Question about Rangemaster Toledo 90 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
How do I replace a ceramic top to my rangemaster Toledo 90 cooker
Replace cracked ceramic top
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 176 Answers
This job is for qualified person. Is not recomadet to doit yourself.
Posted on Mar 30, 2014
SOURCE: how to fit a flame failure device to rangemaster 55
the part that you need is the oven ignitor, located nest to the oven burner. that part gets hot to open the gas to the burner, that will make the oven work again.
Posted on Dec 08, 2008
FitzOriginal
  • 842 Answers
SOURCE: Timer instructions for a Rangemaster Toledo dual fuel 90 required
OK, here we go, this is actually a fairly lengthy explanation, but I will do what I can to explain.
The timer can be used to turn just one, or both ovens on and off automatically, however the start and stop time must be the same for both ovens, though different cooking temperatures can of course be set, so if you play around with temperatures to extend the cooking time of an item in one oven, you can often cook items needing very different settings for the fixed time you set in both ovens. Note that when the timer is on and the AUTO message is on the display, the ovens are disabled and will ONLY work during the timed period unless the timer is disabled again. (This is a common problem when you first power up, because the AUTO setting is automatically engaged on installation or power up after a power cut, disabling the ovens until you figure this out!). So, with all that garbage out of the way, how to use the timer settings:
For ease of understanding, I will refer to the buttons on the control pannel (Running from Left to Right as: BELL, HOT DISH, COLD DISH, HAND, + and -)
TO TIME SOMETHING THAT'S ALREADY COOKING (Minute Minder). Press and hold down the BELL symbol (Far left), use the + or - to adjust the amount of time you want to cook for (You can check time remaining at any point, or cancel the beeper when the time is up, by pressing the bell button.
TO STOP AUTOMATICALLY AFTER YOU HAVE MANUALLY STARTED COOKING. Press and hold the COLD DISH button at the same time use + and - to adjust your required stop time. AUTO will show on the display. When cooking is finished, the beeper sounds. TURN THE OVEN TEMPERATURE KNOB TO "0" FIRST, then press the HAND button, once to stop the beeper, and again to cancel auto and return to manual mode.
TO START AND STOP THE OVEN MANUALLY: Before you start, decide when you want the cooking to stop and how long you want the food to cook for (The cooker will work back from your stop time and figure out the START time for its self.). Press and hold down the HOT DISH button and at the same time set the minutes and hours you want the oven to cook for with the + and - buttons (You are NOT SETTING THE TIME HERE, you are setting how many minutes and hours to cook. Next, press and hold the COLD DISH button and use the + and - to set the stop time (YOU ARE SETTING A TIME IN THIS OPERATION). AUTO will show on the display. Set the temperature for the oven (or both ovens) that you want to auto cook with. When cooking stops the beeper sounds. Press the HAND button to cancel the beeper and press the HAND again to cancel AUTO and return to manual mode. (Note that the beeper stops after a while if you leave the oven attended, but the manual states you still have to press the HAND button twice to return to manual, I have not personally tested this).
GETTING BACK TO MANUAL MODE. If AUTO is showing on the display, because you have set automatic and no do not need it, or you have just powered the cooker up, any cooking time already set must be returned to 0:00 before you can return to manual, so hold down the HOT DISH button and ensure the display is set to 0:00, once you gave done this you can press the HAND button to return to manual mode
Posted on Jan 23, 2009
SOURCE: RANGEMASTER 110 Cooker FLAME FAILURE DEVICE fitting
My progress to date (20090127):
1 Turn off the gas supply to the oven
2 Turn off the electricity supply
3 Remove the oven linings
4 Remove the storage drawer
5 Remove the three screws holding on the bottom trim and the trim
6 Crank up the front roller
7 Pull out the oven carefully making sure the gas hose and electrical lead are long enough and not caught
8 Working from the rear of the Rangemaster, for the right-hand oven, remove the four screws on the corners of the large cover plate at the back of the oven about half way down on the left-hand side as viewed from the back.
9 Remove the cover plate.
10 Go to the front of the oven. Above the burner assembly, towards the left is a thin metal rod running front to back. This is held in place by a clip at the back and by the hole in the metal frame at the front. Remove the metal clip at the back using a pair of long-nosed pliers. Retain the clip.
11 This should release the metal rod (flame sensing device) and you should be able to push it through the hole and out at the back. It is attached to a long copper wire.
12 Go to the back of the range. You should be able to work the wire back through the hole in the rear metal plate and up to the gas valve. The wire is held in place at the gas valve by a bent clip on the rear right. Carefully bend this clip back towards the oven to release the wire.
13 The wire goes down under the gas valve and to a threded bolt end into the bottom of the gas valve ad the bolt is held in place using a locking nut.
14 Remove the locking nut using a small spanner. The threded bolt should now turn, with the aid of long-nosed pliers.
15 The next trick is to remove this threaded bolt on the end of the copper wire and I have not figured out how to do that. It will unscrew a good way but becomes tight and will not come out, as though something inside the valve is holding it in place. Could it be that the flame sensing device has to be removed and inserted from inside the gas valve? If so, what a daft piece of engineering this is.
16 HELP.
Posted on Jan 27, 2009
  • 188 Answers
SOURCE: Cleaning the outside of a rangemaster toledo duel fuel cooker
vinigar might work
Posted on Mar 26, 2009
DeBruce
  • 145 Answers
SOURCE: Ceramic Hob Stained and Marked
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Posted on Aug 24, 2009
Rangemaster Ceramic 110 randomly trips the MCB.
