Question about Kitchen Appliances - Others
Manual for Rapid Steam Supreme KA-15
I am looking for the manual
I am looking for Intructions on how to us a Rapid Steam Supreme KA-15
I am not an expert but I see a steam machine two three times and they always use this in a close area. May be it will help you.
Roasts BBQ Catering
Jan 09, 2014 | Sewing Machines
Manual
Hold the coffee button down from the moment it is pressed till the water in the cup reaches the desired volume, then release. It will now save that volume amount to memory.
Jun 13, 2013 | Solis Palazzo Rapid Steam Palazzo Fully...
Container leaking water
Ther is tank seal that is at the base of the machine where the tank goes on . it will dry up , waer out and leak overtime.
Apr 20, 2013 | Solis Palazzo Rapid Steam Palazzo Fully...
How to decalcify coffee machine Saeco royal digital
Hi
Your showing a different machine than a Royal and that one is different, but if yours is a Royal, this is how.
Auto descale: To automatically descale your machine, press the scoop or menu button and hold it down until you enter the menu. Use the arrow buttons to scroll up until you come to Descale. Press enter button and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Manual descale: To decalcify your boiler, remove your water tank and fill it with hot water (100 to 120 degrees). Open a pack of decalcifier and mix into the water tank. Place the tank back on the machine, then turn the machine on.
  1. If you have a non-rapid steam machine, just open the steam knob and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes. It is very important that the machine does not remain on to heat the boiler anymore than necessary.
  2. If you have a rapid steam machine, turn on the machine and then push the hot water button. This turns off the rapid steam and allows you to run hot water/solution through the steam wand. Just open the steam valve and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes.
  3. Repeat step #2 for your type of machine. Do this until you have used the entire water tank of solution (approximately four to five cycles). Remove the water tank and rinse it with fresh water.
  4. Refill the water tank with fresh water and place it back on the machine.
  5. Repeat step #2 to rinse the machine, only this time use the entire water tank at one time, and there is not need to let it set.
  6. Your machine has been decalcified. You may still have scale in your boiler, but not as much as you had before. To reset your descale light, hold down on the steam button for at least five seconds. You are ready to brew, once your boiler has heated up.
Nov 12, 2010 | Saeco Incanto Classic Espresso Machine
Can you give me instructions on how to decalify the coffee machine in this photo as l have the same.Thank you Barbara
Auto descale: To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Oct 31, 2010 | Saeco Royal Digital Plus Coffee...
I don't have a manual and need to decalcify my saeco stratos. I know I have to buy a bottle of descaler. What do I do then?
Don't use vinegar or CLR or any chemical used in the bathroom. Auto descale: To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Oct 29, 2010 | Saeco Stratos Coffee Maker, Espresso...
Need to decalsify
Oct 28, 2010 | Saeco Royal Professional Espresso Machine
Wanted instructions for hinari steam supreme no st450
you will get any Hinari manual with the manualfox search engine. Check results here:
http://manualfox.com/link/hinari.htm
Oct 17, 2009 | Hamilton Beach Steam Excel 14770 Iron
2003 Ford KA engine light on, spluttering and steam from engine?
Scott,
If you're ever driving along again and you smell coolant, see steam, or your sensor (thermometer) shows up on your dash again...IMMEDIATELY stop the car in a safe place and turn the engine off!!!!!
You may have gotten lucky this time, but I can't say that for sure because I can't see your car.
The thermometer is an indicator light telling you that for some reason your car is overheating (not circulating coolant). It could be the thermastadt is stuck shut, coolant is low, hole in the radiator hose, water pump is shot, and on and on, and on.
When you run a car's motor that hot you stand the chance of warping the heads (big dollar repair item).
I would strongly suggest that you call a tow-truck, and have your garage/mechaninc look at it. It will be alot cheaper this way instead of having to repair warped heads and any other damage from runing the car that hot.
I hope this helps you, and thanks for letting FixYa.com make your day brighter
Jan 04, 2009 | 2005 Ford Focus
Kitchen Appliances - Others Logo
44 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
