Question about Nintendo DS Lite Console
Onknown format im am trying to use a new 4gb micro sd card but when i switch on i get a message ubknown sd format error code 0004 using ds one cards
    Sniper:
  • 58 Answers
The SD card format only goes to 2Gb, anything after this, is an SDHC.  You are obviously trying to use this with an R4 card or similar... These will only accept micro SD, and not micro SDHC
Posted on Jun 20, 2009
R4 ,When switching on ,SD error shows then
This sounds like a problem with the MicroSD card in the R4. Some brands have been known to be incompatible. Without knowing more information about the R4 and the SD card
A couple of years ago, I had three microSD cards fail, even reformatting failed. I believe it was a problem with the R4's at the time. Try reformatting the microSD card in a PC, download the latest kernel and load that on to the microSD card, if you can get it to format.
Failing that, buy a new SD card. SanDisk/Transcend and Kingston are the preferred and recommended types. Is this an R4 or R4-SDHC? Don't use an SDHC(4gb+) memory card in a R4, only in R4-SDHC.
Memory cards are cheap enough 1gb-2gb don't cost that much, if you have an R4-SDHC then try a 4gb
I take it it was working at some point or other, or is this a new card?
Apr 30, 2010 | Video Game Consoles & Games
Memory card error replaced card but still get error message?
Is it the SD memory card? or the Micro HDD(4GB) you're pertaining to. In case of micro hdd not detected or error, micro hdd socket(CF) assembly has a problem most likely, need to be replaced. SD card; check your SD card's capacity, it can handle only up to 2GB or try to format your card elsewhere and re insert it again in your camcorder, if it will prompt you "FORMAT SD CARD?" you're lucky
Feb 25, 2010 | JVC GZ-MC500 Memory Card Camcorder
Cannot format sd card
You are probably trying to format a micro-SD card that is greater than 2GB eg, micro-SDHC (High Capacity) of 4GB or bigger are not supported by 'older' devices. Stick to 1Gb or 2Gb standard microSD cards for your device.
Hope it helps. Let me know how you go.
Jan 13, 2010 | Samsung SCH-u740 Cellular Phone
New 4gb sd card will not work. card error
Is the slide switch in the unlocked position? Are you formatting it in the camera? Are the card contacts dirty?
Dec 07, 2009 | Casio Exilim EX-Z40 Digital Camera
Tried to download software for r4 micro sd card 4gb sh but does'nt work.comes on the ds loading ,works fine with 2gb sd card,any ideas? thank's colin
Hey there Colin,
The original R4 card only works with Micro-SD cards up to 2GB in size. To use Micro-SD cards up to 32GB, you need to buy the newer R4 SDHC card or a Nintendo DSi comaptible card. Check out R4 Cards / R4 DS Cards from DSCardWorld.com or NDS-Gear.com (NDS-Gear is probably better if you live in Europe or Canada as their shipping's slightly better internationally).
Oct 14, 2009 | SanDisk 2GB microSD Memory Card
I am not able to format my micro sd card.
try to format it using ur phone.. if still showing sum error thn card is corrupted.. it will be replaced
Sep 06, 2009 | SanDisk 4GB microSD High Capacity Memory...
Sd/tf card error
I use to have similar problems with my DS Card :(. In the end, I end up buying a new one - I personally use http://www.NDS-Gear.com
Apparently, the Sd/tf message occurs when there is a problem with the connection between the micro SD and the DS Card or between the DS card and the DS. You can try giving your micro SD a good clean ( give it a good blow) and see if that makes any difference. Also, I heard that sticking some papers at the back of the DS Card works for some people. If nne of this work, you would robably want to buy a new one or try and get a repalcement from your seller.
Jan 20, 2009 | Nintendo DS Lite Console
Ds shuts down whenr4 inserted
You should check if the R4 card is actually R4 SDHC, because the firmware of R4DS is not compatible with it. If it is SDHC, go to this website http://rs320.rapidshare.com/files/140174805/English-1.21.zip to download the firmware for your card. If there are any roms on it, you should save them somewhere else, for you have to format the card first (do this in windows by going to 'this computer', then right-clicking on the SD card from your R4 and then select 'format'. Warning! Never select 'quick format'! This could do damage). Now your card is completely empty. Copy the files you just downloaded and unzipped to the card (5 files; _system_, moonshl, _DS_MENU.DAT, _DS_MENU.INI and _DS_MSHL.NDS). Now put the SD card in the R4 and it should work properly :) I had the same problem, and I have just solved it *grin*. I hope this was useful.
Dec 08, 2008 | Nintendo DS Lite Console
4G micro SD
i had the same problem, my 2 gb would work ok but not my 4gb i have heard that the 4gb wont work on the older r4's, so i bought a ds Lite R4 Revolution III (Version 3) from amazon.co.uk and it came with evrything you need and it worked great the address is https://www.amazon.co.uk/s/ref=nb_ss_w_h_/275-1618189-4849908?url=search-alias%3Daps&field-keywords=DS+Lite+R4+Revolution+III+%28Version+3%29&x=14&y=15
Nov 03, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
161 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
