Question about Karcher Garden
HOW MUCH OIL DO WE PUT IN KARCHER3030B AND WHAT SORT OF OIL
OIL IS LEAKING FROM KARCHER 3030B .could it be from the o ring rubber oil seal.How much oil do we put in in oil compartment and what sort of oil as getting original oil from karcher is very expensive
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
You need to know where oil is coming from. pump or motor? both will use normal motor oil
Posted on Apr 21, 2014
  • 14 Answers
SOURCE: where can i put lubricating oil for karcher jet wash machine
It sounds like you are referring to the oil in the swash plate housing. You can use a multi grade motor oil such as 20w50 or 10w40. Fill to about half way over the swash plate. If the old oil has gone amilky colour, please replace the oil seals first.
Posted on Mar 11, 2009
Testimonial: "post was very helpful and i am going to replace o ring rubber seal where i suspect oil is leaking and also fill it with oil.Thanks very much"
  • 46 Answers
SOURCE: karcher 520m oil leak
small engine shop should be able to obtain the proper gasket for you.....oil 20 weight fill untill you can see it at the bottom of the threads at the whole you pour it into!
Posted on May 25, 2009
MNfisherman
  • 11896 Answers
SOURCE: oil leak on karcher model k2.89m
You may need to replace the jug gasket or whatever gasket it is leaking from. If it is by a connection or line, you may be able to use silicone or o-ring
Posted on Aug 26, 2009
  • 15 Answers
SOURCE: Karcher K2.26M water leak
I have the same Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A manufacturing defect.. A New Manifold Complete Replacement K2.26* Part # 97501760 is $61.03, about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
Posted on Jul 13, 2010
SOURCE: karcher pressure washer leaking oil
Usually electric pressure washers only have oil on the pump, so its very likely that you will find the problem there. I'd say check all the pump seals and if that doesnt solve the problem, you can check to see if all bolts are tight when you close the pump back.
If by any chance you are looking for a new machine and/or parts for your machine, log in to www.roncoshop.com where you will be able to find pretty much anything for your preassure washer.
Posted on Jun 26, 2012
Leaking oil through the casing
up end the unit and get to the sump plate of the pump
remove the big screws that hold it on and there is a big"O" ring that is the seal
replace that "O" ring and use silastic blue sealer and reassemble it
Jun 01, 2016 | Karcher K2.26 Electric Power Washer
Karcher dirtblaster leaking at the end
If it's leaking it obviously has a bad seal or is broken. I would try to disassemble and see if it has a seal or not. Sounds like you could have a bad "O" Ring or some other type of seal leaking but I'd bet on an "0" Ring damaged or wore out. Dissemble it and see what is sealing it and proceed accordingly.
Gillight
Jun 26, 2012 | Karcher K2.26 Electric Power Washer
What causes the oil to leak?
1. Oil generally leaks because of mechanical failures.
To contain oils there needs to be a mechanical seal of some sort. This may be for the sake of argument a rubber ring or a flat strip or gasket seal of an appropriate material or even a propriety sealing agent which can be squeezed from a tube.
Simplistically a jar can be filled with oil and the lid which has a seal in it is placed on top secure enough to stop the contents leaking.
If that jar is connected to other jars by pipes to form a system they too need to have seals inserted where they join the jars so that there there are no leaks.
2. Seal failures can be caused by heat, chemical corrosion and or erosion , mechanical stress such as vibrations or bending or longevity of material properties such as the elasticity depreciating. Finally other causes can be attributed to wrongly fitted or inappropriate types of seals being fitted.
May 12, 2012 | Brother EF4N21 Sewing Machine
Oil leak 2000 alero, just replaced plug, not it, leaked out all the oil after I drove it 20 miles, please help, could it be a gasket or what
Check the oil filter. The old gasket might be stuck on the engine (two gaskets stuck together), or the new gasket might be defective, misaligned or missing.
Nov 05, 2011 | 2000 Oldsmobile Alero
Water leaking out of the bottom of the pump - low pressure leak, light stream
Will be a gasket, o-ring or seal that has blown. Could even have a cracked fitting or a split hose.... remove housing where leak is coming from and inspect. call service part agent and order new part (make sure you grease seal or o-ring with rubber grease. If it is a gasket you may need to use a gasket sealant and find out what the torque setting are for the component you have disassembled.
General quide is: 10mm head = 10 - 12 newton meters 12mm Head = 18-20 newton meters
Hope this helps... hard to diagnose accurately with your vague description
Feb 10, 2011 | Karcher 2500 PSI Pressure Washer
Oil is leaking from around the oil filter
The rubber O-ring from the previous oil filter most likely stuck to the engine when filter was replaced. Remove oil filter and ensure only 1 rubber O-ring is sealing the oil filter to the engine.
Jun 19, 2010 | 2004 Nissan Titan
Oil is leaking from where the oil filter screws in. Is that the oil pump? Only leaks when car is running, kind of pours out! I replaced the oil pan gasket and its leaking from that thing that te oil filter...
Did you check the old oil filter if the Oring is present when you remove it? If the not, the old Oring is still there, so, you have two Oring there, that's why is leaking. Remove the new oil filter and remove the other one O ring, the old one and then install it back, and don't forget to wet with oil the Oring before you install it back. ok
Feb 06, 2010 | 1988 Acura Legend
Karcher 520m oil leak
May 24, 2009 | Karcher 2500 PSI Pressure Washer
Where can i put lubricating oil for karcher jet wash machine
Feb 22, 2009 | Karcher K2.26 Electric Power Washer
Garden Logo
710 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
