Agitator barley turns and the belt is slipping,
Agitator barley turns and the belt is slipping, the motor is turning, not sure why the agitator is stiff to turn, is there a bearing on the shaft that is siezing up? There are threads on the back of shaft that the pully sits on but no nut holding it on and did not see a set screw either, trying to find out how to remove pullt to inspect shaft.
  • 15,935 Answers
It appears your tub bearing has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
Smoke come in out while spinning
Don't know what machine you have if it has a belt check it. Take belt off & see the motor turns freely also with the belt off see if you can turn the drum if one of them won't turn the belt will slip & cause burning smell. Small clothes getting under the agitator even sometimes in the pump can cause this , check under agitator & check the pump it may not turn if a sock or something gets in it & this can cause the belt to slip. If these seem ok put it in spin & watch the motor it could have a short & will smoke. Good luck
hope this helps.
Nov 22, 2017 | Washing Machines
Kenmore 80 Series 110.27802690 agitator barely moving
It's the transmission that's bad. The motor turns one direction to spin and the opposite direction to agitate. The transmission converts the constant belt speed from the motor into the back and forth motion. In the other direction, the transmission stops and the whole system spins.
(I don't suspect you have it set to "delicates")
Jul 20, 2016 | Kenmore Washing Machines
How to replace belt instructions
Disconnect cleaner from electrical outlet.
1. Place handle in operating position and turn cleaner over so bottom side is up.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear. Repeat in left-hand slot.
3. Lift extension of bottom plate, rotate plate and remove from cleaner body.
4. Remove agitator and broken agitator belt.
5. Slip agitator through new belt. (With lettering toward outside of cleaner) and position belt in belt guide. Push end of belt into opening in cleaner body. Reposition agitator making sure to align flat sides of projection on belt end of agitator with flat sides of slot in cleaner body.
6. Place the three tabs on bottom plate into slots in front of cleaner body. Snap bottom plate into place over agitator.
7. Remove hood by turning cleaner over and removing nozzle control knob on front of hood -- grasp knob and pull up.
8. Place handle in operating position and turn cleaner over. Insert end of flat screwdriver into one of the four slots beside an arrow on bottom of cleaner.
9. For slots nearest the rear wheels, push handle of screwdriver toward cleaner handle; for remaining two slots, pry outward to release latches.
I0. Turn cleaner over and lift off hood.
Il. Stretch new belt onto motor pulley.
Extra effort may be required to stretch new belt onto pulley.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide.
Aug 08, 2014 | Hoover Vacuums
How to belt replace instructions
Hi! Below are instructions to replacing the belt on a Hoover U5064-930.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear.Repeat in left-hand slot.
Hope this helps!
Aug 05, 2014 | Hoover Platinum Lightweight Upright Vaccum...
Hoover cleaner model u5057-930
Hi! Below are step-by-step instructions on how to change the belt on your U5057930.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide. Hope this helps. If you have further questions feel free to reach out to us hear on Fixya!
HHdedd
Aug 02, 2014 | Hoover Vacuums
How to change belt on hoover runabout 44258-930?
Jun 28, 2014 | Hoover Runabout U50-940 Bagged Upright...
How to change a belt on a hoover u 4266-940?
Hello! Below are instructions for replacing the belt on your U4266940.
Hope this was helpful!
Jun 20, 2014 | Hoover Soft Light U4266-940 Bagged Upright...
More on my frozen maytag spin, motor seems to continue to run (i.e. the pump belt is turning), but the agitator belt is slipping. I assume this is the switch that is screwed down to the motor, about $60....
Okay here is another thought... are your sure that it isn't the pum that is getting tight and seizing up when you turn it in that direction?? Maybe you need to disconnect the coupling and spin just the motor and just the pump to see which it really is that is causing the problem.
Still don't think it is the brake...
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 24, 2009 | Washing Machines
Washer will not agitate but will spin
It sounds like the plastic inside the agitator cog are worn. The smell is the plastic cog turning but the agitator not turning.
Take off the top of the agitator. If any screw are available remove them. If not grab the agitator from the bottom and yank off. Unscrew the agitator drive cog and inspect underside of agitator. Go to an appliance repair shop and reorder a new one. Between $15-30.
Mar 05, 2008 | Frigidaire GSTF1670A Front Load Washer
You are correct that motor turns one direction for agitate and the other for spin. The problem you describe sounds serious but there is a chance it is not. First, try to turn the transmission by hand. If it wont turn by hand, remove the agitator and see if something has gotten under it and has it locked to the basket. To remove the agitator, pop off the top cap and look down inside. You will see the bolt that holds the agitator on. After you take it loose the agitator will slide off.
If there is nothing there, the transmission will need to be replaced. If the washer is less than 5 years old, the transmission may still be covered by warranty. Check your owners manual for warranty details. Post back to let me know what you find out.
Oct 21, 2007 | Maytag Atlantis MAV6260AWW Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
