Question about Uniden Radio Communications
Stuck on channel 5 - Uniden Radio Communications
    Problem Solver:
  • 7 Answers
Do you have a lock function? If so, turn off the lock, probably by holding down the lock control for a second.
Posted on Apr 08, 2014
My LG LCD TV cant stop changing channels on it own . I ve removed the batteries from the remote but still its changing them on its own
Is it going one way - channel 1-2-3-4-5 bottom to up or any way at random. Find out which way and check the channel button on the TV to see if it is stuck.
Mar 17, 2011 | LG 37LD450 37 in. TV
My mintek dtv-373-d is stuck on encrypted channela nd will not do anything else. I can't get the menu to come up or anything to change. help
I'm assuming you have Cablevision. This is becoming a known problem with their broadcasting system. They have been upgrading and it has been causing the TVs to freeze up on a specific channel .
Simple way to fix it:
1. Unplug tv
2. Unplug coax from tv
3. Plug tv back in
4. In the Menu go to Setup > CH setup > CH Memory > Cable (digital)
5. Enable channel skip for channel that it is currently stuck on
6. Push Menu to exit
7. Change to any other channel
8. Reconnect coax to tv.
Followup:
Avoid this channel and go give Cablevision a call and let them know about it. They won't do anything to fix it until they get a certain number of reported issues about the problem
Dec 08, 2010 | Mintek DTV-373-D 37 in. LCD HDTV
We have a jvc tv with built in freeview ; yesterday we got the message on the screen pr list empty and now are stuck with 5 channels and no freeview ; how do we sort
What service company do you have for your TV? Is it dish network or direct tv etc. You can do a channel scan once you verify the service company. A cable service provider will only provide 99 channel to scan/sort while a satellite service provider will provide you more channels to sort/scan.
Aug 23, 2010 | JVC GD-V4211PCE 42 in. Plasma Television
Can you change the operating frequency of a Samson
No, the Stage 5 series are fixed-frequency units. They come in a variety of channels (the new 200Mhz range model has 28 different ones) but they're factory-set, and not programmable, so the frequency you pick when you buy one is the frequency you're stuck with.
Apr 07, 2010 | Samson Stage 5 / CO5 Professional...
Dtv is stuck on channel 5 and i cannot get it off
you need to rerun your channel set up
on cable if you have cable
Nov 19, 2009 | Televison & Video
Get gets stuck on 3 and 5
Probably picking up an open mic like a baby monitor or something like that, you may have to lock out those channels or re- program them.
May 24, 2009 | Uniden BCD396T 6000-Channels Handheld CB...
Wx channels
You are probably out of range of the other 5 channels for your area or your area may only have 2 Weather channels. I can sometimes get 4 here in the Los Angeles area but most of the time only 2. It depends on what the broad cast conditions are.
May 04, 2009 | Radio Shack Pro-95 Handheld Scanner
TV gets stuck on channel, won't advance past channel 7.1
Try doing the Channel Search again. See if that helps.
If not, sounds like the Digital Board could be defective. Since this TV is brand new suggest calling your local sharp authorized service center to replace that board under warranty.
Mar 16, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
RCA 32" TV
The most likely problem is a stuck tact switch, if it goes up in channel number, 5, 6, 7, etc. then the channel up button is stuck, if it counts down it`s obviously the ch. down button. Problem is you have to remove the guts of the set to get at the control boards screws, you can try turning on the set and poke around the offending push button with a tooth-pick, if it stops changing channels leave it alone and use your remote from now on to change channels, if you can`t get it to stop the tact switches or the control board module will have to be swapped out, hope this helps
Nov 27, 2007 | RCA F32695BC 32" TV
Radio Communications Logo
60 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
