Question about Electrolux EW30ES65GS 30" Slide-in Electric Range with 5 Radiant Elements, 4.2 cu. ft. Self-Cleaning... Range
MX50I E11 WHAT IS THE MEANING OF E11
What meaning about E11 ??
If you go to google and put the brand and the model # along with the error code in question form you will get answers
Aug 01, 2015 | Washing Machines
What is meaning of E 11 code at the end of the cycle
What model number?
E11 frequently means that the dishwasher is running without heating. If your hot water is hot, and you don't sanitize your dishes and they are coming clean, you can safely ignore it. It could be a loose wire or the heating element is dead. It is part of an assembly and usually not separately replaceable. If the heat is not running, the error likely comes after a period of time during which the water does not heat. It could also be a faulty sensor, usually part of the same assembly.
If you dishwasher works and is old and still cleaning, it is probably not worth fixing this.
Oct 18, 2014 | Bosch Dishwashers
M frigidaire washer model gltf2940fs1 shows me a e11 code
Thanks for your post, friend!
From my understanding your Frigidaire frontload washer, GLTF2940FS1, is displaying an "E11" error code. Typically, "E11" stands for fill time too long which means you could have an issue within your pressure sensor or control board. I would recommend a reset on your washer and that can be done by flipping the household circuit breaker off for ten minutes. If that does not help correct the issue you may want to consult with a technician for proper diagnosis. I hope this is helpful. -Matt
Oct 15, 2014 | Frigidaire GLTF2940ES Front Load Washer
Eternal hot water heater error code e11
I cannot find what e11 means but it seems most people have just unplugged it an it came back on. Code goes away.
Mar 29, 2014 | Eternal Hybrid Tankless Hot Water Heater...
E11 code on the dispay
Error code E11 is a dryer thermostat problem. The wiring, by design, is too short, and secured too tightly up and behind the digital display, and extends to a connector located on the machine's drum housing. When the machine is in motion, and there is a degree of drum movement back and forth, left to right, the wire disconnects resulting in Error code E11. Your issue may be that the wire is loose, and not fully disconnected (yet) hence the fault being intermittent. Error code E11 requires a service engineer to reattach the thermostat wiring in a way that allows for the drum housing to move, as per it's design, without the wire being disconnected from the drum housing connector, when the wash load becomes unbalanced during the wash cycle.
Oct 20, 2012 | Washing Machines
Error code E11 on hoover washer dryer vhw854d
Nov 12, 2010 | Hoover Washing Machines
FAFW3577KWO washer-code E11 washer will begin wash cycle and stop after 5 or 6 minutes. display reads PAU- when start and cancel buttons are simultaneously pushed I get an E11 code. What is E11?
Your machine may have short circuit with the inlet valve since you are facing problem after 5 to 6 mins you are suppose to change the inlet valve
Dec 24, 2009 | Frigidaire ATF6000ES Front Load Washer
My washer dryer wont dry it comes up E11
e11 indicates problem with water supply.Check inlet hoses and water valve
Oct 20, 2009 | Washing Machines
Konica - warning code E11
What model of which make Konica or Minolta?
May 19, 2008 | Konica Minolta Office Equipment & Supplies
Electrolux EW30ES65GS 30" Slide-in Electric Range with 5 Radiant Elements, 4.2 cu. ft. Self-Cleaning... Range Logo
22 people viewed this question
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Robert Plante
Andrew Taylor
Andrew Taylor
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
