Power LED continously blinks
It and LG, and sometimes its does finally come on and sometimes it doesnt, the power LED will be flashing continously.
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Main system control IC fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 30, 2014
My tcl led TV picture blinks continously
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Jan 19, 2016 | Televison & Video
How do I fix no video on a LG 55lm6200?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 19, 2015 | LG 55LM6200 55 1080p 120Hz 3D WiFi LED...
How can I fix a LG 47" LED TV
Sep 14, 2015 | LG Televison & Video
Lg LCD TV power up issue
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Normally continious flashes of standby LED indicates a main board failure. Anyway, count the number of blinks as stated above, and make sure about the fault. Contact any service technician.
Sep 16, 2014 | Televison & Video
The capslock and the numlock leds r flashing continously. the screen is blank
How many blinks between pauses if there are pauses? Look at this chart.
Number of Blinks or Beeps Location of Blinking LEDs Component Being Checked Error Condition Continuous glow Battery power LED Battery The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook. 1 Caps Lock/Num Lock CPU CPU not functional 2 Caps Lock/Num Lock BIOS BIOS corruption failure 3 Caps Lock/Num Lock Memory Module error not functional 4 Caps Lock/Num Lock Graphics Graphics controller not functional 5 Caps Lock/Num Lock System board General system board failure 6 Caps Lock/Num Lock BIOS BIOS authentication failure Continuous blink AC power adapter LED Power adapter Insufficient power
Jun 30, 2011 | Compaq Presario Notebook
Power light comes on for about 30 secs, something clicks and both power and ocp lights start blinking contineously. the screen does not light up
I have this model of the sharp tv.Happen to me very often the Power and OPC LED light indicators blink continueosly.Not the power supply board,it the Tuner board that take in the comming broscast signal that have the problems.You still can used this tv.Push the power button sometime the tv it will work right away.Not,each time POWER and OPC lights continueosly blinks.Just push the power button again each time the POWER and the OPC continueosly blinks.Just have push power button again about 4 times each time Power and OPC blinks recycles,it will finally show the backlight and picture come on.My guest,if u do this by pushing power button to recycles about 10-12 times each time the POWER and OPC blinks it time to change the Tuner signal board.
Jun 03, 2010 | Sharp LC-C4655U 46 in. LCD TV
LG 700E monitor's power LED blinking continueously, no display
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Apr 08, 2009 | LG 500LC Monitor
The display flashes...
unplug everything. press power button continously for one minute.
helps sometimes. sometimes repeating multiple times helps. sometimes repairs the issue for a few months and then finally breaks for good.
Mar 23, 2009 | Gateway XHD3000 LCD TV
LG 700E monitor's power LED blinking continueously, no displaySolution.............
Jan 23, 2009 | LG Studioworks 700S 17" CRT Monitor
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