Electric rangemaster tripping electric - what size mcb? ' DIYnot ...
www.diynot.com > Forums > How to... > Electrics UK
Apr 6, 2013 - Cooker occasionally trips the 'Wylex B32 MCB' when almost everything is going. ... http://www.ebay.co.uk/itm/Rangemaster-Leisure-110-Electric-Cooker-/ ... Find the total load via the site below, a ceramic nit is 14kw shock:
Oven or cooker tripping electric, what to do next? - YouTube
? 3:11
https://www.youtube.com/watch?v=O42p_tWYgAU
Dec 21, 2011 - Uploaded by Richard Saupe
Hi Richard, i recently bought a all electric rangemaster cooker second ... I'm asking because our oven trips the breaker when we try to turn it on, ...
Frequently Asked Questions ' Rangemaster
www.rangemaster.co.uk/rangemaster-owners/faqs
For earlier specification110cm models, remove the storage drawer and the silver ...Ceramic and Induction models may be connected to a suitable 6mm cable ...
http://www.diydoctor.org.uk/forums/electrics-forum.html 2015-12 ...
www.diydoctor.org.uk/forums/electrics-forum-f182.xml
Jan 19, 2016 | Rangemaster Range Cookers Kitchener 110...
Can i fit a glass lid to my Rangemaster Toledo 90? It has never had one fitted and wondering if one can be fitted. Thanks
No not if it has never had one fitted by the manufacturer as it wont have a safety device fitted to close the gas supply in the advent that the lid is closed while a burner is still a light which would shatter the safety glass and cause injury to the user. Some glass lidded cookers where imported to England when i was an apprentice gas engineer and no safety device fitted and the lids exploded and where soon made illegal.
Apr 13, 2015 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Replace ignition button
Hello Angela,
does your cooker looks like this one?
Then one of the very small buttons should be for the ignition.
To replace that, you need to remove the control board, as they are screwed at the back.
So work for an engineer.
But I know a much easier way.
Clean your button with brake cleaner, or thinner or something like that.
Try to find the cheapest spray can with silverpaint.
Be shure that you have covered all the parts that you do not want to be sprayed and only spray that part of the button that needs to be silver.
Every one will tell you that you are an Expert.
Good luck with it, Dik
Sep 07, 2017 | Rangemaster Toledo 90 (Dual Fuel) Dual...
We bought a brand new dual fuel Rangemaster cooker and the adaptation of our bungalow and building works have now been completed and ready for the cooker to be installed. However, my husband ( who has a...
I used to have the same range with 2 electric ovens, but it is available with the lower large oven on gas and the tall oven electric.
The manual for theToledo with tall electric and large gas oven can be found here:
http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/Toledo90Gas.pdf
The manual for theToledo with both electric ovens can be found here:
http://www.rangemaster.co.uk/media/575792/toledo%2090%20dual%20fuel.pdf
The main product page for the toledo 90 can be found here:
http://www.rangemaster.co.uk/range-cooking/toledo-90.aspx
Sep 16, 2011 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Warmer lights up but not getting hot - Rangemaster Toledo XT
Hi Sally
I havd exactly the same problem. I contacted Rangemaster/Aga support line (0845 603 5312 if in warranty, 0870 789 5107 if not) and they told me the heating element was shot.
My cooker is 2 1/2 years old, so out of warranty, but they were good enough to send me a new cooker top (top left hand side only of course) free of charge!!!, I just have to get it fitted.
You have to replace the whole left hand side of the cooker top too - the burner that the wok goes on!
Good luck
May 08, 2009 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Dec 07, 2008 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Rangemaster toledo DF 90 what is the minimum door width through which these cookers can be fitted?
Yes, the handle, doors and knobs can all be removed, in fact (If I remember correctly) the unit is delivered with at least the handle/rail at the top not fitted. I would still suggest that you visit the supplier with a tape measure and suggest that if they want sell you a unit, they reassure you by showing you a packaged unit, or demonstrate the removal of the handle.
Sep 24, 2008 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Faulty plate warmer on rangemaster 110 dual fuel
We have the same problem on a Rangemaster Toledo 110. It is not a fuse.
The 'Hot' light still comes on because that is a different (parallel) circuit.
Examination by a competent electrician has found that the soldering for the wires that power the warming metal strip under the glass is faulty. You will have to ask for a replacement part.
There may be a design flaw, so you might want to enquire about the professional all gas burner top and just use the griddle as a warming plate over the second wok burner.
Good luck.
Jan 20, 2008 | Rangemaster Classic 110 (Dual Fuel) Dual...
Range master toledo 90
I would follow these requirements if I were you:
The cooker must be connected to the correct electrical supply as stated on the voltage label on the cooker (This is obvious so far!). It should be connected through a suitable cooker control unit incorporating a double pole switch having a contact separation of at least 3mm in all poles (This means one of those big red switches with "COOKER" written on them). The cooker must NOT be connected to an ordinary domestic power point. The cable size used should be between 6mm squared and 10mm squared twin and earth. Where the installation is protected by a 30 milliamp sensitivity residual current device (RCD Breaker), the combined use of your cooker and other domestic appliances may occasionally cause nuisance tripping. In these instances, the cooker circuit may need to be protected by fitting a 100 milliamp device. This work should be carried out by a qualified electrician.
Oct 28, 2007 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Rangemaster Toledo 90 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
99 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
