Question about Hartke Samson Technologies - SAM-XP308I - Samson Expedition XP308i Portable
Power Supply XP308i
I turne don my PA system and the power indicator light is flashing on and off also the remaining indicator lights are flashing and I an not getting any power. Can you help
  • Hartke Master
  • 3,320 Answers
Read the manual. SamsonTech
Posted on Mar 30, 2014
Power not going to tv
if your tv has no power light indicator at the front panel, it was an indication of power supply failure. if just a blinking light indicator that was mean an error detected by the main board.
Nov 19, 2012 | Proview PA-32JK1A 32 in. LCD Television
When you turn it on The blue light flashes and it returns to the red light and will not turn on
This is a power problem from the unit. The unit receives power into it but does not supply the power sufficiently enough to get the unit to function well. This is why the blue light flashes when the initial burst of power is sent into the unit but due to lack of follow up power the unit fails to remain on.
Best get an expert to identify if the power supply distributor in the unit is bad or the ic which is responsible for the distribution is the cause.
Hope this solution has been helpful?
Apr 10, 2011 | RCA RT2870 Theater System
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
Rca 42 in lcd it shuts off 5 sec after being turned on
This could be a power supply problem, these tv's use a series of switching mode power supplies usually mounted in the same circuit board , the light flashing is an indicator that this is the problem, but these boards are expensive so you may want to get the tv looked at before anything else. You do not mention if the sound remains in your description of the symptom, but just in case it does then a back light inverter could be at fault. hope this helps. thanks for leaving you feed back.
Aug 27, 2009 | RCA L42WD22 42 in. LCD Television
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
FLASHING RED LIGHT ON 360
Make sure that the power supply is cool loadTOCNode(2, 'whattotry'); The red light may indicate that the power supply is too hot or it has already overheated. If that is the case, you should let the power supply cool for several hours in a well-ventilated space. Turn off the Xbox 360 console and don't turn it back on while the power supply is cooling. This will allow the power supply sufficient time to cool. As soon as the power supply has cooled off, the power supply light will change from red to orange, and you can turn the console back on.
If the power supply light is still red after you have let the power supply unit cool in a well-ventilated space, the power supply unit may require replacement. You can contact Xbox Customer Support at http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to replace the power supply.
Make sure that the power supply is plugged in correctlyFor further details go to this link
http://support.microsoft.com/kb/906101/
Jan 03, 2009 | Microsoft Xbox 360 Console
Power supply light flashing.
Computer power supplys are modular replacement fixes. Better to replace the whole thing then try to repair.
Sep 24, 2008 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Dell Inspiron 600 Laptop, stop working.
This is generally a problem with the battery or a memory chip. Start by removing the battery and starting up on the power supply only. Dell batteries are notorious for causeing a no start. Then try removing the memory and try one chip at a time in both slots. If neither of these work, then I'm afraid you have a failed system board component, ans you will probably want to take it in for a professional diagnostics. Also, you can find a diagnostics light codes list for your machine at Dell's support site.
Aug 06, 2008 | Dell Inspiron 6400 Notebook
Hartke Samson Technologies - SAM-XP308I - Samson Expedition XP308i Portable Logo
112 people viewed this question
Top Hartke Computers & Internet Experts
David Payne
David Payne
Are you a Hartke Computer and Internet Expert? Answer questions, earn points and help others
