Tdk ticr100p It won't turn on
My TDK 8GB memory stick won't show up on the PS3
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
hope it helps
May 13, 2012 | TDK Electronics - Others
Sony portable DVD player dvp-fx970 won't play dvd
Use lens cleaner TDK or wash dvd disks with hot tap water then block off the water drops.
Feb 08, 2012 | Sony Televison & Video
TDK fdd-100 external floppy drive won't mount
check the leads that attach this external floppy drive make sure they have a good secure connection
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
hope this helps you
Oct 31, 2011 | TDK External USB Floppy Drive FDD-100AX...
I just opened the box of my new tdk 2-speaker boombox. I read the manual and it says as soon as I turn the left nob, it should turn on. The only thing that is turning on is the tiny monitor...nothing else....
Email or call customer support. It is a firmware issue that requires the unit to be returned to TDK. once contacted they will email you a return postage label Once the unit is recieved they will send you a new boom box
Sep 15, 2011 | Audio Players & Recorders
I need the manual for TDK DA -5900 4x Digitakl audio CD receiver
Asking the question a thousand times won't get a faster answer but a Google search will.
You'll have to register for free to get it here.
http://www.hifiengine.com/manuals/tdk/da-5900.shtml
Jul 19, 2011 | TDK DA-5900 2-Disc CD Recorder
TDK iVIBE users manual needed ADS-70BLK
Most of the functions are the same as the TDK iSLIM, and the user manual for this is available on the TDK website, http://www.tdk-media.com.sg/sg/products/peripherals/manual/iSLIM.pdf
Jan 11, 2011 | Audio Players & Recorders
53 people viewed this question
 Grubhead
Grubhead
