleaned.
3. Nvidia software was installed but previouse graphics software was not removed (un-installed) before the installation of the nvidia software.
4.The card is bad.
Suggest you download the latest driver software from Nvidia.
Jun 17, 2008 | EliteGroup L7VMM2 Motherboard
Display adapter disappeared
Hello.
After installing new windows you should install all drivers needed by you computer. You should have a a cd utilities nvidia graphics card if you have not then you scan the driver it in web. try search in this website.
if it is build in to the mainboard better go to the manufacturer website of your board. hope this help
melnavz
Mar 31, 2008 | ASUS A7S8X-MX Motherboard
Nvidia Quadro4 (128MB RAM) driver required for linux 2.4.20.18.7
hi there..
here is the link for your Quadro 4 Graphics for linux 32 Bit
To download and install the drivers, follow the steps below:
STEP 1: Review the NVIDIA Software License.
You will need to accept this license prior to downloading any files.
STEP 2: Download the Driver File
Download - NVIDIA-Linux-x86-96.43.05-pkg1.run
SuSE users: please read the SuSE NVIDIA Installer HOWTO before downloading the driver.
STEP 3: Install
Type "sh NVIDIA-Linux-x86-96.43.05-pkg1.run" to install the driver. NVIDIA now provides a utility to assist you with configuration of your X config file. Please see Chapter 3 of the README or run 'man nvidia-xconfig' for details on usage. Instructions for those wishing to edit their X config file by hand can also be found in the README.
__________________________________
here is the link for your Quadro 4 Graphics for linux 64 Bit
Download - NVIDIA-Linux-x86_64-1.0-9639-pkg2.run
STEP 3: Install
Type "sh NVIDIA-Linux-x86_64-1.0-9639-pkg2.run" to install the driver, then edit your X config file as appropriate. If you are using a Linux 2.6 based system, type "modprobe -q agpgart", first. See the text README for more detailed instructions.
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Feb 19, 2008 | Nvidia Quadro NVS 280 (64 MB) Graphic Card
Open Questions:
lenovo 3000 N200 2048k ram passed Hay I am siva I am using the Lenovo 3000 N200( core-2) model laptop that system operation is vista but I am change to win- 7 professional 2 days have same hard drive corruption problem there showing all way this message A problem has been detected and windows his been shut down to prevent damage to your computer , If this is the first time you’ve seen this stop error screen, restart your computer .if this screen appears again, follow these steps Check for viruses on your computer .remove any newly installed hard drives or hard drive controllers, check your hard drive to make sure it is properly configured and terminated .run CHKDSK/F to check for hard drive corruption and then restart your computer . Technical information : Stop :0x0000007B (0x80D86B50,0XC000034,0X00000000, 0X00000000,) I am try to all when I restart the system there come windows error recovery launch startup repair ( recommended) then automatically go to the startup repair setup few mint check the repair then restart again go to the same setup start windows normally I try select the normally mode not go to the logon page again come same page how to solve the problem pl tell me I am try to all fun key nothing happened Phoemix TrustedCore(tm) NB Copyright 1985-2004 Pheonix Technologies Ltd. HDL10 BIOS Version 61ET33WW (V2.02) CPU = 1 Processors Detected, Cores per Processor = 2 Intel(R) Core(TM)2 CPU T5500 @ 1.66GHz 1024M System RAM Passes 2048K Cache SRAM Passed System BIOS shadowed Video BIOS shadowed Press [F1] for SETUP, Press [F12] for boot device selection menu Pressing F1 changes the bottom line to "Entering SETUP...", but nothing else happens. Nothing happens if I press F12.
Jun 01, 2012 | Lenovo 3000 N200 0769 Intel Celeron 530...
Lenovo 3000 N200 0769 Intel Celeron 530 1.73GHz / 512MB DDR2 / 80GB HDD / DVD Player/ CD Burner / N... PC Desktop Logo
12 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
