Question about Samsung 50 in. Plasma TV
Swapping a samsungln46a750 screen with a ln46a550 screen. Would these parts be compatible?
I need to get another screen
    Top Expert:
  • Samsung Master
  • 75,178 Answers
No. These are not compactible.
Gopakumar Gopalan Google
Posted on Mar 30, 2014
Samsung LCD TV 46 inch LN46A550 colors are all messed up.
My solution to that pixelation color problem was replacement of the flat wire connected to the Tuner board and video data board,must be new and original replacement part. I clean the terminals(don't brush just spray on)with electronic contact cleaner,let it dry or blow dry with hair dryer to vaporize left over liquid on both boards.Reason these flat wire problem is due to environmental(moisture)corrosion and breakage of the folded parts of the wire. I tested the replaced part and found breaks or cut ,we call it in electronic term"open connection".
Dec 18, 2012 | Samsung LN46A550 LCD TV
Samsung LCD TV 46 inch model LN46A550 has bright pink glow where it should be light (sky, lamp, etc)
My guess would be that you have a CCFL lamp that is failing. They will give off a pinkish tint when they are about to fail. But I would encourage you to get a professional diagnoses.
Oct 03, 2012 | Samsung LN46A550 LCD TV
Can you fit a cbr 1000 engine in a 2002 Honda CBR 600 F(4)I frame?@
Hi, Anonymous parts swapping is common with most motorcycles when it comes to interchangeable or compatible parts from one model with another the best thing to do is call your local Dealership Parts Department or a reputable independent shop. If your location is not near a shop then go online and find a parts catalog or "FICHE" and match part numbers depending on your criteria.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
91 cbr 600 f2 engine swap questions CBR Forum Enthusiast forums for Honda...
http://www.fireblades.org/forums/honda-cbr-600/46464-f2-engine-swap.html
Honda CBR600F4I 2001 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CBR600F4i Owner Manual
Sep 23, 2012 | 2002 Honda CBR 600 F(4)i
Vertical lines left half of screen
You might be advised to look on EBAY for someone junking one for the parts----I do MFR. warranty work and from most makers it is nearly impossible to get replacement ribbon cables for sets....you sound smart so are aware issue could be inside the display panel as well....
Jun 09, 2012 | Samsung LN46A550 LCD TV
Cracked screen
This is the end of the road for this set----the screen is part of the DISPLAY PANEL--ENTIRE front screen unit and if damaged it is fatal.
Cost of the replacement part alone will exceed the cost of the set new or replacing it with a new set.
sorry, but the Panel's are very fragile in nature.
May 21, 2012 | Samsung LN46A550 LCD TV
Right side of screen distorted
if the distortion looks like sideway lines with weird trails and double images its most likely a tab bond issue. If its straight vertical lines then its likely the Tcon
Mar 29, 2012 | Samsung LN46A550 LCD TV
My screen have a red line when opening,and the screen has a dotted red color..what happen to my LCD? Thanks.
It is probably the LCD inverter. When the inverter is bad or damaged the screen will show red lines and tints of light red. The inverter is not part of the LCD so it would be replaced without you needing a new screen. The process in fixing it is not difficult, the hardest part is just getting to the inverter to swap it out. New ones can be found on eBay and they don't cost very much.
Good luck!! EJ Kudelka
May 03, 2011 | Lenovo 3000 G230 COMPATIBLE LAPTOP LCD...
I have a LN46A550 flatscreen...the picture is now only in the upper left hand part of the screen. It's basically 1/6 of the screen. I have tried to pull up the PIP function on the remote and it will not...
there should be a ratio button on the remote if not its deffinitly in the main menu click on 16/9 wide screen you seem to have the veiw secound channel working on you set but were is the big picture of the current show? anyhow try that and let me know how you went
merry christmas
Dec 22, 2010 | Samsung LN46A550 LCD TV
2007 Saturn Ion Sedan Power Steering failure
if you replace or swap just the power steering motor there is nothing else you need to do,,but if you replace a control module you might need to program it,,,some new module come empty and u need to program it,,,and other ones that are used and u swap it need to be relearn to the car or you might get a check engine light on,,,,for it not being learned by the other modules,,they talk to each other
Mar 11, 2010 | 2004 Saturn ION
Screen calibration
want to get the best picture possible out of my Philips 42PFL3603D HDTV. Any recommendation on screen settings or software to help with this?
May 26, 2008 | Televison & Video
Samsung  50 in. Plasma TV Logo
Jerry Greenberg
Jerry Greenberg
